Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-23-2000, 04:09 AM   #1
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Lightbulb The new H6 is swapable.
Reading the latest SCC (Which has scores of articles on the Impreza) it states that the new H6 engine will bolt right up into the 2.5RS engine bay. The bolt pattern of the H6 has more bolts but some of those bolt holes are in the same places as the 2.5RS.
The engine is only 0.8 inches longer and should go right in, possibly on the stock engine mounts. The engine is only 100lbs more from what I remember (magazine is at work). Go out an buy it, NOW. Lots of Scoobies in the mag.
I'll save other scooby material for someone on here to report. Im too busy reading it again (for the 3rd time).
Kevin Thomas is offline   Reply With Quote
Old 10-23-2000, 07:17 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I dunno man, 100 lbs is quite a bit to be putting on the nose of a light car that already has 57% of its weight up front...
RidinLow is offline   Reply With Quote
Old 10-23-2000, 07:27 AM   #3
boxerman
Member#: 644
Post
The Al bumper crossmember and hood should get the nose weight back to a reasonable level. It only takes an hour to move your battery to the trunk.
Tim.
boxerman is offline   Reply With Quote
Old 10-23-2000, 07:40 AM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
But then you can't leave the car parallel parked anywhere & you'll have a dented hood. Or, looked at it another way, you could make those 2 mods without the H6, spend an equivalent amount of money on the H4 (probably a lot) & get quite a bit of power out of the 4 & lighten the car in the process.
Or, looked at it in yet another way, what other performance mod costs a couple of thousand bucks & adds 50 hp along with 100 pounds to your car?
[This message has been edited by RidinLow (edited October 23, 2000).]
Old 10-23-2000, 10:02 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Miatae have had aluminum hoods forever. Requires more care, surely does dent easier than sheet metal, but isn't that big of a deal.
ColinL is offline   Reply With Quote
Old 10-23-2000, 10:23 AM   #6
Gambit
Member#: 102
Post
I think with an H6, you're better off putting it on a wagon because the wagons has better weight distribution than the regular models.
Don't forget with an H6, you can prolly easily tune it to 250hp levels because it's quite restricted as it is right now. Sadly it is offered in auto only for now....
Gambit is offline   Reply With Quote
Old 10-23-2000, 02:18 PM   #7
Jonathan Kent
Guest
Member#:
Question
RidinLow: "But then you can't leave the car parallel parked anywhere"
...huh? Don't understand.
J. Kent
Old 10-23-2000, 03:50 PM   #8
Overtime
Member#: 1346
Post
Miatae?
Anyway, the H6 should be swappable, but I don't know how tunable it'll be. There are some issues with it that will need to be evened out after it's introduced.
And do you really want an engine the first year it's put out? It's not that big of a jump in my eyes from a tuned 2.5 or an EJ20T.
Just my opinion.
Overtime is offline   Reply With Quote
Old 10-23-2000, 04:06 PM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Yeah, plural of Miata.
Old 10-23-2000, 05:25 PM   #10
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Jon, the lightweight aluminum bumper beam pretty much negates any bumping resistance, so if someone hits you while they're parallel parking, you get a crunched bumper.
Old 10-23-2000, 08:07 PM   #11
XT6Wagon
Member#: 524
04 STi
Post
So SCC CLAIMS its swappable. Well have they actualy DONE it? I haven't claimed that my swap works even though I found the physical space to put it in. Thats because I don;t have it RUNNING yet. All kinds of wierd problems can pop up when running.
Don't believe anyone who claims it works until its PROVEN. To do otherwise is to invite loss of $$. My conversion is runnign in the thousnads range. The guy who is going to do the same but w/o turbo is going to hit maybe $1K. I have had to spend more figuring out solutions, and prototyping parts. I think the 3.0L H6 swap will be in the same boat, unless the motor is 100% compatible with ALL ej-25 related parts currently under the hood. That is NOT the case as anyone who has seen a diagram can tell.
XT6Wagon is offline   Reply With Quote
Old 10-23-2000, 08:22 PM   #12
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
Post
and lets not forget the computer. you'd have to get a whole new system. probably a new fuel system as well. i'd rather have a turbo. besides, they sound cool
10th Warrior is offline   Reply With Quote
Old 10-23-2000, 10:02 PM   #13
slide
Member#: 1130
2013 STI Hatch
Post
Hey, There are some good points to having the first release of a certain engine. My 95 2.2 although not new came without a couple smog devices...
slide is offline   Reply With Quote
Old 10-23-2000, 10:47 PM   #14
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'11 X5 xDrive35i
'09 135i 6MT/'15 GTI 6MT
Post
Hrm....H6...plus Minnam Stage-2...and BPM gearset...damnit Kevin, quit giving me more ideas!!!
-Geoff
Geoff is offline   Reply With Quote
Old 10-23-2000, 11:38 PM   #15
HondasRslow
Member#: 2332
Post
the H6 swap would deffinately NOT be worth it. A hundred extra pounds, plus ALL the work doesn't quite add up as logical in my head. I work for Subaru and ive driven the H6, it makes 210 hp feel like alot less, and no its not just the wieght that brings it down, its just not tuned as a "sports car" it was designed as a old people car, luxury i guess you could call it. It revs no where near as quick as the RS. Plus you can only get it as a slushbox, no thanx ill settle for a turbo charged 4 banger.
-Alex
HondasRslow is offline   Reply With Quote
Old 10-24-2000, 01:28 AM   #16
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Well, Kevin has a Wagon, as do i.
Has there ever been a forced-induction H6 from Subaru?
DLC is offline   Reply With Quote
Old 10-24-2000, 08:07 AM   #17
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Post
yeah yeah enough about the H6, someone steal the manuals for the new WRX and see if that engine will fit in the RS, thats what I am interested in
slim speedy is offline   Reply With Quote
Old 10-24-2000, 08:17 AM   #18
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I agree, I wonder how easy it will be to swap the turbo H4 into the RS.
Old 10-24-2000, 04:49 PM   #19
Kevin Thomas
Member#: 110
1989 1989 XT6
Question
What do you think would be faster: 1) a turbo H4 swapped into an RS, or 2) an H6 swapped into an RS?
The H6 may be faster in a straight line since it has slightly more hp, though it has a weight penalty. And just because the front end would be heavier in the H6, that doesn't mean an RS with an H4 turbo swap would be faster in the twisties. Let's not forget how the big, heavy, non-twisty performing Mustang GT whooped up on the Acura ITR at the track (SCC-Sport Compact Car) and in the straight line.
Just making an observation as usual. I don't take either side of the argument here.
Old 10-24-2000, 05:01 PM   #20
eicbal18
Member#: 959
Post
New H6 swappable? then new turbo engine that will come out in MY02 could be swappable too.
eicbal18 is offline   Reply With Quote
Old 10-24-2000, 07:09 PM   #21
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Post
Actually according to excite's auto guide the H6 only has 212 HP and the new impreza has either 215 or 227, depending on whose numbers you use. Plus I think having the extra weight in the front will mess up the handling. Regardless the turbo engine should be much easier than the H6 to get more horsepower out of(turbo engine, more aftermarket support, etc.) Anyway thats my take on it, so line me up for a WRX engine after someone takes a corner to fast
Old 10-24-2000, 09:19 PM   #22
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
Arrow
...Or you could just Turbocharge the H6
Dan_E is offline   Reply With Quote
Old 10-24-2000, 09:24 PM   #23
Kevin Thomas
Member#: 110
1989 1989 XT6
Lightbulb
Or supercharge it, like JC Sports did on a Legacy with an SVX engine. Got Hybrid?
Well... The STi is sold... and the new car is.... Jaylyons1 Mid Atlantic Impreza Club -- MAIC 31 05-30-2008 10:10 PM
the new H6 NicEJ25 Outback Forum 6 06-10-2004 12:18 AM
What's the power output of the new H6? MrSube2pt5 General Forum Archive 4 11-26-2000 12:06 AM
AutoWeek report on the new H6 Outback gtguy Legacy Forum 1 08-24-2000 04:41 PM
Hints of the new H6 John Davies Legacy Forum 2 12-23-1999 06:26 PM
