Old 07-08-2004, 09:44 AM   #1
wgb113
Member#: 32478
2004 Forester XT
Default Low-pitch "rumble"
Lately I've been hearing a low frequency rumble from what sounds like the rear tires when at slow speeds. An example would be when cruising to a stop (foot off of brakes). It's definitely coming from the rear of the car and is a "revolving" noise (wa-wa-wa-wa-wa) as the wheels turn.
I'm coming up on my 15K service, should I mention it to the dealer or is this just a result of the tires wearing?
Bill
wgb113 is offline   Reply With Quote
Old 07-08-2004, 05:43 PM   #2
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
http://forums.nasioc.com/forums/show...hreadid=371118
this works for most, and worked for me too.
4psi higher in front tires
StarDogChampion is offline   Reply With Quote
Old 07-09-2004, 02:53 AM   #3
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Make sure your lug nuts are torqued as well.
khail19 is offline   Reply With Quote
Old 07-09-2004, 03:03 AM   #4
ripvw
Member#: 27790
check pressures, check lugs, and check the tire(s) in question very carefully - look over the entire surface for any type of wear - be sure to check the inside edges of the tires
assuming all is well, check out this flow chart for more ideas - such as swapping the tire(s) with the front - and definitely tell the service shop about it - soon
http://www.tirerack.com/images/tires/vibechart.pdf
ripvw is offline   Reply With Quote
FS: 04 STi rotors, NGK plugs, Solid pitch mount, AEM, TurboXS *low prices* bObby SCIC Private Classifieds 12 09-23-2009 06:14 PM
Low high-pitched whine when driving? DaNewSube Newbies & FAQs 35 01-17-2007 04:53 PM
Help: Getting a low-pitched vibrato kind of sound on the highway perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-24-2005 07:22 PM
