Old 07-07-2004, 02:08 PM   #1
Fermi
Member#: 50666
2000 Outback Sport
Blue Ridge Pearl/Titanium
Default proper inflation when car is really loaded down
After reading all the strict warnings from this website and Subaru about tire pressure affecting the differentials, I'm trying to figure out how I should have the front/rear tires inflated for an upcoming road trip in the mountains. A couple questions:
1) The car will be pretty loaded down in the back, so I assume this might change the -3 psi F/R differential since that is for an unloaded car? Should I actually measure the tires to get the diameters the same?
2) I'll be driving from ~600 ft above sea level to 8000+, so I assume the tire pressure will be higher when I arrive due to the lower pressure outside. Should I then deflate the tires to the original desired pressures?
Fermi is offline   Reply With Quote
Old 07-07-2004, 02:20 PM   #2
bluesubie
Member#: 767
04 FXT
I believe the info you've read about tires affecting the diffs is mainly related to replacing one worn tire. IMHO, a load isn't going to change the circumference in the tires enough to worry about diff damage.
You want extra air in your tires to help support the extra load that you'll be carrying (to avoid blowouts, etc.). I've gone with 4 psi's over recommended psi's for trips with two weeks worth of luggage and toys including a Thule cargo box.
It's worth keeping it at 4 psi's over at all times anyway for better handling.
-Dennis
Old 07-08-2004, 11:25 AM   #3
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
To be safe I would suggest to not exceed the max pressure on the tire sidewall . That is the max cold PSI so the tire can carry its max load . If you feel the tire is not up to the load you may want to consider a tire with a higher load index rating .
Just my .02
imprezzakc is offline   Reply With Quote
Old 07-08-2004, 12:11 PM   #4
fliz
Member#: 30342
-Dennis
Not to mention better gas mileage.
Run a tank at 32/29, then run a tank at 40/37. You'll get better mileage at 40.
PS. I ran 35/32 for a while, then I put on tires that were inflated to 40/37 and got much better mileage. Now I run 42/39.
Re #2: The difference in atmospheric pressure between sea level and 8000 feet isn't enough to make a noticable difference in tire pressures. Atmospheric pressure is 14.7psi at sea level, 10.4 psi at 2500m ( http://www.personal.usyd.edu.au/~gerhard/pressure.html ) . You would cause more problems by dropping the pressures, because you would end up with underinflated tires when you dropped back down.
fliz is online now   Reply With Quote
Old 07-08-2004, 04:20 PM   #5
Fermi
Member#: 50666
2000 Outback Sport
Good point!
Old 07-09-2004, 02:40 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
A LARGE percentage of problems that people have with tires are due to underinflation......and very few are due to over inflation.
Old 07-09-2004, 02:58 AM   #7
ripvw
Member#: 27790
as far as load capacity, P-metric radials reach their max rating at 35psi, Euro-metric radials at 36psi cold pressure. Putting in more air beyond that won't increase the load capacity of the tires. However, increasing pressure to at least that point guarantees that your tires are at their maximum load capacity
I like cold pressures between 35 and 40psi for their impact on dry handling. over 40psi you may be losing max contact patch width - i.e. dry cornering grip. you end up sacrificing grip for better "feel" and responsiveness - not a good trade in my book.
ripvw is offline   Reply With Quote
'02 Outback 2.5 NA - near stall when turning, strange noise, happens when car is hot merlin2375 Normally Aspirated Powertrain 5 03-29-2010 02:45 PM
rpm goes up when there is a load harrisont Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-28-2008 01:49 AM
So when exactly is NASIOC going down for maintenance? MattDell Off-Topic 8 07-16-2004 02:37 PM
Alarm keeps engaging when the car is idleing(sp?) down.... ChristophWRX Electrical & Lighting 6 12-16-2003 10:29 PM
My car is really sick & dealership is lagging Lisa Bay Area Impreza Club Forum -- BAIC 7 09-18-2002 06:26 PM
