Old 10-24-2000, 08:09 AM   #1
8Complex
Member#: 922
04 FXT
Red
Post Getting the max power for STS?
Seeing as I may be staying in the class for next year, I'm interested in what everyone has done that is STS legal and gives them a much needed power boost.
So far all I have done is an intake & suspension, but I'm looking for a complete list so I can start a somewhat rough list and estimate a price on the power.
So far for mods in STS I've got:
Intake
Exhaust
CARB legal headers (Borla?)
Underdrive Pulley
Higher octane fuel
Shorten tire height (in effect, reduce gear ratios)
Light wheels
Other then all those, all I can think of is altering the suspension (which I've done, but I haven't maxed out yet... planning a second STS question for the wheel/suspension forum). Any ideas? Is this actually a full list for our cars?
Also has anyone heard of someone reprogramming the ECU for extra power or raised rev limiter? This would be nice but I haven't heard anyone do it without piggybacks.
Old 10-24-2000, 08:17 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
Post
Shhh... I haven't told anyone this, because I had to try out my car again and make sure, but my Rev limiter is like no-one elses. Everyone I know hits at 6250, but my car doesn't.. It idels at around 600 rpm, and my rev limitier kicks in at about 7100 rpm. Why it is like that I don't know, but those Cobb cams are tempting me just to see how hard it will pull past that 6250 mark. NE1 else out there have a higher rev limiter?? Or know why mine is like this. no-one I've talked to can explain it and well.. I didn't tell the dealer 'cause I was afraid they would take it away from me.
One more thing.. headers are leagal for STS?? Sweet!
Thanks-
omahasubaru is offline   Reply With Quote
Old 10-24-2000, 08:24 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Good list, but suspension is going to make a bigger difference than all those parts put together. That said, and since this is the engine forum:
I would wait for the 2001 rulebook before deciding on headers. STS members have petitioned for the explicit allowance of high flow catalysts, which would IMO make the Borla header a bad choice. It takes a hard 90 degree turn to mate with the first stock catalyst. If you were to run aftermarket (straight through) catalysts, you could run 4-2-1 equal length headers like MRT offers. Hopefully a solution will present itself besides ordering from Australia, even though the AUD is at all time lows against the USD.
On the tires, if you really want light I would run 225/50-15 PZeroes ($168 ea, tirerack) on 15x7 Advan RG (est $250 ea, TRi). There aren't many 225/50-15 high performance street tires though, so perhaps a 225/45-16 Pzero or Continental ContiSport would be a better idea, on stock wheels or Advan RG (16x7 > $350 ea) depending on your budget.
ColinL is offline   Reply With Quote
Old 10-24-2000, 08:36 AM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Omaha: what you probably have is a stock tachometer that is even less accurate than usual. I highly doubt you are actually revving to 7100rpm.
Old 10-24-2000, 08:46 AM   #5
8Complex
Member#: 922
04 FXT
Red
Post
omahasubaru - You're not the first with this "problem". I've heard of several others, but mainly they ended around 6500. I think you may want to talk to Trey Cobb about that 7100 limit because IIRC he said the valves will start to float around 6800 or so. Of course, what Colin mentioned about the sloppy tach. is possible as well.
Colin - Yeah, I know we aren't allowed to swap out the cat's just yet, but I think they'll have a hard time passing that one since it goes against federal DOT regulations (something about not changing the cat's unless the stock ones go bad is a felony or something..). You're right about the header design though, I highly agree that I don't like it as well.
I also had planned on shortening the tire height, but I'm still unsure on which tires will be best (as I like to drift courses, this is a tough one - no STR for me for sure). Also, I had thought that Volks were lighter then Advans...
Old 10-24-2000, 09:28 AM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
I see you havn't listed an AFC or ITC. Or were those items now listed for SM only?
Revision is offline   Reply With Quote
Old 10-24-2000, 09:35 AM   #7
8Complex
Member#: 922
04 FXT
Red
Post
Well, they're piggybacks and piggybacks in general are borderline items. It depends on the alignment of the moon and stars as to how they'll rule them. *shrug*
Old 10-24-2000, 09:43 AM   #8
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Post
I don't know if this applies or not, but I'd heard that the 98 2.5RS had a redline of 6500 and the 99+ 2.5RS had a redline of 6250. Now if you have a 99+ then that info is useless to you.
That would be very nice to have full exhaust allowed for Street Touring. I've done no exhaust work yet but if I upgrade the headers and catback, why should I run it through the tiny stock cat if there are other street-legal cats available.
I've also heard there is a push to get motor mounts allowed in Street Touring...I'd like that rule. I want those mounts but I don't want to leave my class without alot more modification (and I don't want to lie about my class either).
Warp3 is offline   Reply With Quote
Old 10-24-2000, 09:46 AM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
the ecu rule is
Engine management computer or ECU may be altered, but car must meet federal emission standards.
soooooooo even a replacement is okay as long if you can pass a test....
other bits on my list
strut braces
cross drilled rotors
Braided brake lines
brake ducts
relocate battery
Plus what you have, thats about it.
Midwayman is offline   Reply With Quote
Old 10-24-2000, 09:47 AM   #10
8Complex
Member#: 922
04 FXT
Red
Post
Warp3 - Yeah, the Neon guys are trying to get mounts in because they have to replace theirs about 3 times a year since they keep breaking. I was going to get in on the GB on them until I realized it'd kick me out of STS.
Old 10-24-2000, 09:56 AM   #11
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
Post
Sorry to change subjects on you 8, but I have another question... What can I hook up to my car to see what RPM it is actually running and where it starts to be off at?
BTW I have a MY99.
I should probablly take into the dealership and see what they think, this is probablly a bad thing, 'cause I want a try tach that reads acurate.. hopefully that is all the problem is.
Old 10-24-2000, 10:44 AM   #12
8Complex
Member#: 922
04 FXT
Red
Post
omahasubaru - You could take it to the dealership if you wanted, or you could borrow an accurate tach from someone (aftermarket) and hook it up temporarily. I'm sure if it is off, you can get the dealership to replace/fix it for free.
Old 10-24-2000, 11:01 AM   #13
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Post
I have a '98 and RPM's are limited at 6700.
OK.. so if all the cool stuff I have is illegal in STS, what class am I in?
MRT exhaust (The whole shebang)
Intake
Engine/Tranny Mounts
APEX'i AFC
Toyo Proxis F24's
Short Shifter
Chuck is offline   Reply With Quote
Old 10-24-2000, 11:10 AM   #14
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The engine mounts might be legal, and the exhaust is only illegal if someone protests you. (it has to comply with federal emissions, which it probably does not. oh well.)
Otherwise, you're in Street Modified. You could also be in D Street Prepared. Either requires slicks if you have any aspirations of success, but honestly I don't think it will help much.
Old 10-24-2000, 11:14 AM   #15
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It could help... I'm in DSP (thanks to my driver's seat) & I was within 2-3 seconds of 2 different ACR Neons with R compound tires (or were they slicks... didn't check that closely) last Sunday, & I'm on Nexus street tires.
I'll see how things change when I use my newly acquired A032R's.
What's the difference between SM & DSP? It seems that I should be in STS except for the seat and the AFC... but if the AFC could put me in SM & the seat definitely puts me in DSP, which way does it go?
[This message has been edited by RidinLow (edited October 24, 2000).]
RidinLow is offline   Reply With Quote
Old 10-24-2000, 01:03 PM   #16
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Yep, and it is a damned shame about how I hit that rock just right to damage mine. Both of them, and absolutely nothing else.
stimpy: I expect to get my butt kicked in SM too. That's only weekend fun though, and I like the car a whole lot better after the cam install.
Old 10-24-2000, 01:04 PM   #17
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
1 hammer=1 damaged cat. Opps I hit something on the road.
Old 10-24-2000, 01:15 PM   #18
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
Then again, no current SM cars weigh 1800lb.
Unless you are competing in SM in the Philly region. Sean Christie won SM this year in a Civic hatchback which previously competed successfully in CSP (I believe). I'm not sure what work had been done to the car, or if he just jumped into SM for the hell of it. The only car in SM closely competitive with Christie has been the heavily modified Eclipse of Ian McFetridge (sp?).
I don't presume to be as good a driver as either Sean or Ian, but without R compound tires I was lagging (*cough* *cough*) behind.
SteveS is offline   Reply With Quote
Old 10-24-2000, 01:34 PM   #19
8Complex
Member#: 922
04 FXT
Red
Post
How much does a racing harness really help you guys? Personally I am fine with the stock belt as I'm used to driving like that (and I'm a large guy that fits snugly in the seat already).
Also kinda a poll... do you drive one-handed most of the time? I know I do until I'm coming up to big, tight turns. Someone was trying to tell me that I could turn faster with two hands, but I don't understand that as your goal is be smooth, not jaggedly-fast.
Old 10-24-2000, 02:10 PM   #20
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
While racing a time or two ago, I was strictly racing with one hand (its how I usually drive). I constantly found my car not cornering hard enough. Well it wasn't really the way the car was setup, it was that I was driving one handed and I couldn't rotate my arm any further. A switch to two-handed steering netted me another 1.5 seconds and I didn't find myself pushing to the outside of corners any longer. Only problem with this is that yes, you can wrap your steering wheel around more, but you also have to unwrap your steering further to get it straight again. I now race with two-hands needless to say.
Old 10-24-2000, 02:15 PM   #21
8Complex
Member#: 922
04 FXT
Red
Post
Hmmmmm... see my car is set up full oversteer so in reality I don't use much more then that one hand even on hard turns since I just flick into it and drift through it. The only time I use two hands is when I screw up and need to get back on course. *shrug*
Old 10-24-2000, 02:18 PM   #22
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
We're getting OT but you're a moderator so...
I drive with two hands most of the time on the street. When cruising for extended periods on the highway, I drive with only one had on the wheel, right between the two left spokes and I have a dent in the armrest from where my elbow ALWAYS rests.
While autocrossing or otherwise driving spiritedly, I always have my hands at the 9&3 and I don't remove them from the wheel unless I have to.
Old 10-24-2000, 02:22 PM   #23
8Complex
Member#: 922
04 FXT
Red
Post
It may be OT, but I was looking for a good place to post something autoX related on the board, and there was none. I think we need an autoX/rallyX forum.
BTW, over 70mph and I definetly have two hands on the wheel. Gotta really be prepared if you're cruising along at 100+ and have to maneuver quickly (which fortunately has never happened to me and hopefully never will).
Old 10-25-2000, 12:08 AM   #24
DLC
out back
Member#: 1964
01 BH
Blue/Bronze
Post
Here in Utah there are at least 3 guys with AFCs in STS, but one is actually illegal because he's got a CF hood.
He's still faster than everyone by a good second regardless of that 14lbs.
225Pzeros, Advan 17x7.5, Tein and Rallispec have a bit to do with his success.
Oh, and it's a hell of a fun ride in the passenger seat!
DLC is offline   Reply With Quote
Old 10-25-2000, 12:18 AM   #25
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Garrick, in DSP there are no competitors with over (WAY over) 300HP. In SM there are.
Then again, no current SM cars weigh 1800lb. For a long while, the winning DSP car has been a Fiat X1/9 but you have a pretty signficant horsepower advantage... The 2.5RS might be competitive in DSP if built to the limits of the rules. Same for SM, unless someone builds a ringer.
Max power for stock STI Turbo ? CALI07TR Newbies & FAQs 7 07-03-2008 08:13 AM
Max power for stock EJ257 crank Bilyk WRX Built Motor Discussion 22 02-16-2008 07:08 PM
Max Power For $4-5k ????/ Stover954rr Tri-State Area Forum 5 06-24-2005 09:34 AM
What's the max power can a Unichip make on a Stock Sti? smootth Engine Management & Tuning 16 07-28-2004 08:55 PM
Max power for a 12W3D4? Davenow Car Audio, Video & Security 6 05-13-2004 09:51 PM
Message Board Statistics All times are GMT -4. The time now is 02:30 PM.
