Old 10-24-2000, 09:12 AM   #1
Jonathan Kent
Guest
Member#:
Question changing octane and ECU reset
Hey folks. Can someone please clarify as to whether or not an ECU reset is necessary after changing gas octanes? I've always used 93 in my 99RS. However, this past weekend, I filled my empty tank with 87 for the first time. I didn't notice any changes (power, mileage, etc.)
So, to ECU, or not to ECU?
Thanks,
J. Kent
Old 10-24-2000, 02:00 PM   #2
cakagan
Member#: 251
1998 Impreza 2.5 RS
Post
I'm not sure how long it takes the engine to notice the lower octane, but I've heard that it takes 3 tankfuls of a higher octane for the ECU to adjust.
I would only reset it when you go to a higher octane than 87. Why the change?
-Chris
cakagan is offline   Reply With Quote
Old 10-24-2000, 02:47 PM   #3
sasim
Member#: 2659
Smile
The ECU should adjust to the lower octane quite quickly on a MY99, a reset should not be required.
The whole ECU reset is a subject of great debate here in the UK, but my simple understanding is that MY98 models or later should never need a reset, not sure about pre MY98 ones......hmmmmmmmm
SS
sasim is offline   Reply With Quote
Old 10-24-2000, 03:10 PM   #4
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
$$$ is why'd i'd change too...
silverSurfer is offline   Reply With Quote
Old 10-24-2000, 04:56 PM   #5
Catfish
Member#: 1322
2000 2.5RS Sedan
72 Datsun 240Z
Post
In case you don't already know....
You don't need high octane gas unless you are experiencing detonation. Just fill it up with the minimum octane required by the manufacturer and live happy. As you do mods to your car, upgrade to the next octane if you detect any knocking. Most mods outside of cams or forced induction will not require an increase in octane. To use the highest octane available just because that's what all the "sports cars" use is a waste of $$$ and gas mileage. You'll actually get better gas mileage with the least octane. Higher octane fuels are less prone to detonation because they are more difficult to burn. Being more difficult to burn means they burn slower and also are more difficult to ignite by your ignition system. So, unless your car was designed or has been modified in such a way to warrant the higher octane, stick with what works and enjoy the savings.
Dave
'00 Subaru 2.5RS Sedan
'00 VW Passat GLS 4Motion
'72 Datsun 240Z
Catfish is offline   Reply With Quote
Old 10-24-2000, 05:01 PM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Flame speed is not related to octane.
You can trust me on that or you can read a very informative post here: http://www.i-club.com/ubb-files/Foru...ML/003898.html
In it you will also learn that engines can require considerably different octanes depending on wear, atmospheric and local conditions, and manufacturing tolerances. It is by no means unreasonable to think that some 2.5RS will require 91 octane or above to attain nominal performance, and others will require less than 87.
[This message has been edited by ColinL (edited October 24, 2000).]
ColinL is offline   Reply With Quote
Old 10-24-2000, 10:05 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
ColinL,
Don't you know that nobody ever reads that post? Except me...
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 10-25-2000, 07:19 AM   #8
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
WOW that was a long post.....but some stuff I did not know in there
Liquid Calm is offline   Reply With Quote
Old 10-25-2000, 10:12 AM   #9
Gambit
Member#: 102
Post
Bah that post is like Colin's Tne Commandments tablets.
Gambit is offline   Reply With Quote
Old 10-25-2000, 11:58 AM   #10
BongMan
Member#: 2399
2001 Impreza RS
Thumbs up
That post was crazy long.
Lawrence
MY01 BRP Sedan
BongMan is offline   Reply With Quote
Old 10-25-2000, 09:09 PM   #11
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Post
I get improved mpg with 92 octane vs. 87 or 89 with my EJ22. Enough to make the added $ worth it.
Ken Levin is offline   Reply With Quote
p0031 and misfires after a brand new front o2 sensor and ecu reset 1gcrazy Newbies & FAQs 25 09-26-2008 12:17 PM
GanzFlow aftermath and ECU reset question heatseeka Normally Aspirated Powertrain 16 06-19-2001 02:21 PM
Intercoolers and ECU Resets Kevin Thomas Normally Aspirated Powertrain 2 03-09-2001 09:55 PM
AFC and ECU reset Spectre23 Normally Aspirated Powertrain 0 03-03-2001 10:06 AM
Went to 89 octane during ECU reset.. is it okay? Jason52 General Forum Archive 1 12-21-2000 01:08 PM
