Old 07-08-2004, 05:27 PM   #1
AWD2.5
Member#: 43273
2.5 impreza
BRP
Question hub-centric spacers???
i just purchased some Rota Formels for my 01' impreza and a buddy of mine told me i should have hub-centric spacers before i put them on. I've called around to different performance shops and basically half of them said i need them and half said it's not nessary. has any one had any issues without using them or are the rota wheel made to fit directly up to the hub???
Any info would be a great help.
-Charlie-
AWD2.5 is offline   Reply With Quote
Old 07-09-2004, 02:57 AM   #2
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
All the newer Rotas made for Subaru fitments are hub-centric, meaning the size of the hole in the wheel fits tightly on the hub of your car. You don't need hub rings, even if you had them you couldn't use them anyways. Most aftermarket wheels are designed to fit a variety of cars, so the center bore is drilled bigger and they send you hub rings to fit your application.
khail19 is offline   Reply With Quote
WTB: Custom 5mm 5x114 hub & wheel centric spacers & studs Crashed_Again Private 'Wanted' Classifieds 0 04-14-2010 09:35 AM
FS: 10mm Hub centric Spacers with 10 long wheel studs. 5X114.3 MarcsRX Wheels/Tires 3 12-30-2008 03:23 PM
CA: Bolt on hub centric 5X114.3 wheel spacers SonnyCrockett04 Suspension/Brakes/Handling 3 08-26-2008 02:45 AM
front wheel spacers available that keep hub-centric?? WRXINTX Brakes, Steering & Suspension 14 02-19-2007 11:48 PM
Hub centric wheel spacers renhoek Brakes, Steering & Suspension 11 02-22-2006 08:39 PM
