Old 10-21-2000, 06:23 PM   #1
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Question Urgent...need help with changing gear oil
I think I found the drain plug, but where is do I fill it up from?
Zee
Sunrise City Rider is offline   Reply With Quote
Old 10-22-2000, 07:20 AM   #2
BrianB
Member#: 1712
2008 STi
Post
Funnel to the dipstick tube.
BrianB is offline   Reply With Quote
Old 10-22-2000, 09:49 AM   #3
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Lightbulb
i think the rear has two bolts with indented square rachet fittings 1/2" or something one above the other on the rear diff.. i think you just stick the rachet itself in the hole and it fits. then just remove the bottom one and drain and replace. then remove the top one and fill and replace.
the dipstick i believe is to fill the MT fluid???
justin
joostin420 is offline   Reply With Quote
Old 10-22-2000, 07:09 PM   #4
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
Post
Are you talking about the front or rear diff Zee?
Kyle Paton is offline   Reply With Quote
Old 10-22-2000, 07:12 PM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Isn't this illustrated in the owner's manual?
RidinLow is offline   Reply With Quote
Old 10-22-2000, 11:01 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
For the tranny, the drain plug is located at the junction where the two header runners meet. Make sure you cover or remove the exhaust runners or you will smell burning tranny oil all day (all night and all week). The fill tube/dip stick for the tranny is located on the passenger side under the large plenum box right off the tranny housing. Look for it. Use a long funnel to fill it. And don't overfill. Overfill bad.
The rear diff is simple. The view from the rear shows 2, 1/2inch square bolts. Use a 1/2" breaker bar to remove. Top bolt is fill, the bottom bolt is drain. Fill only to bottom of top bolt. Very messy operation, but before you begin, check out the diff houseing for leaking fluid. If you see any leaking fluid (even a drop), take it to your dealer for warrenty seal replacement.
Revision is offline   Reply With Quote
Old 10-22-2000, 11:08 PM   #7
socal2.2
Member#: 2428
Exclamation
It's not 1/2" -it's 3/8", I used my ratchet to do it....
Just wanted to save this guy a trip to the hardware store.
Try your ratchet....
socal2.2 is offline   Reply With Quote
Old 10-23-2000, 01:40 AM   #8
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
Gentlemen,
Always, open the fill plug BEFORE opening the drain. Just in case there is a problem getting the fill plug open.
gaylemd is offline   Reply With Quote
Old 10-23-2000, 10:16 AM   #9
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Angry
Its cool, I found the dipstick. It was 11 at night and the damn thing is hidden down there. Its a bitch to put it back in too. Before I changed the fluids I took a trip to Sears and copped the 170 piece mechanics kit so I had the tools. I believe its a 1/2" in the rear diff not a 3/8". Now that I got that all taken care of... my new problem is I am grinding 1st gear. I don't know if the oil is too thin...but I disengage the clutch to the floor and I pop in first and it grinds not all the time but when it does I can pull it out and repeat the grinding again. The oil I used was Valvoline Synpower 75/90. Is there something wrong with this oil and my tranny. Its not really a grind its more like a strong vibration that shakes the stick...
Zee
Old 10-23-2000, 11:32 AM   #10
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
Yeah, that seems to be a universal problem. I used Redline 75w90 NS (NS formula has friction modifiers). It seems that nearly all the synthetic 75w90 tranny fluids are too slippery for the syncros to work properly.
Try a search on Redline 75w90.
But if the gear isn't really grinding. You are probably feeling the syncros working.
urgent need for tonight redline Gear oil 75w 90 1 bottle Syms-STI North West Impreza Club Forum -- NWIC 7 08-26-2008 11:08 AM
URGENT!!! need help with tire sizes and center diff crazyboardr8806 Tire & Wheel 2 02-23-2007 11:15 PM
I need info on changing gear oil (tranny) shogunate83 Service & Maintenance 33 10-21-2002 11:17 AM
URGENT... need help with STi mount install mpaone Normally Aspirated Powertrain 4 10-22-2000 01:07 AM
URGENT!!! Need help with Tein HA's! tmr Technical Forum Archive 4 10-03-2000 01:51 AM
