Old 02-14-2001, 10:32 PM   #1
markus
Member#: 438
2004 STi
White on Gold
Question Turbo's & Cruise Control==>Compatible?
IIRC, most of the existing aftermarket turbo systems out there that are using intercoolers have to remove the cruise control. Is this correct?
I drive many thousands of kilometers/miles a year and to lose my cruise would completely suck!!!
Any of you turbo owners care to comment on what modifications (if any) you had to make to your cruise control in order to make this work? Or did you simply live with the inconvienence?
Your input appreciated.
markus is offline   Reply With Quote
Old 02-14-2001, 10:46 PM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
You just have to relocate it. You need to move it more because of where the turbo mounts, rather than the IC. Here is a pic of where I put mine.
<IMG SRC="http://www.azscooby.com/images/Rim00023.jpg" border=0>
It is the green/black thing above the air filter (for those who might not know what they are looking for.)
Hope this helps,
Aaron
AaronB is offline   Reply With Quote
Old 02-14-2001, 11:58 PM   #3
XT6Wagon
Member#: 524
04 STi
Post
Oh, you might want to put on stronger throttle return springs...
My Turbo wa on the highway when a car passed me and pulled back in. Bingo the car accelerates as the air drag decreases ALOT (hmm 4X4 ride hight and areodynaics of a barn). Well this causes the turbo to spool. The turo is spolling faster than the cruise can let off on the throttle. So here I am accelerating hard at 85MPH running 15psi and the boost is holding the TB open, as the cruise is resisting the throttle return spring enough.
XT6Wagon is offline   Reply With Quote
Old 02-15-2001, 12:01 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Here is my relocated Cruise Control near the ABS - Instructions are posted off the mymods section of my website www.ImprezaRS.com. No problems so far.
<IMG SRC="http://www.imprezars.com/images/step160dcp00365.jpg" border=0>
Larry
[edit] typed a / after the www in the URL instead of period for the picutre
[This message has been edited by ImprezaRS dot com (edited February 15, 2001).]
ImprezaRS dot com is offline   Reply With Quote
Old 02-15-2001, 01:25 AM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Yup, cruise control isn't a problem Markus.
Had I kept my turbo I would've mounted it back somewhere else too...I can't live without my ABS!
Fwiw, I think not having the cruise control was what was setting off my AT oil temp light back then.
Keiho is offline   Reply With Quote
Old 02-15-2001, 05:37 PM   #6
markus
Member#: 438
2004 STi
White on Gold
Thumbs up
Thanks for your input guys. Looks like its a no-brainer modification.
Fog light & cruise control switch smokeone954 Private 'Wanted' Classifieds 2 04-15-2010 02:18 AM
06 STI Differential & Cruise control prob from LED tail light bulbs REDDOG Drivetrain 0 05-02-2008 06:20 PM
Aftermarket Steering wheel & Cruise Control? WAYGONE1 Motorsports 5 06-04-2007 05:20 PM
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
Steering wheel & Cruise control Skeandhu Interior & Exterior Modification 6 01-23-2001 08:08 AM
