Old 10-25-2000, 07:12 AM   #1
Gambit
Member#: 102
Post How often do you reset your ECU?
I just reset my ecu again because I got some hesitations. Not only did the hesitations' gone, the car felt all new again! Maybe it's my head. But heck that thing pulled like it just got 2 JATO rockets strapped behind it compared to pre-ecu rest era! I think from now on I will reset my ecu every 2 months irregardless. If anything just to make the ecu forget the lazy driving habit days....
Gambit is offline   Reply With Quote
Old 10-25-2000, 07:21 AM   #2
DuneHopper
Member#: 1249
2000 OBS
Post
I reset after every oil change. There's that rumor that the sound of the air being pumped out of the oil filter can trick the knock sensor/ECU into retarding the timing. Anyhow, it's a convenient time to do the reset, and my putt-putt OBS almost feels like it has gumption after a reset.
DuneHopper is offline   Reply With Quote
Old 10-25-2000, 07:43 AM   #3
Subi Chicky
Member#: 2239
'05 Civic Si, SSM
RIP Sirkbac
Arrow
Never heard of that . . in my expereince, ECU only needs re-setting after something major is done with the system, ie install of new mods like intakes and piggyback devices, etc.
Subi Chicky is offline   Reply With Quote
Old 10-25-2000, 07:46 AM   #4
steve_d
Member#: 315
Post
we all know how the oil filter spins on...
I just fill mine to the edge, and spin it on.
sjd
steve_d is offline   Reply With Quote
Old 10-25-2000, 08:37 AM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
When i worked for Q-Lube (before PZ turned them into Jiffy-Lubes) we never filled the filter with oil. We just lubed the rubber gasket and screwed it on.
If you fill your filter first, then don't worry, otherwise some people have had odd problems with their knock sensors.
DLC is offline   Reply With Quote
Old 10-25-2000, 09:02 AM   #6
RRinDC
Member#: 204
1998 Impreza OBS
Glacier White/Slate
Cool
I do an ecu reset whenever I think of it, maybe 8-10 times a year.
RRinDC is offline   Reply With Quote
Old 10-25-2000, 09:27 AM   #7
Kachukaa
Member#: 2527
1997 Legacy 2.5GT
Quicksilver Metallic
Post
I don't mean to sound like an idiot, but how do you reset your ECU. Just put a Weapon R intake on mine.
Kachukaa is offline   Reply With Quote
Old 10-25-2000, 10:08 AM   #8
Gambit
Member#: 102
Post
Also is there away to reset the ecu without going the battery terminals route? I know there's the fuses route? WIll it trigger the car alarm if I put back the fuse? And what fuse was it?!
Old 10-25-2000, 10:27 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Only once since I've owned it and I switched from intake to intake to intake. *shrug* Somehow I can't believe that it's that important...
Old 10-25-2000, 10:28 AM   #10
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
Can someone please put a comprehensive method on how to reset the ECU in the mods section please!?!
This has been asked too many times for it not to be there.
If someone wants a very reliable (I've never had a problem) method, PM me. If you want my method for the mods section, again, PM me.
-Rez
P.S. I've reset my ECU twice. Got the feared high idle when I did it incorrectly (didn't let it idle long enough) and had to do it again.
[Edited to answer the question. Oops.]
[This message has been edited by Rez (edited October 25, 2000).]
Rez is offline   Reply With Quote
Old 10-25-2000, 10:48 AM   #11
Tim Prudence
Member#: 216
Post
Doesn't ECU resetting give you poor gas mileage, it does on my My99 turbo.
Tim Prudence is offline   Reply With Quote
Old 10-25-2000, 11:01 AM   #12
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Exclamation
Listen to me, all you doubters!
I can tell you that my car experienced a hesitation from 3-4,ooo rpms after my last oil change. I put in some good old mobil 1 and an additive, did a perfect change and got mucho hesitation!
Well needless to say, I was concerned about this problem. But thanks to the suggestions found in the I-club, I did a ecu reset.
I swear that I got 10 hp out of it. I would say the improvement was easily better than the underdrive pulley I put on!
So try it! It will work!
(oh by the way I had 94 octane fuel in the tank during the reset)
Rich L is offline   Reply With Quote
Old 10-25-2000, 11:43 AM   #13
wrxman555
Member#: 2677
2001 Lexus IS300
Post
Unhook the negative terminal on your battery and leave it for about 5-10 minutes. Hook it back up and turn your car on, keep ALL accesories,(stereo) off! Let car idle for about 30 minutes. Turn car off and then start it up again. BAM, you did a RESET!
wrxman555 is offline   Reply With Quote
Old 10-25-2000, 02:20 PM   #14
wrxman555
Member#: 2677
2001 Lexus IS300
Post
I think my way is way easier. Plus, I am sure that I'm not the only one that does it the way I do it. Just my .02 Cents
Old 10-26-2000, 12:02 AM   #15
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Thumbs up
Hell yeah, I'm gonna start reseting the ECU when I go to the strip because I too feel the release of power when my car's memory is erased and it has to learn the way I drive it again.
Zee
Sunrise City Rider is offline   Reply With Quote
Old 10-26-2000, 12:20 AM   #16
sasim
Member#: 2659
Smile
Hey Guys,
The correct method (some say!) for resetting your ECU can be found at:
http://www.mrtrally.com.au/performance/howresetecu.htm
SS
sasim is offline   Reply With Quote
Old 10-26-2000, 02:38 PM   #17
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Lightbulb
I just pull up on the carpet on the passenger side. Unbolt the shield over the ecu and unplug the harness. I leave it unplugged for about 30 minutes for good measure. Then plug back in and start up car. Now as far as romping on the gas as soon as 1st startup after reset, or letting it idle for 5-10 minutes....well your guess is as good as mine!
(BTW I don't loose my Radio settings and xover settings this way!)
-chrisC
MY99 2.5GT Ltd.
silverSurfer is offline   Reply With Quote
Old 10-26-2000, 02:57 PM   #18
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Thumbs down
chrisC,
I would not recommend doing that without disconnecting your battery. The reason is that the ECU connector isn't really designed as a "hot-pluggable" connector, so there is always the danger of electrical surges to components when the pins mate up at odd sequences.
Wire up a battery isolator and 12V gel-cel for your stereo equipment, if it's that important to you. But hey, it's your car.
-WaC
Wayne
97 OBS, EE by day
wac is offline   Reply With Quote
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 08:30 PM
How often do you reset your router sha_zapple Off-Topic 54 12-11-2006 10:59 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 03:22 PM
How do you reset your ECU IcedOutRS Newbies & FAQs 10 03-27-2001 04:41 PM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 05:07 PM
