Old 10-22-2000, 03:48 PM   #1
Paully
Member#: 1337
Question ATTN: Some one who KNOW'S 1.8s and Turbos
Ok, From my post below i found I have a 1.8 under my hood. So some one got a little caryed away with the stickers. So here is the question.
Will a water cool turbo from a 89 1.8 fit on my car? I work in a junk yard and I can find the parts. And it would be cheeper to get a used turbo. I wont to buy the headers and turbo and make the rest fit. any one that know PLEAS reply. Thanks.
Paully is offline   Reply With Quote
Old 10-22-2000, 03:59 PM   #2
Subu WEX
Member#: 1169
Post
If you can figure out the piping, and placement of the Turbo, as long as it fits under the hood, it fits, ya know?
Subu WEX is offline   Reply With Quote
Old 10-22-2000, 05:15 PM   #3
XT6Wagon
Member#: 524
04 STi
Post
a 1.8L WHAT??
I will assume you are talking about a impreza, and based on that here goes.
I would pick the Legacy Turbo turbocharger if one is avalible to you. If not the one off the older subaru Turbos will work. You then have two choices for exaust routing. You can get a legacy turbo crossmember and exaust, or run a minam style setup. Intake plumbing is dead simple once you have the rest of it done.
XT6Wagon is offline   Reply With Quote
Old 10-22-2000, 06:13 PM   #4
Paully
Member#: 1337
Post
sorry it is a impreza. I thought that the Turbo would fit. There is plenty of room. What it really comes down to is the Headers. Will the Legasy Header fit my car? and if it dose witch is the better set up? the legasy headers or minma style? thanks for all the info. PLEAS keep it coming!
Old 10-22-2000, 08:15 PM   #5
XT6Wagon
Member#: 524
04 STi
Post
Ok, the legacy style is by far the most expensive, and is a bit better.
What I would do is make a custom setup, with the stock Y-pipe cut not far after the 90 bend. then run it up behind the subframe to slightly above where miniam puts thier turbo. Use a common 2-1 colector to make the transition. Then reduce it to the diamiter of the turbo, and put a flange on top. If you want me to I can make the flange needed for athe early Subaru turbo turbocharger or the legacy one. I have MOST of the dimentions needed for the legacy one, and all of them for the early Subaru. The downpipe flange is more difficult but can be done.
here is a few pics of the one for my Hybrid Wagon.
http://web.nmsu.edu/~ewitte/subhdr_2.JPG http://web.nmsu.edu/~ewitte/subhdr_3.JPG http://web.nmsu.edu/~ewitte/er27man_1.JPG http://web.nmsu.edu/~ewitte/er27man_2.JPG http://web.nmsu.edu/~ewitte/er27man_3.JPG
Note If I had to do this again I would have used a WRX turbocharger, and mounted the turbo farther back and slightly lower.
As seen in this next pics the Turbocharger I used is off of a single turbo Supra.
http://web.nmsu.edu/~ewitte/subex_5.JPG http://web.nmsu.edu/~ewitte/er_27_12.JPG
Old 10-23-2000, 05:41 AM   #6
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
XT6Wagon......
WOW H-6 with a turbo in a wagon.....Frankenscooby!!!! that is cool.
Liquid Calm is offline   Reply With Quote
Old 10-23-2000, 06:51 AM   #7
Gambit
Member#: 102
Post
dayam....i thot you're refering to the VW 1.8T....
Gambit is offline   Reply With Quote
Old 10-23-2000, 11:50 AM   #8
Paully
Member#: 1337
Post
Nice set up there XT6wagon. I would love to see teh face of the people that try and take you at a light!
In sted of cuting my headers would the legasy headers fit? And what about my computer? I have been thinking of geting the TEC 2. but I cant find a cost and I really dont know if it would help. know if I put a turbo on I am going to need somekind of computer. And I would think that SCC and others out there would agree that 6 pigy back computers are not as good as one. So any ideas? And XT6 if I need a custem set up I will let you know. Thanks.
Old 10-23-2000, 02:48 PM   #9
XT6Wagon
Member#: 524
04 STi
Post
Well You can on a low boost situation get away with just a FPR. your car uses a MAF so it should be fairly good at adjusting for the airflow.
The legacy turbo headder shoudl work, but you need to do so much extra work and buy extra parts that I woul avoid doing that. You could always find a impreza in the junkyard and buy its y-pipe to cut up.
looking for some one who knows how to do head light mods dubkid26 Southern California Impreza Club Forum -- SCIC 5 02-18-2009 07:51 PM
sti tmic from some one who lives in los angeles brianmurder13 Private 'Wanted' Classifieds 0 08-19-2008 05:14 PM
Some one who has installed a FMIC kit before... Erexxx Southern California Impreza Club Forum -- SCIC 22 08-13-2007 03:05 AM
WTF: Some one who works with aluminum (lathe) Pat Green North West Impreza Club Forum -- NWIC 9 11-13-2006 11:30 PM
Some one hit my car with there door and i caught who did it! ImprezedRS South East Region Forum 7 05-16-2001 07:08 AM
