Old 10-26-2000, 05:46 PM   #1
copec
Member#: 1808
Post someone posted about adapting legacy turbo to impreza rs:
I remember someone posting about that in the sales section on a JC sports turbokit group buy. I did a search and couldn't find that post. Could you the person who posted that info, or someone knowadgeable on that info help me out.
I could do it myself, I figure I'm knowadgable enough to figure everything out. Just thought since someone has done it first I would get the headsup.
Can you take the legacy turbo exhaust manifold+turbo and just bolt it on the RS? Then just work a custom exhaust system and intake tract? Or did the person making it just make an uppipe to the Y manifold on the RS? I think that a ported legacy turbo exhaust manifold would work well.
I want to make 230hp street and 265-280 autocross.
I have a 98' impreza RS
copec is offline   Reply With Quote
Old 10-26-2000, 06:51 PM   #2
Tim Prudence
Member#: 216
Post
You'll need a turbo crossmember too, as the turbo headers will not clear the RS crossmember. There's a lot more information available if you do a search in the old technical forum.
As far as making 265-280 hp, that turbo just isn't quite up to the task. Believe me when I say it maxes out at around 230 hp... it can only sustain 7 psi at redline and by my math that equates to 245 hp assumming 100% efficiency (and many, many other assumptions). But that's probably not that far off, if you want to get to 280 hp go for the Vishnu kit.
Tim Prudence is offline   Reply With Quote
Old 10-26-2000, 09:12 PM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Talking
http://www.i-club.com/ubb-files/Foru...ML/000040.html
You will need an up-pipe from stock headers to turbo, a down-pipe from turbo to catback, a turbo to IC pipe and a turbo inlet to attach the air filter. This is all included in the kits people sell. Regular price for a rebuilt legacy kit is like $2,600 - $2,700 and they did a group buy for $1999 of which I am doing the instructions as a full color PDF file. I hope to finish it this weekend.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 10-26-2000, 10:29 PM   #4
copec
Member#: 1808
Post
well 230hp is still very reasonable, probably better anyways cause I have a 98' RS
I'm looking for a nice torque curve for autocross. I know all this stuff has been talked about, and I am aware of it mostly. Just now that I'm serious about putting a turbo on I have more questions.
Also, 230hp is the max hp for that turbo right? I mean flow rate is flow rate, even though it could only make 7psi boost on a 2.5L engine, It could make X boost on a 2.2L legacy turbo it would work out to be 230hp or around that.
Like for instance I get the cobb cams, or design and have some ground of my own (in which I am capable of, I've been learned base n/a tuning math for a while). The turbo would run less boost, because the flow rate of the engine has been modified.
Old 10-27-2000, 07:52 AM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
The 2.2T would probably max out at 230-250 because of the ECU limitations. Larger injectors, AA intercooler and ~13PSI of boost could net just about that much with proper intake, headers and downpipe.
This is what i'd LIKE to do, but i can't justify beating up this 4EAT much more! That, and i've got a blasted miss i can't pin down!
DLC is offline   Reply With Quote
Old 10-27-2000, 07:59 PM   #6
Andre Vandenberg
Member#: 501
1998 2.? RS Turbo ;)
RBP
Post
If you are looking for a turbo and up pipe, call Trey @ Cobb tuning, he has the 2.2 turbo with all the brackets and the up pipe as well. It is the stuff I took off of my motor when we built my 2.2 / MY98 2.5 "Hybrid"
Andre
Andre Vandenberg is offline   Reply With Quote
FS:(CT)Newer WRX/Legacy Turbo to Front Mount Adapter Kylar Engine/Power/Exhaust 2 05-27-2010 07:53 PM
2.2 Legacy turbo to a '95 2.2 Impreza? Wellhung Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-30-2002 07:16 AM
It's about time... Legacy turbo vented rear discs on my Impreza beachbum Brakes, Steering & Suspension 0 08-12-2001 07:54 PM
Thinking about a Legacy Turbo newscooby Legacy Forum 2 06-20-2001 09:34 AM
('93-'01) Thinking about a Legacy Turbo newscooby Impreza Forum 2 06-20-2001 08:42 AM
