Old 07-07-2004, 06:13 PM   #1
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Default Installing WRX injectors befor turbo?
Im getting ready to install my turbo, and I was planning on doing the parallel fuel mod this week. But I would like to install my WRX injectors while I have the manifold off the car.
Will my car run with the WRX injectors? or will it be really rich?
My car is pretty much stock right now, I do have a S-AFC installed so I could back off some of the fuel.
Anthony C
Bobalouy is offline   Reply With Quote
Old 07-07-2004, 06:46 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
u SHOUDL be able to pull fuel enough, but im not sure what the safc capabilities are
what fpr did u choose?
Old 07-07-2004, 09:32 PM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
If you pull the max amount of fuel you will just barely get it to idle.
Drac9 is offline   Reply With Quote
Old 07-07-2004, 10:45 PM   #4
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
The S-AFC does +/-50%
I was thinking if the stock injectors are 280 and the WRX's are 420, thats like a 50% difference.
White 2.5rs - I dont have an FPR yet, do I really need one on a 99rs at ~6psi
Thanks
Anthony C
Old 07-08-2004, 08:31 AM   #5
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Currently I am running Wrx injectors with just a FPR. the Car idles and runs very well . You will be fine!!
The WRX injectros are really 380cc. Look at I-speed.us to read more about those injectors!!
Elliot is offline   Reply With Quote
Old 07-08-2004, 09:15 AM   #6
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Interesting, but do you have your turbo installed? Im talking about befor the turbo is in.
but anyway if the wrx injectors are 380cc. does that mean if I pull 36% of fuel all the way across the board I will be back to normal. Or do things not work that way?
Thanks
Anthony C
Old 07-08-2004, 10:03 AM   #7
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
you'll be fine... its all in the "tune" thought all you do is take fuel out... do a search there are rough settings for this setup...
it was used quite some time heh
HOK is offline   Reply With Quote
Old 07-08-2004, 10:35 AM   #8
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Ok well I'll just give it a try.
HOK - I searched befor I posted, but couldnt find much info on NA rs's with the injectors. Do you know who did it?
Anthony C
Old 07-08-2004, 10:58 AM   #9
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Start with -20% all around in Lo settings and -15% in hi settings.
watch your EGT gauge and set it to reach 1500F cruising and 1400-1450 WOT
Elliot
Old 07-08-2004, 12:27 PM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
you will be fine for short term i mean... You will be able to go around town but thats about it. I didn't feel that you needed this for more then that. long term yup you will have problems.. way too rich..
Old 07-10-2004, 10:40 AM   #11
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
i was surprised to find that my car idles perfectly with no correction with my WRX injectors....
wierd and I need to have them and my stockers flow tested for piece of mind but its the truth!!!
with almost no internal adjustment from the computer!! about -5 - -10% which was normal for idling in closed loop with my stockers.
Hitokiri is offline   Reply With Quote
Old 07-10-2004, 12:06 PM   #12
Unsung Boxer
Member#: 37196
the ecu is capable or a +/- 20% fuel trim. i dont see how anyone's car can run fine w/o fuel managment w/ WRX injectors.
my Turbo Legacy EJ22t injectors, are only 100cc over stock and my car ran like CRAP-OLA when i put them in and started it up w/o my emanage. I am idling at -37%. If it was not running boost it would be -37 across the board to make it run like stock.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 07-11-2004, 09:10 AM   #13
4wheelmotion
Member#: 2044
1999 2.5 rs-T
rally blue/ '96 jetta vr6
i've been running with wrx injectors with my stock ecu for about 1k miles. with no corrections at low throttle and no corrections at idle. only corrections are at high throttle for boost.
-robbie
4wheelmotion is offline   Reply With Quote
Old 07-11-2004, 11:10 AM   #14
Unsung Boxer
Member#: 37196
then you are running extremely rich at idle. Your o2 sensor fuel trim is likely maxed. im surprised the ECU hasnt thrown a CEL for this
If you continue to run this rich, the unburned fuel in the exhaust system will ruin the catalyst. Your spark plugs will eventually foul as well, then you will have a misfire problem.
Fuel managment is important guys, dont skimp on it. Dont expect your ECU to take care of everything.
-Jake
Old 07-11-2004, 05:55 PM   #15
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Thanks for the input guys, I decided to hold off on the injectors, but I did do the parallel fuel mod, and paint the manifold while I was at it.
Old 07-12-2004, 12:54 AM   #16
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
unsung - nope I monitor my fuel trims very closely while road tuning with the emanage. I can assure you that it idles at under 10% corection on my car and at perfectly stoic A/F (LM1).
I want to get the WRXs flowed against my stockers real bad. I was concerned at first, but it is reasuring to see other MY99 RS people have had the same experience.
WTB stock 02-05 wrx injectors, tdo4 turbo and stock tgv tumblers felixwankel88 Private 'Wanted' Classifieds 3 08-10-2009 11:56 PM
FS: EJ205 Shortblock, WRX Injectors, TDO4 Turbo, WRX Fuel Pump bryancregger Engine/Power/Exhaust 4 09-01-2008 03:39 AM
5th injector or wrx injectors for turbo rougeben83 Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-08-2006 05:59 PM
stock WRX injectors and turbo DJIMPREZA Private 'Wanted' Classifieds 1 01-08-2004 08:02 PM
WRX injectors for Turbo RS? Pipercub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-14-2001 12:52 AM
