Old 10-22-2000, 11:28 PM   #1
byb555
Member#: 2201
Unhappy 4.444 Limited slip diff
I have been searching for a 4.444 LSD for my Liberty/Legacy project for quite a while now but to no avail. Any info on where to look would be appreciated.
Sorry if this post is not in the right classification area.
<HTML>
<HEAD>
<BODY TEXT="#ffff00" LINK="#ffff00" VLINK="#00ff00" BGCOLOR="#000000">
RX TURBO = 1800cc of turbo charged whoop ass!!
<TABLE BORDER CELLSPACING=3 BORDERCOLOR="#00ff00" CELLPADDING=7 WIDTH=377>
<TR><TD WIDTH="33%" VALIGN="TOP" HEIGHT=14>
<P ALIGN="CENTER"><A HREF="http://web.one.net.au/~bybsubi/index.htm"><FONT FACE="Comic Sans MS">HOME PAGE</FONT></A></TD>
<P ALIGN="CENTER"><A HREF="mailto:[email protected]"><FONT FACE="Comic Sans MS">E-MAIL ME</FONT></A></TD>
<U><FONT FACE="Comic Sans MS" SIZE=2><P ALIGN="CENTER">ICQ 54651488</U></FONT></TD>
</TR>
</TABLE>
</BODY>
</HTML>
byb555 is offline   Reply With Quote
Old 10-23-2000, 07:21 AM   #2
XT6Wagon
Member#: 524
04 STi
Post
Use a 3.90 LSD, but change out the pinion for the one from a 4.11 or 4.44. Or go all out and put a 3.70LSD in a 3.90 ring gear with the 4.11/4.44 pinion.
Subaru only makes 2 ring gears, and two pinions, so you have to mix and match to get the 4 ratios Subaru uses. 3.70,3.90,4.11, and 4.44.
XT6Wagon is offline   Reply With Quote
Old 10-23-2000, 03:00 PM   #3
byb555
Member#: 2201
Post
Very interesting about the gear sets that are used.
I know where there is a 4.444 open centre that I have been thinking about getting and doing the limo swap thing. I was just hoping to find a 4.444 set up, as the whole system will be newer than picking up a 3.700 out of an RX or something like that.
Old 10-24-2000, 09:12 PM   #4
Kikos Fonseca
Member#: 1765
2000 WRX
Lightbulb
LSD is one thing and can be fitted to any ratio you choose, front (or) and rear.
Diff combos are apart and YES you can find the 4.44 combo for front and rear to be fitted with or without LSD. Anyway I do stock the 4.44 set if you want it(dont have the LSD though).
KIKOS
Kikos Fonseca is offline   Reply With Quote
Old 10-24-2000, 09:21 PM   #5
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'11 X5 xDrive35i
'09 135i 6MT/'15 GTI 6MT
Post
Where can a 3.90 LSD be found?
-Geoff
Geoff is offline   Reply With Quote
Old 10-25-2000, 11:48 AM   #6
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
Sorry to sound ignorant, but what do those numbers mean?
mrbell is offline   Reply With Quote
Old 10-25-2000, 02:42 PM   #7
byb555
Member#: 2201
Post
8Complex, no worries about the signature. I am new to the board and willing to conform to the way you do things.
Brett
Old 10-26-2000, 12:04 AM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Geoff, look at the transmission links here-- tells you what JDM models had what: http://www.i-club.com/ubb-files/Foru...ML/000125.html
mrbell-- 4.444 = 4.44:1 ratio, which means the input shaft turns more than 4 times per turn of the output shaft. This means that there is more torque multiplication (acceleration and towing potential) but less speed potential than a 3.90:1 gear. Of course, that's overly simplified because the gear ratios of the transmission and the powerband of the engine matter too.
ColinL is offline   Reply With Quote
Old 10-26-2000, 12:17 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
byb555 - Please don't use that as your signature... it is too large and bulky. Just make 3 links with - seperators if you must.
Viscous limited-slip diff. question SubaruImpreza_power Transmission (AT/MT) & Driveline 6 05-28-2002 01:53 PM
installing a limited slip diff, how hard? okamikatekore Transmission (AT/MT) & Driveline 3 04-09-2002 07:26 AM
Front limited slip diff??? wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-28-2001 01:35 PM
('93-'01) Stock rear limited slip diff. brandon Impreza Forum 14 06-10-2001 09:28 AM
limited-slip diff confusion Benjamin Tang Legacy Forum 22 05-08-2001 12:52 AM
