#1 |
Member#: 1737
NWIC
Vehicle:2005 BMW zhp www.vispoint.com |
Hey all..
I just put my 5zigen cat back system on and a week later after it got progressively louder, I put it on the ramps again and one of the bolts between the 5zigen center pipe and the zigen exhaust had disappeared. Thus the noise. I was unhappy with the fit between the 5zigen center pipe and the stock cat pipe so i put the stock center pipe back in and connected it to the zigen exhaust with the gasket inbetween. My question is how does leaving out the washers influence the nuts/bolts rattling off eventually? What are the best washers to use here and where should i use them to hold this thing together better? TIA Mike
#2 |
Member#: 2253
Vehicle:2000 2.5 RS Red |
Torquing down the fastner the proper amount will keep the fastener from rattling apart. Use a split washer to help keep tension on the fastners. You might want to use a mild Lock Tight, not the heavy duty stuff.
#3 |
Member#: 1426
NESIC
Vehicle:'07 335xi, '07 ZX6R SV650 Race Bike |
To echo what Storer said, you can either use a lockwasher which looks like a washer with a slit halfway through it....or use a Nyloc, which is a steel nut with a nylon insert which greatly improves retention forces. The fit is kinda crappy from the cat to my mid pipe (2.25" apexi) but so far no leaks. I went the Nyloc route..just FYI.
Fitz |
| Thread Tools | |
| Display Modes | |
| aftermarket radio install question on the sub | jasontee1 | Car Audio, Video & Security | 2 | 10-07-2007 11:43 PM |
| n00b catback install question | quynce | Newbies & FAQs | 8 | 08-08-2003 03:01 AM |
| Catback install question | Purdue WRX | Factory 2.0L Turbo Powertrain | 3 | 06-12-2003 03:05 PM |
| catback install question | OJL | Normally Aspirated Powertrain | 23 | 05-04-2003 10:06 PM |
