Old 07-10-2004, 12:19 AM   #1
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Default Car runs but not happily with my Ludespeed
When the IAC is plugged in, with LinkPlus, idle SUCKS, very rough and varies between 500-900 rpm, without it, it idles smoother! The coolant temp will jump to 108deg C and fall unpredictably (AC is not on). Ran it on the dyno and have about 100 wheel horse which is unacceptable. Any ideas?
blaznc is offline   Reply With Quote
Old 07-10-2004, 04:21 AM   #2
kaos200
Member#: 2692
100whp non turbo, have you changed the injectors? it just means you havent tuned it well.
if the coolant temp is rising, and falling unpredictably. Check your thermostat first, then if thats ok check your leakdown
kaos200 is offline   Reply With Quote
Old 07-10-2004, 12:10 PM   #3
Unsung Boxer
Member#: 37196
disabling the IAC will make the motor sit in "shut position" and the ECU will have no control over idle based on MAF/MAP input. Thus its in sort of a "failsafe" mode. Your car may idle now, but at different altitudese and temperatures, you will have problems. Not to mention you should see a Check Engine Light soon (oh wait, you have Link).
Anyways, you are disabling a motor, its not a proper fix. If you are having idle problems now, its likely due to vacuum leak or crappy A/F map.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 07-10-2004, 05:22 PM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
obviously your IAC is shot.
sidewayz is offline   Reply With Quote
Old 07-10-2004, 06:41 PM   #5
Unsung Boxer
Member#: 37196
oh is it now? You should be a technician
-Jake
Old 07-11-2004, 05:20 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I had very similar problems until I hooked up the ECU ground to a good earth ground. Then everything was fine.
Drac9 is offline   Reply With Quote
Old 07-11-2004, 12:16 PM   #7
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
This definately sounds like a vacuum leak issue. Do you have a boost gauge or scan tool? see what your manifold vacuum is at idle with the thing un-plugged.
no-coast-punk is offline   Reply With Quote
Old 07-11-2004, 01:59 PM   #8
blaznc
Member#: 41862
0000 99L 2.2T, dead
My boost gauge says around 18-13 in Hg. The Link says around 40 kPa
Old 07-11-2004, 04:45 PM   #9
Drac9
Member#: 9861
Grounds man- I had the exact same behaviour
Old 07-12-2004, 07:51 PM   #10
sidewayz
Member#: 5810
2001 S366 2.5RS
-Jake
I am think before you speek idiot. if the diaphram on the IAC is open the idle will jump.
disabeling it will close it, BUT the car will not drive right, the a/f will be all over the place.
plug the IAC vaccum hole with your finger when the car is running. If the idle drops to normal then you know it is shot.
or, if you cant do that. Restricte the amount of incoming air by placing your hand over the TB and see if the idle goes down.
Good luck
Old 07-13-2004, 12:24 AM   #11
blaznc
Member#: 41862
0000 99L 2.2T, dead
The car ran fine with the stock ecu and idles funny with the Link. It is not the IAC.
Old 07-13-2004, 08:45 AM   #12
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
When you bought the Link Plus it was for a 2.5 correct?
What year?
Did it come with a PNP harness,and are you using that?
-Tod
todnar is offline   Reply With Quote
Old 07-13-2004, 10:52 AM   #13
Unsung Boxer
Member#: 37196
(speak=speek?)
Just because you disable something and the car behaves differently does not make that componant the culprit. I laugh because you are so cocksure of yourself, and post as if is common sense. There are many things that effect idle, and if you read my explanation, you would see an actual diagnostic approach, not just a spastic theory.
OH, what do we have here... if the IAC is "obviously shot" then how come the stock ECU can control it and not the Link???
As so well put by yourself before... think before you 'speek' idiot
-Jake
Old 07-13-2004, 11:22 AM   #14
sidewayz
Member#: 5810
2001 S366 2.5RS
well when a thread is titled such as this , what do you expect? With no other information to go by and only a second to reply, that was a quick one.
No need to birate me on 2 occasions. take it to pm as I have done such. ok mr spelling bee.
Old 07-13-2004, 08:34 PM   #15
Unsung Boxer
Member#: 37196
I would love to send you a PM, but you seem to have it disabled. You dont have to cry just because I disagree w/ you... and happen to find it a bit humerous...
At any rate, to keep this thread on topic, the IAC is not likely the cause of your problem. This is a prime example of examining a system to see how it works, and not just condeming one componant based off of a hunch.
-Jake
Old 07-13-2004, 08:53 PM   #16
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I unpluged my IAC just like the TEC 3 manual says. I wonder if mine is shot as well?
subiekid is offline   Reply With Quote
car runs horrible with maf plugged in but fine when not SethV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 06-15-2009 09:21 PM
Urgent help needed: Car will not run with MAF plugged in. Carter Alaskan Impreza Club Forum -- AKIC 11 02-25-2009 09:49 PM
Need urgent help: Car will not run with MAF plugged in. Carter Normally Aspirated Powertrain 10 02-25-2009 09:47 PM
wtfsauce? Car runs better in diagnostic mode then not? eodtech Open Source Reflashes 0 04-29-2008 03:47 PM
Turned the car on before putting MAF plug in Mdub Newbies & FAQs 2 08-01-2007 12:25 AM
