Old 10-24-2000, 05:05 PM   #1
DarkLite
Member#: 2005
98 Vw Jetta VR-Sex
Cool White...
Question Will this turbo work with a 2.5rs ?!!!HELP PLEASE
http://cgi.ebay.com/ebaymotors/aw-cg...080258&r=0&t=0
if so i am buying it and dont even think about bidding on it ne of u....
i will then get it rebuilt....and purchase all of the pieces one at a time..to make a turbo kit for the impreza...
thanx
please help
DarkLite
DarkLite is offline   Reply With Quote
Old 10-24-2000, 05:13 PM   #2
Tim Prudence
Member#: 216
Talking
haha, I just bid on it
Seriously though, what do you mean, will it work? Can it work? Yes. Will it work? Depends on what you are planning to do with it. The auction isn't over for 8 more days. Go find a copy of Maximum Boost by Corky Bell and read about how to design and implement a custom turbo system.
Tim Prudence is offline   Reply With Quote
Old 10-24-2000, 05:17 PM   #3
tulit
Member#: 338
09 STi
Post
i guess we'll have to duke it out Tim
But true, im not sure what you mean by will it work? Of course it will. But do you have the means to custom build a turbo kit?
If your looking for a straight bolt-on, this definately wont work
tulit is offline   Reply With Quote
Old 10-24-2000, 05:23 PM   #4
DarkLite
Member#: 2005
98 Vw Jetta VR-Sex
Cool White...
Question
So which turbo is recommended to put on the 2.5rs?
i want something that spools very fast and boost starts very early....?
IHI
T28
T3
Super 60
T3/T04
help which one??
thanx
BTW please explain all
Old 10-24-2000, 07:59 PM   #5
Dynobyte
Member#: 1636
1994 94L->RHD V5 STi
Grigio Silverstone
Post
the aerodyne turbo is supposed to be good yes? its used by that post-minnam turbo company...
Dynobyte is offline   Reply With Quote
Old 10-24-2000, 08:10 PM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Conceptually, absolutely. Very low lag.
They are simply unreliable, to be polite. Search around on the Miataforum in their Power Mods forum.
ColinL is offline   Reply With Quote
Old 10-24-2000, 08:18 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
A T3 is a good tize turbo. Maybe a touch big for low boost.
Eric
Eric SS is offline   Reply With Quote
Old 10-24-2000, 10:03 PM   #8
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Hmmm...
Everyone BUT Darklite are bidding on this one
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 10-25-2000, 01:39 AM   #9
delectron
Member#: 227
Post
T3 super 60 is the best for around 7-8 intercooled psi with the stock redline.
delectron is offline   Reply With Quote
Old 10-25-2000, 05:15 AM   #10
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
ColinL
I thought the aerodyne turbo is reliable if you use the right size for the boost lev. you want to run.. I have heard Thay run into reliablity iss. if you overboost them? But if you have a boost control sys. to protect from over boost and do not turn up the boost over what is recmded they would be fine? This is more of a qustn. than a statment.
Liquid Calm is offline   Reply With Quote
Old 10-25-2000, 09:30 AM   #11
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post
make sure ya'll get the proper housings and gaskets for it, it may be a biyatch if you don't
-matt
kid22 is offline   Reply With Quote
Old 10-25-2000, 09:38 AM   #12
Tim Prudence
Member#: 216
Post
Liquid Calm,
That is true, however, aerodynes simply just explode at the first sign of danger. Even with perfect boost control, if you spring a small intake leak, they will overrev and blow. I've had a hose pop completely off one of my intercooler pipes before, and have sprung numerous leaks (think I need to get turbo specific hose clamps). If I had an aerodyne, it would have died a long time ago.
Tim
Old 10-25-2000, 10:04 AM   #13
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
Tim,
I PMed you
Old 10-25-2000, 10:21 AM   #14
wrxman555
Member#: 2677
2001 Lexus IS300
Post
There is a guy in my town that supposidly has a Twin Turbo RX-7 set up in his 98RS and he claims to be running the 1/4 Mile in the low 10's. Is it even possible to build a set up like that? If so, I might be interested.
wrxman555 is offline   Reply With Quote
Old 10-26-2000, 05:35 AM   #15
Ch˙SacSVT
First RS in the 12's YEEEEEEEEEHA!
Member#: 129
'03 Corvette Z06
Black as in:180mph Black!
Talking
Hello guys!!!
DarkLite - I'm using a Ballbearing T28. It's a good size turbo for this car, not too big nor too small, all depends on what you are looking for. If you like AutoX and an ocassional drag race, this is the one for you. Lag? What's that? (full boost @ 2300/10-12psi).
Delectron & Imprezinator - Both of you are right!! The T3/Super 60 hybrid is the best turbo for the RS. It won't spool as quick as the T28, but it will keep producing power up to the stock redline. BUT......don't use it for 8psi. This hybrid id better suited for 10-12psi, with the proper fuel management (S-AFC, pump, etc) you won't have any problems.
If you want to see my car, there's a topic on this board's section named: "Turbo RS Pics" from Oct. 19, 2000, check it out & let me know what you think....
PEACE!!!!
Ch˙SacSVT is offline   Reply With Quote
Will this CPU work with this Board? Thugthizzle Off-Topic 8 03-26-2010 02:05 PM
Will this amplifier work with this speaker/sub combo? PaulCharles Car Audio, Video & Security 1 07-30-2007 02:44 AM
Will this amp work with this sub? sandiegowrx Car Audio, Video & Security 10 08-17-2005 02:53 AM
Will this amp work with a 12" sub? pjdwrx Car Audio, Video & Security 12 03-05-2004 04:48 PM
Will this turbo work? Ippon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-10-2003 12:11 PM
