#1 |
Member#: 953
"Don't get one for the MY00-01. The computer learns that you have one and will cancle the settings out after a little while. It was the biggest waste of $300 I've ever spent because I always have it set to 0% even with my nitrous!"
I got the S-AFC for my car as well, but I have yet to install it on my car... if the settings reset after a while then I see no point in taking the thing to dyno-tune at Minnam/Tecknik afterall
#2 |
Member#: 1669
Vehicle:2004 WRX Sport Wagon Silver |
i'm gonna lean towards yes due to the map sensor having it's own fuel maps...i believe is the correct way to say it.
#3 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
<FONT face="Comic Sans MS">Another reason being that the MY00-01 run rich as opposed to lean with an intake, ergo, there is no need to bump the amount of fuel at a given rpm range.
Brian AIM: NUrsalia ICQ: 84483950 http://members.nbci.com/_XMCM/northu...reza/index.htm Is that a chicken up there? Nope, just the way he's holding the grapefruit! </FONT f> |
#4 |
Member#: 953
So basically you are telling me that... for a MY00 2.5RS, the Apex'i S-AFC will provide no use for me even if I have an intake and catback exhaust?
#5 |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
Well, if in theory the MY0x's run rich, you could use the SAFC to lean out the fuel going into the engine to make a bit more HP. That's in theory though.
LaterZ! Darren!! |
#6 |
Member#: 953
Well how about in actuality Darren? hehe
#7 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
Since I am the one who posted the quote above, I can tell you for a fact that it is true
![]() Eric |
#8 |
Member#: 766
Vehicle:MY00 2.5RS 4EAT BRP |
Eric,
Base on your experience, if I use the SAFC to lean out '00 RS, will there be some HP gain? Thanks~ |
#9 |
Member#: 3768
So I wasted $300 dollars? Oh well it still looks trick as ****!
adamsrs www.unnatural.org |
#10 |
Member#: 1473
Vehicle:2005 Legacy GT 5MT Satin White Pearl |
ive always thought a SAFC on an N/A car with regular cams was a waste of money
![]() at least on the honda/acura world, unless you have wilder cams, and other n/a work done. You will gain nothing from tuning a stock n/a car with a SAFC... (in H/A's) |
#11 | |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
no due to the auto learn feature which will compensate
#12 |
Member#: 953
Yeah right?
Cause I saw the dyno charts for Keiho's car.... he has an exhaust, upulley, and intake... it pulls significant harder with the addition for his Field SFC... Isn't the SFC and the S-Afc the same thing? |
#13 |
Member#: 627
Vehicle:MY96 outback wagon |
my MY00 runs rich under 3500rpm, and lean above that (only have catback exhaust, no intake yet)
i don't think my ECU has learned anything yet (had it for 3 month now and put on about 3k miles since), but i'll do a couple runs tonight or tomorrow to see if that's true |
#14 |
Sea to Sky - OWNED
Moderator Member#: 610
VIC
Vehicle:2003 Lexus IS300 Graphite Gray Pearl |
Since my name was mentioned here I'll throw in my 2 cents.
When my car was turbo'd I was using the Hyper R as my only means of controlling fueling. It worked great up until the top end, which by then my Hyper R ran out of numbers! I was enriching the maximum 30% and it still wasn't enough. Anyway, after a while of testing on the dyno, the guys at Technik found that YES, the ecu did revert back to its oem fuel maps and the Hyper R was useless after that. However, this is only the case when cruising and the throttle is at a constant level. So for what its worth, the Hyper R does work, but if you're on the highway and the throttle isn't moved much, yes the ecu does revert back to its oem fuel maps.You can look at my dynograph to see the difference between my non-tuned NA setup and my Hyper R setup. Last but not least, I'm using a Field Hyper R, so it might be different from the Apex'i SAFC ![]() |
#15 |
Member#: 438
W. Canada
Vehicle:2004 STi White on Gold |
So Keiho, are you saying that a turbo'd MY00/01 would be best served by going with a stand alone fuel management system (like TEC-II) and avoiding the stock ECU altogether?
#16 |
Member#: 627
"However, this is only the case when cruising and the throttle is at a constant level"
Keiho, where you in close- or open-loop?? |
#17 |
Member#: 4067
Vehicle:01 2.5 rs silver |
the s-afc doesn't tell the ecu to add or take away gas, all it does is trick it into thinking more or less air is going into the engine, then the ecu regulates the fuel injectors. it's a pretty good thing to have for a turboed car, but as far as an n/a car goes, you can only yield a small amount of hp out of an hour or so of tuning with an a/f meter.
#18 |
Member#: 953
So it does work, but if I keep it at a constant throttle then it will reset?
Is it easy to reprogram the original set of numbers? |
#19 |
Member#: 1110
Vehicle:1999 RS Silver |
The ECU does not "learn" in closed loop (except from knock). There is no "fuel map" in closed loop. It constantly trims the mixture based largely on the inputs from the O<sub>2</sub> sensors. Playing with the SFC will do nothing in closed loop since the ECU instantly (not eventually) works around it and brings the mixture back to what it deems appropriate. If it senses knock the whole timing-retard regime is triggered and it may take a very long time for it to "unlearn".
In open loop the ECU only learns if it encounters knock. If this was not the case and it did take A/F mixture into account then O<sub>2</sub> meters (and in fact, the SFC itself) would be pointless, since the ECU would immediately override any settings you made as it does in closed loop. The fuel maps are preprogrammed, hence the term open loop. In a MY00 this means x injector cycle duty for y speed and z density (in a MY98-99 it means x injector cycle duty for y*z mass airflow). You can still trick the ECU by telling it that the density is from percentage of z. You can lean the engine out with typically positive results if it was running too rich (as measured by an EGT gauge, and if possible in conjuction with an O<sub>2</sub> meter reading), but if you induce knock you are going to get yanked back by the ECU. When you hear about dyno tuning with the AFC, what they are usually talking about is getting a feed on the O<sub>2</sub> sensor reading and overlaying it on the dyno graph, then looking for patterns and correcting accordingly. Edit: can't spell [This message has been edited by P.K. Motorsports (edited February 13, 2001).] |
#20 |
Sea to Sky - OWNED
VIC
Markus - of course if you have the money for a standalone engine management systems, yes that is the best for turbo'd MY00-01 cars.
However, a RRFPR and a fuel computer would do nicely, you won't get the most power, but it'll work.cj917 - I haven't the slightest clue, I'm just repeating what the mechanic at Technik told me. |
#21 |
Member#: 627
what smacksube and PKM said
silly me, got scared for a minute thinking that the SAFC would re-write the preprogrammed lookup table... of course not, since it simply tricks the ECU thinking it's seeing more or less input from the MAP sensor for those who want more readings, here's wac's SAFC tech note |
#22 |
Member#: 627
keiho:
i'm guessing you were in close-loop then... wac (and someone else in the NE board) confirmed that the ECU enters open-loop mode of >20% throttle position... in that case, the ECU does not refer back to its stock fuel map, but simply relies on the o2 sensor's feedback for fuel correction (see PKM's post) markus: wac is running a turbo on his OBS using SAFC (and ITC i believe), but no TEC-II... and it's running great, to my knowledge... as long as you tune it carefully and have the necessary gauges to monitor things, it should be fine and if you are not planning on TC/SC-ing the car, running lots of N/A mods that would drastically change the amount of air entering the engine, or simply using less than 25% of the throttle most of the time, yes the SAFC is a waste of money ![]() |
#23 |
Member#: 1110
cj917 - the ECU goes into open loop at roughly 90% throttle based on O<sub>2</sub> sensor readings. It is in closed loop at all other times.
#24 |
Member#: 953
Hehe... P.K., I don't really get it... simply put... what you told me is....?
#25 |
Member#: 627
PKM:
are you sure?? i just took a drive outside, with the SAFC settings to all zero's vs. the corrections... and with the corrections i only need to push 25-30% throttle to see that the SAFC is indeed working (i.e. instead of my EGT reading shooting up towards the 1500F's, it stays around 1400's like i want it) i'm not entirely sure how WaC tested the greater-than-20% theory (i think it was based on his o2 sensor readings... i have a MY00 so i dont bother to hook the SAFC up with the rear sensor), but someone else confirmed on that number too... you might wanna ask WaC himself and if anyone else can confirm the >20% or other numbers, please help us and speak up! ![]() (on a separate thought) when someone goes to a shop and sometimes they tune it by sticking a o2 sensor into your exhaust pipe, isn't that reading off what's "after" the cat(s)? and i thought that suppose to be not as accurate? |
| Thread Tools | |
| Display Modes | |
| Is this true? SAE Correction for turbo cars is BS? | japslapr | General Community | 12 | 03-06-2008 10:24 PM |
| I heard that Kumho is going out of business. is this true? | Eric SS | Brakes, Steering & Suspension | 1 | 12-08-2001 09:45 PM |
| ('93-'01) is this true?? please read | nitrousjunkie68 | Impreza Forum | 55 | 06-30-2001 03:22 PM |
| Is this true? Can they do this? | DaPunko | General Forum Archive | 18 | 07-19-2000 05:08 PM |
| Is this true about Isuzu???? | Rene Seguin | General Forum Archive | 10 | 06-01-2000 11:00 PM |
