Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 07-07-2004, 02:48 PM   #1
Dong9mong
Member#: 60227
Default JDM V7 vs V8 Suspension
What are the main differences between the JDM STI V7 and V8 suspension? Also, what is the difference between the springs that come with the JDM struts and the STI pink springs? Thanks.
Dong9mong is offline   Reply With Quote
Old 07-07-2004, 04:52 PM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
V7 is for bugeye Imprezas, V8 for the "normal" headlight versions. The major difference is rear spring and strut top design. There was a V7 wagon version, but not V8.
JDM springs come in standard (188/173), Type RA (215/190), and Spec C (200/130-200, progressive). The USDM STI uses Spec C springs.
Regular STi springs (black) are regular height, Pinks are lowering springs. V8 Pinks (257/217) are stiffer than V7 Pinks (215/190).
This is all of the top of my head, so don't sue me if I got a number wrong.
Mark Avery is offline   Reply With Quote
Old 07-07-2004, 05:49 PM   #3
Dong9mong
Member#: 60227
thanks for the info mark.
will the v7 strut/spring combo work on a 2004 wrx and will i have buy other things to make it work (like tophats)? if not, then should i just look for v8 suspension instead? thanks again for the help.
Old 07-07-2004, 07:58 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
If you get the V7 combo complete with top hats, you'll be fine to install in a 2004 WRX. If you only get the struts and springs you'll need to get 02/03 rear hats, your front hats will work fine.
I would personally go with the V8 setup as its an easier swap to go to the STi pink springs which you are sure to go to. Plus, I've heard that there might have been some valving improvements with the V8's. Not sure though. However, the V7 struts have a few more spring options out available because they've been around longer.
Arnie is offline   Reply With Quote
Old 07-07-2004, 08:55 PM   #5
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
What he said-----
944 turbo guy
Myles Williams
Racecomp Engineering LLC
www.racecompengineering.com
2720 Sisson st .
Baltimore, Md 21211
410-366-RACE (7223)
410-707-0108 cell
RaceComp Engineering is online now   Reply With Quote
Old 07-08-2004, 04:18 AM   #6
jackassery
Member#: 48655
2003 WRX
Sonic Yellow
Okay I've been looking at this all for some time. My simple question is do the Ver 8 Sti takeoffs will work on an 03 or do I need to get a set of Ver 7 takeoffs?
From everything I have read, I need the Ver 7 set because of the issue with the rear Ver 8 tophats not fitting the 03's rear, right?
-Jamaal
jackassery is offline   Reply With Quote
Old 07-08-2004, 04:35 AM   #7
supermarkus
Member#: 6971
2008 WRX STi
SSM
No, Ver8 bolt right up to the older cars. It's just that you cant mix and match their rear springs without having the proper model strut tops. If you have ver 8 springs you need the ver 8 tops, etc.
supermarkus is offline   Reply With Quote
Old 07-08-2004, 12:47 PM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Exactly! If you have a complete setup of springs, struts and hats, either will bolt up.
V7 vs V8 dyno chart mudbug Proven Power Bragging 36 02-11-2010 09:32 PM
V7 vs V8 questions?? 2000wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2004 07:51 AM
WTB: JDM V7 or V8 suspension takeoffs, complete heffergm Private 'Wanted' Classifieds 2 04-13-2004 09:25 PM
WTB: Sti v7 or v8 suspension/ txs axleback v1 DirtstyleWRX Private 'Wanted' Classifieds 7 01-04-2004 02:03 PM
JDM V7 vs. V8, AVCS hookup questions dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-25-2003 03:26 PM
