Old 07-08-2004, 06:12 PM   #1
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Cool PICS of my new oil cooler
mrubino83 is offline   Reply With Quote
Old 07-08-2004, 06:14 PM   #2
gusto
Member#: 58323
looks great (paint over the bline stuff)
gusto is offline   Reply With Quote
Old 07-08-2004, 06:30 PM   #3
BlueDemon
Member#: 10173
2005 WRX STi
Default Re: PICS of my new oil cooler
Originally posted by mrubino83
Dropped oil temps by almost 40 degrees. Let me know what you think. Thanks. -Mike-
http://www.imagestation.com/mypictur...3&from_album=1
OOOO OOOOO OOOOOOO! Please send some info on where to purchase this kit, and/or sites where to source so I can build myself!
Thank you. Been looking to do this for quite some time, but no idea which core works with the WRX and fittings and such work with the WRX.
BlueDemon is offline   Reply With Quote
Old 07-08-2004, 07:02 PM   #4
driggity
Member#: 7453
2005 Legacy GT Wagon
2006 LJ Rubicon
Very nice. And yes, please post the parts that you used.
driggity is offline   Reply With Quote
Old 07-08-2004, 07:10 PM   #5
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
Sweet Setup Dude....please post those parts you used!
Scoobs2002 is offline   Reply With Quote
Old 07-08-2004, 07:49 PM   #6
norseone
Member#: 16350
B7 S4 Avant
Do you have a thermostat with that setup?
norseone is offline   Reply With Quote
Old 07-08-2004, 07:56 PM   #7
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
How far down does that cooler go below the bumper? I want an oil cooler but I have a DR500 FMIC and its flush against the bottom of that bumper.. Also.. can you link to where you purchased the kit and the price.
Thanks
Clark
AZScoobie is offline   Reply With Quote
Old 07-08-2004, 08:02 PM   #8
CyC
Member#: 23499
2006 Saabaru
bump for parts list
CyC is offline   Reply With Quote
Old 07-08-2004, 08:10 PM   #9
cronic
Member#: 9749
Thanks
Clark
Yea that is my problem Clark.. I wanted to get the STI one that is on the s202 but its not going to happen unless i mount it in an alternate location.. I doubt i will spend the money on that one but this one looks interesting.. Can you get it without their name sprayed on it?
cronic is online now   Reply With Quote
Old 07-08-2004, 08:17 PM   #10
norseone
Member#: 16350
B7 S4 Avant
You can mount it behind the grille man just like mrubino's is.
It does not have to go where our FMIC is.
Old 07-08-2004, 08:23 PM   #11
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Where does that T into? Did you use like a sandwich plate on the filter/standard cooler area?
-Mike
MJU1983 is offline   Reply With Quote
Old 07-08-2004, 09:25 PM   #12
tdxflex
Member#: 13634
Do you have rubber washers where you mounted the cooler? It would help dampen vibrations to the core.
Cooler dimensions you can find just about any configuration, some are more expensive than others though. Just for a starting point:
www.bakerprecision.com has a ton of different Setrab coolers
www.batinc.net has a ton of Mocal adapters and coolers
www.racerpartswholesale.com has the best price on Aeroquip AQP hose, and some Mocal adapters
tdxflex is offline   Reply With Quote
Old 07-08-2004, 09:40 PM   #13
oldmansan
Member#: 17877
Midnight Pearl
Default Setrab
for me, and I'll mount behind the grill (FMIC). Looks good!
San
oldmansan is offline   Reply With Quote
Old 07-08-2004, 09:54 PM   #14
norseone
Member#: 16350
B7 S4 Avant
HKS and Trust make nice ones. So do Prova and Zero/Sports!
The HKS and trust ones go for $900. Prova and Zero/Sports are like $1200+. All cheaper than the STi one.
FWIW
Old 07-09-2004, 04:05 AM   #15
mrubino83
Member#: 22987
True you can find a lot of differant cores available. This one uses a Setrab core
Old 07-09-2004, 04:17 AM   #16
mrubino83
Member#: 22987
Yeah you can get the cooler w/o the name painted on, and yes,uses a sandwhich plate adaptor between the filter. I bought it from B-Line motorsports. Heres the email address and phone#...
blinemotorsports@sbcglobal.net
310-519-9126
Old 07-09-2004, 10:08 AM   #17
vile
Member#: 32371
'02 t-rex wagon
platinum
Thanks
Clark
hey clark, here's how i have mine set up, it might clear your fmic.
it's only two row, but is very long, pretty much end to end of the grill, here's a pic, if you look closely behind the grill, you can see the second row sits pretty high up
if that doesn't work, use this link, it's the fourth pic
http://community.webshots.com/album/139243245hqgPxI
vile is offline   Reply With Quote
Old 07-09-2004, 12:43 PM   #18
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Vile.. cant find that pic man.
C
Old 07-09-2004, 01:23 PM   #19
vile
Member#: 32371
'02 t-rex wagon
platinum
or link
http://www.imagestation.com/mypictur...7&from_album=1
or link
http://www.imagestation.com/picture/...c/fb6c1d9d.jpg
hope one of those works
if not, it's essentially a two row oil cooler made by perma-cool. the rest of the system, i pieced together. the bottom goes as low as where the grill meets the bumper, so hopefully, that should clear your fmic
Old 07-09-2004, 01:38 PM   #20
AK'S REX
Member#: 12163
FWIW
Whoever pays over $1000 for an oil cooler is crazy!! Those cores at most are a few hundred, at most. The fittings are the most expensive part, you'll probably drop a few hundred on lines and fittings. At most I could see spending $500 or so for a good setup.
Check your local domestic hotrod shop for lines and fittings, there usually much cheaper than those prices online. A hydraulic shop carries this stuff too, one near me sells XRP for half of what the aeroquip stuff costs, its the same thing.
You said it dropped temps by 40 degrees? What is it running at now? You dont want oil too cool. Nice setup though, are u using a thermostat to bring it up to temp faster? Did you retain the factory cooler as well?
-AK
AK'S REX is offline   Reply With Quote
Old 07-09-2004, 02:29 PM   #21
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
looks good Vile.. can see it now.. That would probably clear the FMIC.. Where did you get the core?
C
Old 07-09-2004, 02:32 PM   #22
mrubino83
Member#: 22987
No Im not using a thermostat. Should I be? and Bline said that I can run a front mount with this oil cooler if I wanted.
Old 07-09-2004, 03:59 PM   #23
norseone
Member#: 16350
B7 S4 Avant
Yes you should be using a thermostat.
Old 07-09-2004, 04:12 PM   #24
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Not in so cal... No point what so ever in my opinion.
C
Old 07-09-2004, 04:50 PM   #25
norseone
Member#: 16350
B7 S4 Avant
How about at the north pole?
Finnally got my new rims on the GC and a pic of my new project Car for next year bstoehr83 Member's Car Gallery 25 04-13-2010 07:57 PM
pics of my new sti...with pics that work this time 1quiksoob Member's Car Gallery 8 09-03-2003 11:15 AM
Poor pic of my new 18" Advans and my Friends Protege 5 adamsrs Member's Car Gallery 37 03-09-2002 02:18 AM
('93-'01) new pics of my new REX -=] (pic sorta large) ^jynx^ Impreza Forum 0 07-04-2001 09:52 PM
new PIC of my new grill and vents tonyb New England Impreza Club Forum -- NESIC 4 03-15-2001 04:29 PM
Message Board Statistics All times are GMT -4. The time now is 06:19 PM.
