Old 10-17-2000, 02:25 PM   #1
Gerry
Member#: 1829
Question Anyone use adjustable cam gears?
Just wondering if any of you guyts are using adjustable cam gears? And if so any benefits?
Thanks Gerry
Gerry is offline   Reply With Quote
Old 10-17-2000, 07:42 PM   #2
Turk
Member#: 1888
Post
I don't believe anyone makes adjustable cam gears for are cars yet. Hint Hint, Nudge Nudge, Wink Wink... cobb tuning... psst Trey I think someone is trying to tell you something
Turk http://www.clubimpreza.com
Turk is offline   Reply With Quote
Old 10-17-2000, 07:48 PM   #3
Member#: 67
1999 Outlasting
the competition.
Post
Byron at Bspec has them
Old 10-18-2000, 03:22 AM   #4
S.Damery
Member#: 1770
Post
From what I understand if you have a DOHC engine you can tweak the cam timing to improve the HP and Torque across the RPM range. Unfortunately with SOHC, (i.e. all the newer Subies) all you can really do is shift the powerband up or down a bit.
-Shawn
S.Damery is offline   Reply With Quote
Old 10-24-2000, 09:52 PM   #5
subywuby
Member#: 2333
Question
Can you give me a link for Byron at Bspec?
subywuby is offline   Reply With Quote
Old 10-25-2000, 06:08 AM   #6
Turk
Member#: 1888
Post
Old 10-25-2000, 07:52 AM   #7
legacyGT00
Member#: 2052
Post
With the DOHC you can adjust the valve timing by adjusting or retarding the cams using cam gears. You've basically got one cam for intakes and one came for exhaust. With a SOHC, you've got to get a cam that is ground differently. Cobb Tuning has some. You could probably also find a local engine shop that would grind the cams for you.
legacyGT00 is offline   Reply With Quote
Old 10-25-2000, 03:07 PM   #8
WRXGirl
Member#: 881
2004 WRX
Grey
Post
Unorothodox is making them. They are due out in the spring.
WRXGirl is offline   Reply With Quote
Adjustable cam gears anybody using them? Forester_007 Normally Aspirated Powertrain 2 05-01-2008 11:37 AM
Adjustable cam gears for DOHC? Tangmere Normally Aspirated Powertrain 4 01-07-2002 10:52 AM
Adjustable Cam gears for SOHC Jaxx Normally Aspirated Powertrain 12 09-15-2001 05:01 PM
Adjustable Cam Gears survey WRXGirl General Forum Archive 4 09-12-2000 07:39 PM
Subaru adjustable cam gears??!! Kyle Paton Technical Forum Archive 16 07-13-2000 12:52 AM
