Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 10-24-2000, 04:26 AM   #1
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
Post SAFC Throttle missing 10%
Just installed my SAFC and I have a very odd reading. The sensor check tracks the voltage from my TPS as going from 0.0 to 4.2~3 and in all respects seems to opperate just fine. The problem is that fully floored all I get is 90% on the throttle reading on the SAFC. I could find no adjustment for the endpoints which made me wonder something. The manual indicates that on different vehicles the TPS may produce 0-3, 0-4, 0-5. How does it know when it reaches 100% if there is no provision to tell it what 100% is? It would stand to reason that you must be able to set the maximum so it knows what 100% is. What are your experiences and what is you rmaximum indicated throttle percentage?
Pipercub is offline   Reply With Quote
Old 10-24-2000, 09:46 AM   #2
Scooter
Member#: 75
Post
Do you know anybody with a Laptop and OBD II scan tool software? With such software you could do a check to see if you get the same 90% reading from the ECU. If so, then your throttle may not be opening fully or your TPS could be off.
Here's a link to a Fluke DMM application note that talks a little bit about checking such things. Even without a DMM you could still check if the throttle is actually opening all the way. If it is opening all the way, but the ECU says it's only 90% open, then your TPS might need adjusting.
http://www.fluke.com/application_not...AGID=1&SID=103
[This message has been edited by Scooter (edited October 24, 2000).]
Scooter is offline   Reply With Quote
Old 10-24-2000, 11:27 AM   #3
MPREZYA
SCIC
Member#: 85
Post
Make sure your floor mat or something isn't underneath or in the way of the gas pedal near the fire wall that will keep you from getting 100%.
MPREZYA is offline   Reply With Quote
Old 10-24-2000, 03:07 PM   #4
Pipercub
Member#: 2188
2004 Impreza STI
Post
It was something simple, but not as simple as a floor mat. I performed an initialization on the SAFC and set it up with the same settings as I did the first time and 100% throttle is now displayed. SO, to anyone installing an SAFC, do an initialization, then input your settings for sensor type # of cyl etc. It takes 10 seconds and saves you a great deal of trouble.
[DISCOUNT] Get 10% off on wheel & tire combos from TireBuyer.com PostRelease Tire & Wheel 0 06-01-2010 01:01 PM
Engine misses when throttle 'floored' lil'greenimp_98 Service & Maintenance 3 02-11-2008 12:36 PM
engine missing after 50% throttle kolohe Engine Management & Tuning 23 12-19-2004 03:09 PM
I think my SAFC just went to SAFC heaven... Fred Zaplitny Engine Management & Tuning 3 03-25-2003 09:12 AM
('93-'01) SAFC Throttle not reading "zero" 2yLiTe Impreza Forum 12 04-12-2001 12:33 AM
