Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 07-09-2004, 01:18 AM   #1
Kaishi
Member#: 25521
2005 WRX Wagon
World Rally Blue
Default SSR comps vs Rota Attack
I'm looking for a new set of tires/wheels for my WRX wagon.
I've decided on 215/45/17 tires (closest ratio to stock that will fit on a wagon).
Now I need some wheels.
I'm stuck between getting SSR comps or some rota attacks. My question is, will the ~4lbs per wheel difference between the rotas and SSR comps make a big difference?
If so, will this difference be worth the price of the SSR comps (just over 2x the price of rotas)?
Also, should i go with a 17x7 or 17x7.5 for those tires?
Kaishi is offline   Reply With Quote
Old 07-09-2004, 01:22 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
IIRC, every 1lb of unsprung weight is like 50lbs of weight from the car. So a difference of 4lbs per wheel adds up. Also, if you go with the SSR's I believe you can only get them in a 17x7.5" size. I run these on my sedan and couldn't be happier. They're expensive and I did consider the Rota's, but in the end, the weight differential led me to the SSR's.
Calvin
cnk is offline   Reply With Quote
Old 07-09-2004, 01:24 AM   #3
Kaishi
Member#: 25521
2005 WRX Wagon
World Rally Blue
Wink
Awesome, thats what I was thinking too.
Now I just have to find a way to sneak 4 wheels past my wife.
Old 07-09-2004, 01:49 AM   #4
ripvw
Member#: 27790
Originally posted by cnk
IIRC, every 1lb of unsprung weight is like 50lbs of weight from the car. So a difference of 4lbs per wheel adds up...
yes, if true it would add up to the equivalent of 4 x 4 x 50 = 800 lbs of dead weight from the car just by getting some lighter wheels
no offense, Calvin, but I think your numbers are a little on the high side
whatever the real numbers are, it's still better to have lighter wheels. I own the Attacks, but I lust after the SSR's. If you can afford them - go for it.
ripvw is offline   Reply With Quote
Old 07-09-2004, 02:35 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I noticed the difference when I put tires that are 3 pounds, each, heavier on my car.
....and I love my SSR's
Old 07-09-2004, 08:46 AM   #6
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
The SSRs have a better Subaru offset. 50 if I remember right.
You should be able to run 225 on a wagon with that setup.
Go for the 7.5 in wide wheel.
There are many people who run 225 on wagons using rota wheels with the 48 offset with no problems. On the other hand, there are a few who have minor rubbing with that size tire. I always err on the side of caution and I run the 215 on my Attacks.
The extra 2mm should protect you from rubbing. I someday want the SSR Comps with 225. $$$$ is the only thing holding me back.
dbrier is offline   Reply With Quote
Old 07-09-2004, 09:29 AM   #7
robbswrx
Member#: 38975
2004 WRX Wagon
WR Blue
I run SSR's on my o4 wagon w/ Kuhmo 712 225's with no rubbing
what so ever, I highly recommend them! BTW i also live in
eastern PA where they spend squat on reoad repair, very strong
wheel too
robb
robbswrx is offline   Reply With Quote
Old 07-09-2004, 09:54 AM   #8
Chuck H
Member#: 20442
KTR tuned 2003 WRX
VF34 equipped, 270 whp
I have a sedan, not a wagon, but I have the SSR's as well. I couldn't believe the difference between them and the stockers. You can definitely feel the difference in wheel weight, especially on launching.
Chuck H is offline   Reply With Quote
Old 07-09-2004, 10:01 AM   #9
cnk
Member#: 10757
Did a quick search. . .there's a lot of controversy over the real ratio. Seems that some have settled on a 1:4 ratio, which means a 4lb difference would be equivalent to 16lbs of sprung weight. Still adds up in the end.
Calvin
Old 07-09-2004, 10:23 AM   #10
Kaishi
Member#: 25521
2005 WRX Wagon
World Rally Blue
Wohoo, 225's on a wagon!
SSR comps it is then.
Old 07-09-2004, 11:37 AM   #11
tribegolfer
Member#: 26850
2002 WRX V7 STi swap
You're not going to notice the difference in wheel weight. Tire weight is way more important since the weight is farther from the rim. But if you want to spend that much and never race them, go for it.
tribegolfer is offline   Reply With Quote
Old 07-09-2004, 04:46 PM   #12
Kaishi
Member#: 25521
2005 WRX Wagon
World Rally Blue
Is there a place you can see the wieght of various tires?
I looked on tirerack, and hit up google and didn't find anything.
Currently, i'm looking for a good all season tire, that doesn't sacrifice comfort or increase noise. I live right outside seattle, so wet performance is important.
Old 07-09-2004, 05:02 PM   #13
ripvw
Member#: 27790
see this thread:
http://forums.nasioc.com/forums/show...hreadid=592703
Old 07-09-2004, 05:26 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
Good, light tires include the Kumho MX( ) and the Toyo T1-S( )
Old 07-09-2004, 09:17 PM   #15
Len
Member#: 39937
2011 328i 6MT
LMB
Calvin
Correct ratio is 2 :1 maximum, but more like 1.7:1. 4:1 is physically impossible. No need for a controversy. It's a clear cut physics.
Len is offline   Reply With Quote
Old 07-09-2004, 09:50 PM   #16
cnk
Member#: 10757
To be honest. . .I could care less at this point. The fact of the matter is that reducing unsprung weight is better for performance plain and simple.
Calvin
Old 07-10-2004, 01:52 AM   #17
lucien2
Member#: 1519
1998 Volvo V70R
You mean a better Impreza offset Some of us run +48mm from the factory.
lucien2 is offline   Reply With Quote
Old 07-10-2004, 03:09 AM   #18
Len
Member#: 39937
2011 328i 6MT
LMB
Calvin
Yes. But the question is how much better and (more importantly) whether it's worth the additional investment. I too prefer lighter wheels in general, but I wouldn't spend, say, additional $500 just to reduce 1 lb per corner knowing the aforementioned ratio. Then again to some people that might be a worth while investment, depending on how demaning a driver you are.
Old 07-10-2004, 08:24 AM   #19
Chuck H
Member#: 20442
KTR tuned 2003 WRX
Just curious where you got that "clear cut" physics number from, since I've seen lots of different numbers and lots of different explanations. Determining the difference in acceleration on a car between just adding a pound to the cars weight and adding a pound to the rotating mass of a wheel/tire isn't the easiest calculation on earth to do.
Old 07-10-2004, 08:16 PM   #20
Len
Member#: 39937
2011 328i 6MT
LMB
If you are really interested in boring calculations, maybe you wanna check out this thread.
http://forums.nasioc.com/forums/show...light=unsprung
But in the end I said it was clear cut because,
1. Non-rotating mass and acceleration are directly related (twice the mass, twice slower the acceleration)
2. The factor we use to calculate the rotational inertia is directly related to the non-rotating mass.
It's really not a long calculation. For instance, for a uniform disk (the best case) we use a factor of 0.5 to get the rotational inertia. If you calculate how much power it takes to accelerate this disk by rolling it on a slip-less surface, you'll reallize that it's just like accelerating a non-rotating object that's (1 + 0.5 =) 1.5 times heavier than the disk on a friction-less surface.
The same goes for a thing ring (where all mass is concentrated at the edge, the worst case) where we use a factor of 1.0 and we get (1 + 1.0 =) 2 times heavier equivalent non-rotating mass. So there you have the factor of 1.5 ~ 2, and even if you consider the wheel size, tire weight, etc etc, this factor will be intact.
Now realistically a wheel/tire conbo is not as good as a uniform disk but not as bad as a thing ring either, so it should lie between 1.5 to 2.
Old 07-10-2004, 09:41 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
The difference between 35 pounds/corner(13 pound wheel like the SSR+22 pound tire like the Kumho MX)....and 45 pounds/corner(20 pound wheels+25 pound tires) is ENORMOUS .
The above numbers are NOT exact and are for reference only.
If you can't tell the difference in 10 pounds/corner, you really REALLY need to be driving a Yugo.
Old 07-11-2004, 12:14 AM   #22
cnk
Member#: 10757
It's a pretty simple methodology if you think about it. Determine your budget and then get the lightest quality rims you can afford. For most people, they don't even care about rim weight, only about what looks good. . .hence why there are so many people running around on 18" rims. For me, modifying a car means improving upon it, which meant getting a rim that was either equal to or lighter then the stock WRX rim of 16.5lbs.
Calvin
Old 07-11-2004, 12:33 AM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
Calvin
Old 07-12-2004, 04:15 AM   #24
Fubaru
Member#: 6046
'08 Prius
Cool looking & light weight, sure, but be prepared to replace a wheel or two because of street damage.
I had the Rota Attacks on my old WRX and broke one doing a hard turn. A spoke just sheared completely apart.
I didn't hit a curb or anything, it just broke taking a tight corner. There were a few other WRX owners who reported the same thing happening on this board.
I think if you search on 'SSR competition' you'll also find a lot of complaints that they are fragile as well (easily bent).
Fubaru is offline   Reply With Quote
Old 07-12-2004, 04:35 AM   #25
Len
Member#: 39937
2011 328i 6MT
LMB
Calvin
Not that I'm against your methodology, but different people have different priorities on things like performance, looks, and durability. Unless you have unlimited budget, you always have to make comprimises. Especially with affordable rims, light weight usually comes at the expense of durability, which to me is at least as important as performance. Therefore my choice tends to be more complicated than just the lightest rims in my price range.
Uncle Scotty, 10 lbs/corner is around 70 lbs effective mass and that's about the difference between the sedan and the wagon. I think that's good weight saving, especially considering the fact that most people that go plus-size end up gaining at least a few lbs/corner. What I'm saying is that that's the actual weight you saved, around 70 lbs. Did you feel it was a lot more than that?
WTT: 18x8 Anthracite SSR Comps for Steel Grey or Gold Rota Torque or G-Force DieselClown Tri-State Area Private Classifieds 1 05-30-2006 04:30 PM
17" Rota SSR Comps in Gold FEELER hoxypad Private 'For Sale' Classifieds 14 02-02-2006 02:29 PM
rota attacks vs battle vs sub-zeros? jhong567 Member's Car Gallery 2 02-12-2003 01:40 PM
P1's vs. SSR comps. wrxplode Brakes, Steering & Suspension 7 06-27-2002 08:59 PM
SSR Comps vs OZ SL Rim poll Keirik Brakes, Steering & Suspension 22 12-23-2001 05:04 AM
