Old 07-07-2004, 11:11 PM   #1
thrillho
Member#: 59816
2004 WRX
World Rally Blue
Default How could I tell if a rim will fit the WRX?
Like the numbers. I don't know anyhing about wheels and would like some help.
thrillho is offline   Reply With Quote
Old 07-08-2004, 12:02 AM   #2
ripvw
Member#: 27790
here are the numbers:
PCD (pitch circle diameter or bolt pattern): 5 x 100 (this was changed to 5 x 114.3 for the '05 STI, just to make things more complicated)
offset: the typical range is from ET45 to ET55(stock) with ET48 being about average
centerbore - hub diameter: 56.1mm - wheels that have this measurement are known as "hubcentric"
is your '04 a wagon or a sedan?
wagons have less space in the rear fenderwells so wheel width and offset can be an issue - sedans have a lot more room
read the sticky's at the top of this forum, like this one:
http://forums.nasioc.com/forums/show...hreadid=524624
it has a good definition of offset among other things
the stock WRX wheels are 16x6.5 ET55 and weigh 16.5 lbs
most of us end up with 17x7 or 17x7.5 wheels - the 17x7 size is what the rest of the world gets standard on their WRX - we're "special"
other options are 16x7, 16x8, 17x8, 18x7.5 and 18x8. All of these will fit the sedan without rubbing assuming that you also get appropriate sized tires - with some of these choices on the wagon you may need some guidance or you will have to "roll the fenders" to make things fit
if you get your wheels from [email protected] Rack he will make sure you end up with something that fits - Tire Rack has a very large assortment of Subaru specific wheels - ASA and Kazera are popular - as well as the best technical information on the Internet. Read their website and become enlightened. Make sure to go through Luke - the other people at Tire Rack may be ignorant of Subaru's
other vendors who know their stuff are Dave @ Oakos, Brad @ TB Racing and Suby_Dude - all of whom sell the very popular Rota line of wheels
Enkei also makes some good, not too expensive wheels for the Subaru and Nino @ Nino's Auto Accessories and Rich @ Daddy's sell them
There are lots more wheels - OZ, Prodrive, SSR, BBS, Volk, etc. - and vendors, of course - this is just to get you started
if you have already seen a wheel that you like, make sure that it meets the criteria above for bolt pattern and offset - the centerbore can be adjusted for with "centering rings". Many good vendors will specify "Subaru fitment" to make it easy for you
sorry - lots more than you wanted to know, I'm sure. some nights I just can't stop writing...
ripvw is offline   Reply With Quote
Old 07-08-2004, 12:25 AM   #3
thrillho
Member#: 59816
2004 WRX
World Rally Blue
Don't apologize, the more the merrier. I'm asking b/c I 'm trying to get cheap off Ebay and they of course aren't WRX specific.
I have a sedan.
Would a Universal bolt pattern work? They are ugly but I assume should work. Also, I thought I understood bolt pattern until you posted that 5x114.3 thing for the STI. 5 is the # of spokes right? What is that x100? Would the WRX sedan work with something like 5x114.3?
So what is the highest and lowest offset my sedan car run? What does the + mean? Example: +45 offset.
Old 07-08-2004, 12:30 AM   #4
PigSTi
Member#: 65822
2002 Sport Wagon
/=BlueBlackYellowWhiteRed
How cheap is cheap, because you can get the perfect spec. Rotas for $600ish new.
PS Go Lehigh!
PPS use the search function it's all been covered. Or at least read the FAQ at the top.
PigSTi is offline   Reply With Quote
Old 07-08-2004, 01:30 AM   #5
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
I have a sedan.
5 is the number of lugs and 114.3 is the diameter. Your car is 5x100, so 5 lugs with a 100 mm diameter. So to answer you question, the WRX will only work with rims that have 5x100 bolt patterns.
For bolt patterns, read this: http://www.tirerack.com/wheels/tech/boltpatt.htm
For offsets, read this: http://www.tirerack.com/wheels/tech/offset.htm
Also, read the Offset Sticky. It will tell you general guidelines about offsets for different rim widths.
Silver04WRX is offline   Reply With Quote
Old 07-08-2004, 02:33 PM   #6
WagnerRX03
Member#: 64370
03 bugeye wrx
07 avalon
wait wait wait....et me see if i get this right....the new BBS STI wheels will not fit my 03 wrx Sedan? why do they do that to me? they might as well take a dagger to my heart and kill me...lol
WagnerRX03 is offline   Reply With Quote
Old 07-08-2004, 02:57 PM   #7
jland67
Member#: 14427
2002 09 Mazdaspeed 3
Grey
The 04 BBS STi wheels will fit.
Jeremy
jland67 is offline   Reply With Quote
Old 07-08-2004, 04:17 PM   #8
YinUCSD
Member#: 44945
06 LGT wag
Jeremy
yes the 04s will fit 02/03 wrx.
BUT
the 05 sti wheels will NOT fit the 02/03 wrx's. the 05 sti has 5 x 114.3 bolt pattern, while the 02/03's have a 5 x 100 bolt pattern.
YinUCSD is offline   Reply With Quote
Old 07-08-2004, 05:04 PM   #9
poison
Member#: 37678
"How could I tell if a rim will fit the WRX? "
Take the wheel in question. Cover it in newly sheared lambswool from the firstborn calf of your oldest ewe. Wait until the first sign of the new moon when the Warrior crosses the Equinox. Burn the lambswool with freshly cut cedar boughs. If the wheel is discolored, it will fit. If it is not discolored, you shall shatter it with a thousand stones and scatter it in your fields.
Or just ask the Wheel and Tire forum
poison is online now   Reply With Quote
Old 07-09-2004, 12:18 PM   #10
mch
Member#: 30039
2002 wrx wagon
dirt slvr
You forgot the "mess about with virgins" part....
mch is offline   Reply With Quote
Other makes/ models that will fit the WRX? thunder_lizard_1976 Tire & Wheel 1 07-29-2008 11:56 PM
enkei 17X8 NT03 rims will fit 02 wrx wagon?? spitfirezip100 Tire & Wheel 3 10-14-2005 04:58 PM
Any 16 inch rims will fit the 04 STi? V6 Tire & Wheel 5 08-05-2005 04:12 PM
How could I tell if a rim will fit my WRX? thrillho Tire & Wheel 4 07-08-2004 02:21 PM
What Factory Rims will Fit the WRX? jonnyslick Interior & Exterior Modification 6 01-11-2003 03:47 AM
