Old 10-25-2000, 08:07 PM   #1
IMPBOY
Member#: 65
Post How bad is water leaking through air filter for engine?
I have K&N cone just below the hood scoop. It rained today and I noticed the filter got soaked a little after driving around for while. If water did get into the engine, does it cause serious problems or the engine just stall without any damage? I thought K&N was semi-water proof...
IMPBOY is offline   Reply With Quote
Old 10-25-2000, 08:10 PM   #2
nathan power
Member#: 2208
Post
could cause vapor lock. witch ould cause bent concting rods. You cant compress a liquid. Get it covered.
nathan power is offline   Reply With Quote
Old 10-25-2000, 10:19 PM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
That would be "hydro-lock" - vaporlock is what my 1983 Mazda GLC would do when the carburator and fuel lines would get hot while delivering pizza in college...
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 10-25-2000, 10:22 PM   #4
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Even with our small displacement motors you'd have to suck in a pretty decent amount of water to hydrolock a motor. Most cases of hydrolock occur when people drive through puddles or shallow streams etc. My intake sits under one of the hood vents and has sat there since I put the intake on three months ago. Before I had the intake I was using just the airbox with all of the tubing removed. Still no problems, even with the torrential downpours we've been having in New England earlier on this year.
Fitz
Fitz is offline   Reply With Quote
Old 10-26-2000, 12:53 AM   #5
wistful
Member#: 745
2004 STi
Java Black Pearl
Post
what's vapor-lock, I've heard of it before..
Don
wistful is offline   Reply With Quote
Old 10-26-2000, 01:07 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Vapor lock is when air would get in the fuel lines and the carb. wouldn't get fuel. This was fixed by fuel injection since the fuel system is under pressure between the main pump and fuel rail at all times.
And no, a bit of water in the intake doesn't hurt. It's like an internal steam cleaning at times... just don't go overboard.
Old 10-26-2000, 09:07 AM   #7
gumball
Member#: 1209
Post
yeah- there was a Car Talk discussion about how some techies will actually used an extremely carefully controlled flow of fine mist in the intake to clean the valves etc...
The vapor just does a good job of knocking deposits loose.
gumball is offline   Reply With Quote
Old 10-27-2000, 07:51 AM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Post
Ever herd of water injection. I think Jackson Racing sells a system for water injection.
Like others sed, you need quite a bit of water to creat problems. Like dumping a glass of water down the intake with the engine running. That would do it..!!
Water injection is REALLY a great thing, ESPICALLY for those whom have TURBOS. Not only does water injection "steam clean" the engine internally but it also helps curb detonation, water is a MUCH better conductor of heat than fuel so it helps ti keep thing ALOT cooler.
For the turbo guys, it also allows more boost, due to the detonation curbing capibilty.
I read somewere when doing some reaserch on the subject that in Europe some of the cars running W.I. pushing up to 44bar of boost!!!
Anyway, This is what i've read here and there, i could be talkin out my butt though.
AaRoN
How bad is it to seal exhaust leaks with Sealent? Steveee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-23-2006 08:02 PM
How bad is a Tranny oil leak??? line Transmission (AT/MT) & Driveline 12 04-20-2005 11:16 PM
Is this correct engine air filter for STi? 2dino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 04-26-2004 12:30 AM
Question about possible water leaking through the hood scoop into the engine bay? bambams247 Interior & Exterior Modification 2 08-28-2003 12:20 PM
How bad is it for the Engine ??? morgie Legacy Forum 6 11-19-2002 10:52 PM
