#1 |
Member#: 2341
Have any of you guys/girls had any problems with your turbo charged 2.5? Any rough idle, over-heating. How has drivability changed since intalling it (aside from MORE POWER!!!)?
#2 |
Member#: 216
I have a rough idle, I'm still not sure why that is.
#3 |
Member#: 1227
rough idle is a sign for a vacuum leak check on all turbo cars...either by means of a blown off hose or a tear or crack as a result of excessive heat. if thats the case try silicone hose, it's more durable.
Jon |
#4 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Several people have sent boosted EJ25s to an early demise through poor tuning.
#5 |
Member#: 132
Vehicle:1997 LGT Wagon 5spd '06 LGT 5spd Ltd Sdn |
Rotary, I was always under the impression that silicone lines on a turbo car were a no-no, simply because they expand so much under boost, probably not the best thing for boost controller and wastegate lines.
#6 |
out back
Moderator Member#: 1964
RMIC
Vehicle:01 BH Blue/Bronze |
Silicone is supple but much less prone to flex than rubber.
It'll also last a LOT longer. The hoses on my 93 are just about at the point where i might need to replace them all to fix a suspected leak. |
#7 |
Member#: 1163
Vehicle:We are nothing without our founder. |
Rubber vacuum lines will crack and break, rendering the vacuum useless. Silicone hoses have less of a chance of cracking, and they respond to heat less than rubber. The drawback is expense.
| Thread Tools | |
| Display Modes | |
| Has anyone had similar problems with their swap? | breaksjm | Subaru Conversions | 12 | 12-20-2006 08:37 PM |
| Has anyone had any problems with the cobb Stage 2 kit? | Subarubrim | Factory 2.0L Turbo Powertrain | 32 | 03-08-2005 05:20 PM |
| has anyone had this problem? | 42202sub | Factory 2.0L Turbo Powertrain | 3 | 09-03-2002 09:26 PM |
| has anyone had tranny problems with their new wrx | scooby | Newbies & FAQs | 1 | 12-07-2001 10:47 AM |
| Has anyone had rust problems with SPO Motorsports Adjustable Rear Sway Bar Kit? | Sean | Brakes, Steering & Suspension | 2 | 08-20-2001 08:55 AM |
