Old 10-25-2000, 02:07 PM   #1
KITTbri
Member#: 2748
1992 WHT SE-Rw/stuff
2.5RS & '01 Mazda MP3
Angry AT won't hit redline
I have a MY99 that won't pull to redline. It shifts at about 5950 in 1, 6000 in 2nd, and it looks like it will in 3rd. haven't redlined 4th yet though, not enough straight road around w/out cops.
I was wondering if anyone else had this problem and what I can do about it. I installed a K&N and did an ECU reset and it still happens. Any help on this?
KITTbri is offline   Reply With Quote
Old 10-25-2000, 02:10 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Post
Anyone can correct me if I'm wrong, but I believe that peak HP and Torque come BELOW the redline, somewhere around 5500 rpm? the torque and hp numbers actually DROP off after that, so your AT shift points are pretty well matched to the engine.
Old 10-25-2000, 02:17 PM   #3
KITTbri
Member#: 2748
Post
that would be explainable. i guess if you look at the hp/tourque curve that is true.
jsut don't want my subie underacheiving.
Old 10-25-2000, 02:41 PM   #4
KITTbri
Member#: 2748
Exclamation
how did you manage that??
[This message has been edited by AutoBri (edited October 25, 2000).]
Old 10-25-2000, 03:04 PM   #5
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
Post
Mine shifts past 6k every time when I want it to. Shifts right b4 it touches the redline on the tach. Have you tried pushing the gas pedal all the way to the ground? Or if you r crazy enough u can shift it manually
-Daios
MY00 BRP SeDan
Daios is offline   Reply With Quote
Old 10-25-2000, 03:17 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
mine "reds" just fine...
even after the new engine
i'll have to check & see exactly where it shifts... mmmm... never really bothered to check...
would be interesting to compare as i have "the bigger car"
Old 10-25-2000, 03:54 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
cracked #2 cylinder... car overheated 1 time... this is typical of the 98 RS' and the 99 GT's - the Phase I DOHC engine... it's crap!
all repaired under warranty...
and all seems to be ok at this point...
i'll keep ya posted...
Old 10-25-2000, 07:10 PM   #8
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
I've heard that there is some variation in the rev-limiter setting in the manual cars. Some of them bounce off the rev-limiter before it actually gets to redline. I would venture to guess that the same could be said for shift points in the autos.
It would be interesting if you could find someone with a similar model and swap out ECU's (or would it be the TCU for the tranny) just to see what it does.
Rich
richeich is offline   Reply With Quote
Old 10-25-2000, 07:13 PM   #9
inzomniak
Member#: 953
Cool
I redline my car every 2000kms I can hit 6300-6500 on third... but of course the car shakes like something is going to happen , maybe I shouldn't do that too much heh...
inzomniak is offline   Reply With Quote
Old 10-25-2000, 07:48 PM   #10
Andy_T
Member#: 502
Post
I found the floor mat actually gets in the way of the throttle pedal stopper on the floor if it shifts around beneath your feet, and prevents you from reaching full gas (actually my g/f noticed that the pedal hit the "carpet" instead of the hard plastic stop when she was trying to overtake a truck - the car shifted earlier than expected and lost crucial momentum for a second or two).
With the carpet out of the way and the pedal on the floor stop, it should shift right around the redline (practically all modern autos do). But you should hear a definite "click" rather than a "thump" when you stomp on the gas.
Andy_T is offline   Reply With Quote
Car Won't Hit Boost at All!! JohnnyWas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-14-2005 06:53 PM
Hitting redline CFX Transmission (AT/MT) & Driveline 5 12-13-2002 02:35 PM
Hitting Redline CFX Newbies & FAQs 6 12-11-2002 11:22 PM
hitting redline.. CEL light? imprezey Newbies & FAQs 10 08-10-2002 04:51 PM
hitting redline! Ragstylz Technical Forum Archive 13 06-28-2000 10:23 PM
