Old 07-07-2004, 11:18 PM   #1
WRXVII
Member#: 15854
VF34'd...
Default KYB AGX with Eibach prokit springs
It's finally time to replace struts... right rear strut is making clunking noise whenever going over a bump. It's awesome that stock struts lasted well over 30k miles with lowered springs.
What's your opinion about using Eibach prokit springs on AGX? Any opinion?
WRXVII is offline   Reply With Quote
Old 07-07-2004, 11:56 PM   #2
vip
Member#: 6854
I have that setup
All i can say is it is much much better than stock. I am really happy, car corners like its on rails.
get the struts from ebay
kybwarehouse
375 plus shipping
umm i wrote a review do a search for kyb agx and eibach springs
vip
vip is offline   Reply With Quote
Old 07-08-2004, 11:02 AM   #3
Nok's WRX
Member#: 25797
2002 PSM - Stock
Same setup here, much better than stock and loved it at the track on #4.
It's even better with the group-n mounts
Nok's WRX is offline   Reply With Quote
Old 07-08-2004, 11:17 AM   #4
2003WRX
Member#: 23440
2005 Black 35th
Anniversary 350Z
I have that setup as well. I run the AGX's on #2 all the way around. The car handles great and I give up long before it does in the canyons. Zero complaints here... Here are pics of the drop of you are interested in how low it is: http://www.fsengage.com/Camel/WRX.html
2003WRX is offline   Reply With Quote
Old 07-08-2004, 08:49 PM   #5
foureyedlameo
Member#: 65584
'00 XJ
To the guys with the AGX's already, I had the KYB's on my previous car, 99 civic si, and i had four adjustments on the front struts, on the top of the shaft, and eight adjustments with a knob at the bottom of the housings on the rears.
How are they adjustable for the wrx, and if it is top adjustments front and rear, how difficult is it to adjust the rears. It seems that it would be very difficult without removing the back of the rear seat every time I want to adjust them.
foureyedlameo is offline   Reply With Quote
Old 07-09-2004, 10:54 AM   #6
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Adjustments for the impreza are in the same location . IE fronts on top and rears on the side of the strut body under the car .
i have run this setup for close to two years on my RS . Great compromise . i can stiffen it up for autox and soften it up for my wife to drive the car .
imprezzakc is offline   Reply With Quote
Old 07-09-2004, 11:23 AM   #7
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
no the WRX specific struts have adjustments on the top in both the front and back for the 02+ the old gc had side adjustment on the rears but that has since changed (this can be confirmed w/ part #'s)
The adjustments are obviously simple to the fronts but to do the rears depending on how you want to do it it will take anywhere between 1 and 20 min. You can always pull yoru rear seat out every time or just not hook in the outsides of yoru seat (I did this at the recomendation of someone) then you just reach behind while looking through your window and it takes less than a minute.
MustGoFast is offline   Reply With Quote
Old 07-09-2004, 11:53 AM   #8
Nok's WRX
Member#: 25797
2002 PSM - Stock
Hmmm, I might just do that. Left the outside shoulder loose one time and it did'nt look that bad.
Old 07-09-2004, 12:51 PM   #9
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
sorry bout that ... now why do the have to go and change things .....
Old 07-11-2004, 05:19 PM   #10
MustGoFast
Member#: 33370
2002 Impreza WRX
they didn't change anything really.. they just finally made a WRX specific version.
Old 07-11-2004, 08:35 PM   #11
ethereal
Member#: 19329
1992 VW Golf
just 5 mins ago i ordered a set of KYB AGX to mate with my tein s-tech (GC8)
after reading this thread, i am excited.
-Andy
ethereal is offline   Reply With Quote
Old 07-12-2004, 12:17 AM   #12
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
I think you will really like em . If you haven't yet get a 20 or 20-24 mm rear sway bar . It really helps to balance out our chassis .
Old 07-23-2004, 12:50 AM   #13
WRXVII
Member#: 15854
VF34'd...
Just installed mine today... I set it to setting#1... it feels a little stiff. Will change to #2 next week to see if it makes difference!
Old 07-27-2004, 04:38 PM   #14
MustGoFast
Member#: 33370
2002 Impreza WRX
setting 1 is the same as stock.. the change in stiffness is just the springs there.. try setting 4
GC8 Suspension - KYB AGXs with Eibach springs jamesfacts NESIC Private Classifieds 1 02-17-2007 08:28 PM
KYB AGX with Eibach Prokit springs imprezzakc Private 'For Sale' Classifieds 1 10-30-2005 11:58 PM
KYB AGX with Eibach prokit springs for 03 wrx Lordhowe Private 'For Sale' Classifieds 7 09-16-2005 07:48 PM
Help!! KYB/AGX With Eibach Springs Dissenter Brakes, Steering & Suspension 11 11-28-2001 08:59 PM
Does anyone have KYB AGXs with Eibach Springs? Dolphin Overton Technical Forum Archive 10 09-18-2000 08:31 AM
