Old 07-09-2004, 12:07 PM   #1
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Default Dual Ball bearing myths...
I heard something to the extend that the dual ball bearings after a hard run will continue to spin even 1 minute after shut off of the car...
I was told I have a dual ball bearing and I bought it fromt he Canadian distributor for garrett... I can hear nothing...
maybe more break in? or is my 13 psi on the GT30 too low to get it spinning hehheeh.. still pushes a lot of air...
fact or fiction?
HOK is offline   Reply With Quote
Old 07-09-2004, 01:24 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
well u gotta also think where would the moving air go to
Old 07-09-2004, 02:17 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
My GT30R still spins a minute or 2 after the car is shut off. You can hear it winding down. Really neat effect.
Based on my experiances, it's fact.
kastle is offline   Reply With Quote
Old 07-09-2004, 02:48 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
where does the air go
Old 07-09-2004, 02:51 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Good question... I know the turbine is spinning cause you can hear it... but where the air goes it a great question.
Old 07-09-2004, 02:56 PM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
so i got ripped off?
Old 07-09-2004, 04:41 PM   #7
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Smile
Hola Kastillo (Kastle in spanish)
How's the GT30R in spooling time/rpms? How much boost? Would it be worth it to upgrade from a GT28?
I get full boost @ 2700rpm (10 psis) but goes down after 5700-5800. When running in 4th & 5th gears over 5700 the car drives almost like a NA car...
saludos,
Mariano
Mariano is offline   Reply With Quote
Old 07-09-2004, 05:15 PM   #8
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
saludos,
Mariano
I'll know today since I'm picking it up from FAT with the new FMIC and new ECU.. only had 160 miles on it with the TEC2 previously.
Old 07-09-2004, 05:39 PM   #9
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Kastle, is this the same FMIC they were designing for us to keep our foglights?
Wedge is offline   Reply With Quote
Old 07-09-2004, 06:06 PM   #10
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Past tense... Once Robert got the car apart, he realized there was no way to keep the fogs...
But it's that kit. GT30R, FMIC (27x14x2.5), Tial 38mm wastegate and Tial BOV... looks really nice... I should be getting the car back today, so I'm crossing my fingers that it runs...
RA motor still only has 160 miles on it, have had it since Jan in the car....
Old 07-10-2004, 12:59 AM   #11
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
update --> talked with Robert about this today, he said that even though the turbine is spinning down, it doesn't create enough air pressure to amount to anything.
Old 07-10-2004, 01:10 AM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
I dont think there is much air moving... they are just winding down. I think ill go do some research on it.
Old 07-10-2004, 05:25 AM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah im thinking that the air just kinda moves around in there
Old 07-10-2004, 08:34 AM   #14
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
A turbo charger is not a positive displacement pump. It can spin (at low speeds) and not displace any or much air at all. Come to think of it, if it can keep spinning 1-2 mins after shut down, that would mean that it has a lot of inertia in the rotating assembly, this same inertia will prevent it from quickly changing speed during transient throttle operation.....which is probably not desireable for quick response. A ceramic turbine and compressor wheel assembly will definitely remain spinning for a shorter duration given the same conditions due to reduced rotating inertia.....just a thought....
Boostup! is offline   Reply With Quote
Old 07-10-2004, 12:17 PM   #15
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
A friend has a GT30/40 and he's timed off 1 minute 36 seconds from shutdown to stopping rotating.
Old 07-10-2004, 08:27 PM   #16
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
My AVO450 goes for a good minute at least even from idle shutoff.
DubuRX is offline   Reply With Quote
VF22 Dual Ball Bearing Turbo... rocketsauce16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2007 06:55 AM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
Sbr Garrett Dual Ball Bearing Bolt On Gt-14 Ebay 1 Hr Left 1 Bid @ $649 calib17a Private 'For Sale' Classifieds 0 04-24-2006 03:04 PM
VF22 Single ball bearing myth fzturbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-30-2006 10:51 PM
Dual Ball Bearing AVO GT30R turbo TurboBeast21 Private 'For Sale' Classifieds 18 10-05-2005 02:50 AM
