Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-22-2000, 09:24 PM   #1
Scoob_13
Member#: 123
2005 WRX STi
Blue and gold
Post UR Pulley questions concerning torque specs
Recently picked up a pulley/belt set from Trey, and started to install it. Got everything off the front and ready to undo the crank pulley, and started to it. Per the instructions I set the car in fifth, had someone hold down the brakes, and started to use the breaker bar to remove the nut.
Ha. We BROKE a brand new breaker bar trying to unbolt (double checked the directions and everything) it, and promptly decided to set a time to take it to Trey for his magic touch.
Anyone else have this slight problem?
Phil
(Back from the Future, so to speak)
Scoob_13 is offline   Reply With Quote
Old 10-22-2000, 10:14 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
That nut is a #$%# to break. needed at 3ft extension to get mine off. its 95ft/lbs supposedly, but over torqued from the factory.
Midwayman is offline   Reply With Quote
Old 10-22-2000, 10:54 PM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Also, be very carefull when retensioning the belts.. Ya might strip the tensioner bolts.. Right Midwayman?
You broke a breaker bar??? (And I thought I had a bad reputation)
What size?
[This message has been edited by Revision (edited October 22, 2000).]
Revision is offline   Reply With Quote
Old 10-23-2000, 12:44 AM   #4
redwagon
Member#: 2181
2008 SpecB
Cool
All crank pulley bolts are done up real tight, and they self-tighten too.
A trick I was taught was to put your thickest breaker bar to it and rotate until it met with something solid, like the frame rail or the subframe. Next, with the plug leads off, give it a quick hit on the starter...best torque wrench there is. Just don't stand there with your head over the thing looking at it...
redwagon is offline   Reply With Quote
Old 10-23-2000, 04:49 PM   #5
Camaroman
Member#: 1559
2004 Sierra Denali
Post
I got mine off today fairly easy using a 1/2 drive breaker bar...
you have to shock it or you'll push all day long...
I had the car in fifth....and my brother hammer on the bar while I pulled it...
hurt the hands but worth it
Camaroman is offline   Reply With Quote
Old 10-23-2000, 05:09 PM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Starter idea is a good one. After 22k miles mine wasn't that bad though, 1/2 breaker bar + 2 ft pipe and it was off.
ColinL is offline   Reply With Quote
Old 10-24-2000, 12:51 PM   #7
nizz
Member#: 188
2004 Forester XT
24k gold on white
Post
I just used a pipe and a lot of yelling. Once you start hearing that metal squeaking sound, you know you're getting somewhere! Don't quit and use $%&*@# power! I had to give up the first time doing it by myself when I had the car in 5th and the brake was held down by my "The Club". It was wedged between my brake pedal and the seat.
nizz
nizz is offline   Reply With Quote
Question on torque spec on exhaust manifold gopsu Newbies & FAQs 7 05-20-2006 07:30 PM
Question on Torque specs and more... mdurbahn Brakes, Steering & Suspension 0 03-17-2006 12:28 PM
Another pulley torque spec question. Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2001 10:08 PM
UR Pulley questions, Need help quick ATX25RS Transmission (AT/MT) & Driveline 7 10-19-2001 04:30 AM
UR Pulley Questions Narso Technical Forum Archive 2 07-11-2000 01:24 AM
