Old 07-08-2004, 08:39 PM   #1
Xzinum
Member#: 50987
Default how important is the postion of a compressor?
turbos usually sit vertically like so:
Exhaust || Compressor
i was wondering if you could put the compressor upside down like so:
Exhaust
compressor
will that affect lubrication?
what are the advantages/disadvantages to this setup?
Xzinum is offline   Reply With Quote
Old 07-08-2004, 09:03 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
good luck
supposedly rx7s r like that but i think it might mess up lubrication
especially if u listen to all of those who say if theres ANY restriction in the oil line the turbo will blow oil
Old 07-08-2004, 10:37 PM   #3
kaos200
Member#: 2692
definitely not a good idea, I forget the numbers but iirc its something like anywhere from 15* off horizontal is ok (either way), but any more is bad.
It could be more than 15* but it wasnt that much.
kaos200 is offline   Reply With Quote
Old 07-09-2004, 12:53 AM   #4
Do_It_Sidewayz
Member#: 24372
it's easy
Just un do the bolts that clamp on the exhaust housing, and "clock" the turbo.
you always want the oil drain pointing down
Do_It_Sidewayz is offline   Reply With Quote
Old 07-09-2004, 06:07 AM   #5
imprezaGDA
Member#: 15725
02 KandyApple
DoLuck REX
do_it_sidewayz, he is talking about the whole turbo, not where the outlet points
imprezaGDA is offline   Reply With Quote
Old 07-09-2004, 12:27 PM   #6
Xzinum
Member#: 50987
Thanks for the info guys
Old 07-09-2004, 09:04 PM   #7
steak
Member#: 38981
wont necessarily cause problems, but i dont know first hand. ive SEEN however, a 3SGTE turbo setup with the compressor on top of the manifold and the exhaust below with the external dump welded into the exhasut housing, it was pretty sick. doesnt have any effect on cooling (oil and coolant) as long as the return line back to the pan has as MINIMAL amounts of bends as possible, and of course the drain line is bigger than the feed. its pressurized with oil (50-80psi, or what have you) when the motor is on, so its really about the flow back to the pan is what you'd be most worried about. you dont want oil coking up in the bearing housing. thats a bust.
good luck
steak is offline   Reply With Quote
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
How important is the primer on the Goped? twinbrd Off-Topic 8 05-15-2009 11:37 AM
How important is the vacuum line behind the intake manifold? KAX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-22-2008 10:49 PM
How important is the turbo inlet hose w/ a Stage 4? portlandwrx1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 06-16-2003 09:42 PM
How Important is the Tech 2 Crank Trigger MY99 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 05-03-2001 06:16 AM
