Old 10-25-2000, 10:28 AM   #1
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post 275 ft*lb!!! (new STi tech data)
Data on the new STi's from Subaru's official page:
All models - 275 ft*lb of torque max at 4400rpm
- signature Subaru torque curve -- power on at 3000rpm, flat all the way through to 5500rpm!
- forged pistons and conrods
- "semi closed deck engine", whatever the heck that means
- larger intercooler with water spray as standard
STi RA = 3087 lb (17" version)
STi Sedan and Wagon = 3153 lb (how can this be? hmmm)
(overall torque/weight ratio -- 8.9 ft versus 9.0 ft for the previous version -- bummer)
STi RA available in 16" and 17" versions -- 17" has "sport tuned" ABS and BIG brakes. 16" is 44lb lighter.
Roof vents standard on RA only. White paint only as before.
Trannies. As you know all STi's have the 6-speed. There is an adjustable shift light feature built into the stock cluster (2000-8000rpm in 100rpm increments) for all you drag racers. And yes, folks, the gears have been beefed up. Note that 6th gear is pretty much identical to 5th gear in the normal version -- therefore, probably VERY buzzy at stateside freeway speeds. Better to wait for an Aussie or UK STi version with a taller 6th gear.
Front skidplate fitted as standard.
Steering ratio 15:1 on all except RA, which gets the same 13:1 quick ratio as before.
Whoo-wee.
Necromancer is offline   Reply With Quote
Old 10-25-2000, 10:46 AM   #2
doripreza
Member#: 574
99 Impreza RS
Post
dope..
i sounds like they upgraded allot of things in the right places.. it doesn't look so bad now does it?
doripreza is offline   Reply With Quote
Old 10-25-2000, 10:46 AM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Man that's a porker of a car. How heavy were the old STi cars?
RidinLow is offline   Reply With Quote
Old 10-25-2000, 10:56 AM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The STi RA was like 2650-2700lb, the regular WRX was 2750-2800lb.
ColinL is offline   Reply With Quote
Old 10-25-2000, 11:13 AM   #5
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Post
ouch that wieght is making me cringe.
that increase in torque should make up for it a little right?
[This message has been edited by SubyRacer (edited October 25, 2000).]
SubyRacer is offline   Reply With Quote
Old 10-25-2000, 11:20 AM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The STi5 and 6 made 260lb-ft. No idea if it was over as broad of a rpm range, but IMO if that weight is right there is no way the car will perform as well as it previously did.
Old 10-25-2000, 05:29 PM   #7
shabby
Member#: 2682
93 Eagle Talon AWD
Post
Rev it to 3000 rpm, drop the clutch... whiplash...
shabby is offline   Reply With Quote
Old 10-25-2000, 05:42 PM   #8
doripreza
Member#: 574
99 Impreza RS
Post
wow.. i love the giant power boost at 3000 its great..
i wonder how the varible valve stuff comes into this.. it doesn't look like its making too big of a difference.. i wonder what there plans are for that?
gino
Old 10-25-2000, 07:59 PM   #9
jImp
Member#: 1741
1999 Impreza 2.5 RS
Rally Blue (Sold)
Post
Sweet, that car is starting to grow on me. This is odd because I hated it at first
jImp is offline   Reply With Quote
Old 10-25-2000, 08:25 PM   #10
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Cool
that engine will one day be inside my '95 2450lb L coupe .
Old 10-25-2000, 11:55 PM   #11
wistful
Member#: 745
2004 STi
Java Black Pearl
Post
this extra fat is the price we pay for a stiffer chassis, which in the end, will hopefully improve the car overall. if it superfluous crap, i'm sure we can pull it out. I'm still hunting for various pieces of insulation lying around that I can take out, like the one between the rear seat and trunk. Hey, hopefully it'll add up in the end, ya know? still cheaper than buying a CF hood.
Don
P.S. No, I do'nt have a fat A$$, so I can't really lose weight there.
wistful is offline   Reply With Quote
Old 10-26-2000, 12:12 AM   #12
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Post
yea, guess 15 lbs more torque with a flatter curve aint gonna make up for 300 more lbs of dead wieght
so what it boils down to is that they ruined its looks and its preformance
they're a bunch of geniuses up there arent they
Old 10-26-2000, 12:14 AM   #13
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Overall I would expect the new STi's to be about as fast as the old ones, based on the torque/weight ratio I posted above. Ironically the thing that would probably slow em down the most in the 1/4 mile would be the 6-speed tranny.
My guess is that the six speed is there simply to achieve feature parity with lesser cars that don't enjoy a flat torque curve (Honda, Toyota). Again, the tallest gear is unchanged, so high speed cruising is not going to be improved. Then again, take an STi RA, tune it for max hp in a narrow range, and suddenly the six-speed looks like a good idea after all...
Old 10-26-2000, 12:18 AM   #14
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Here ya go folks, the sweeeeetest torque curve among turbo 4wd sports cars, bar none.
<IMG SRC=http://www.subaru.co.jp/impreza/sti/technology/img/grfu.gif>
Blue line is the previous model STi. Red line is the new one. Note overall hp has remained the same (yah right). Also note that the "bump" at 3000rpm has been smoothed out somewhat -- as CAR magazine noted in its test drive.
[This message has been edited by Necromancer (edited October 25, 2000).]
Old 10-26-2000, 05:46 AM   #15
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Post
From what Prodrive said, most of the added weight to the new Impreza is as a result of the more refined interior. They said the shell is almost the same weight as the old one. Sooo.... Out goes the interior, down goes the weight...
Marquis is offline   Reply With Quote
(4) 275-40-17 Avon Tech M500 tires.....like new, cheap! impreza2 Wheels/Tires 3 01-15-2010 12:41 AM
Brand new H-tech tien springs for 05 sti takumi Tri-State Area Private Classifieds 0 02-10-2009 03:25 PM
Excellent New Brake Tech Article GarySheehan Brakes, Steering & Suspension 18 02-17-2004 01:45 PM
Ct: Brand new G-Tech Competition Pro Meter BlackWRX Private 'For Sale' Classifieds 0 10-21-2003 09:57 AM
New G-Tech 0-60 time for the auto WRX! G-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-05-2002 09:40 AM
