Old 07-08-2004, 09:59 AM   #1
WRXVII
Member#: 15854
VF34'd...
Default new wheel bearings
Seems like my car needs new wheel bearings... for those who have replaced wheel bearings on WRX, how much did it cost?
WRXVII is offline   Reply With Quote
Old 07-08-2004, 11:40 PM   #2
abaxter34
Member#: 34723
fwd FTL!
wheel bearing+2 bearing seals+axle nut= $130
this was for only one wheel
abaxter34 is offline   Reply With Quote
Old 07-08-2004, 11:45 PM   #3
dorifto88
Member#: 17684
1989 pathfinder
rusted red
a local shop got me a slightly used one for i think 50 dollars?
dorifto88 is offline   Reply With Quote
Old 07-09-2004, 12:03 AM   #4
abaxter34
Member#: 34723
fwd FTL!
you might actually be able to get some slightly used wheel knuckles at a wrecking yard with good bearings in them for less than a new bearing replacement. all youd have to do is disconnect the bottom of your strut and ball joint, take off the axle nut and then remove the whole knuckle assembly, and replace it with the new knuckle. a wrecking yard quoted me $90 for a whole knuckle until we found out the bearing was bad. this would also cut out the cost of having a shop take out and press in the new bearings and seals.
Old 07-11-2004, 08:23 AM   #5
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
Dealer charges $700+. I know that seams steep but all of the Detroit area dealers gave me the same price. If you buy the parts separate the tricky thing is setting the bearing into the hub. Dealers have a tool to do this or something. The local shop that replaced the first wheel bearing for me didn't do it right and I ended up wasting $500 cuz I had to have the dealer install one three months latter. If you get a new one repack the grease with a better quality one.
DetroitWRX is offline   Reply With Quote
san jose - place to get new wheel bearing pressed in? spitfirezip100 Brakes, Steering & Suspension 1 06-19-2006 11:03 PM
new wheel bearing = faster wagon chahny Legacy Forum 3 03-26-2004 07:07 PM
Yahhhhhhhh...new wheel bearing... Scooby South South East Region Forum 6 12-23-2003 11:05 AM
('93-'01) How can I test to see if I need new wheel bearings 2.5rsMI Impreza Forum 2 05-28-2001 06:35 PM
New wheel bearing and hub: what cost? SFsube Technical Forum Archive 3 07-14-2000 09:28 AM
