Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 10-25-2000, 07:30 PM   #1
Member#: 730
Angry Need help with dying ignition problem...
Hey. The Scoob has a problem. Occasionally when I'm idling, such as at a stoplight, the engine will die, and I can't restart it. I have checked and I am getting spark and fuel. If I can get the car rolling, I can bump start it in 2nd gear with the key on and not using the starter.
The previous owner mentioned that there was a secondary ignition in the switch that would need to be replaced. I have already replaced the coil pack, thinking that this was the culprit, but to no avail. Does this sound like the problem? Is it really the switch? I need answers fast, as this is my primary mode of transport to work, and PacBell is very anal about tardiness and missed days.
Digital_Boy is offline   Reply With Quote
Old 10-26-2000, 10:02 AM   #2
Member#: 857
Start with the cheap & easy repairs first... Thus, get new spark plugs & ignition wires.
Silver2000RS is offline   Reply With Quote
need help with ECU/fuse problem eric m. Service & Maintenance 0 01-03-2003 01:45 PM
Need help with HKS wastegate problem rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-22-2002 12:34 PM
Need help with AutoX handling problems . . . z3coupe Brakes, Steering & Suspension 6 03-20-2002 02:57 AM
need help with a headgasket problem. luvmyrs Service & Maintenance 7 02-13-2002 01:19 PM
need help with a question/problem wrxracer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2002 04:52 PM
