Old 10-22-2000, 05:41 PM   #1
shabby
Member#: 2682
93 Eagle Talon AWD
Post How much hp can the EJ20 support?
How much hp can the turbo'd EJ20 support on stock internals? 300 hp, 350, 400?
shabby is offline   Reply With Quote
Old 10-22-2000, 10:05 PM   #2
jackwei
Member#: 233
Post
sky's the limit, if your bank account also has the same limit
jackwei is offline   Reply With Quote
Old 10-22-2000, 11:49 PM   #3
Andy_T
Member#: 502
Post
Paul Rosche used to get upwards of 1,400 bhp out of a BMW four-cylinder for F1 purposes (the same block you find in a mid-80's 318i). So I guess you limit is, as suggested above, money, and the amount of bomb-proof cladding you fit into the engine bay .
Andy_T is offline   Reply With Quote
Old 10-23-2000, 02:45 AM   #4
N/A
Member#: 133
TBA TBA
TBA
Post
It's more realistic to ask how much the drivetrain can take. Which if you were to ask nobody could really answer. The stock RS tranny seems to be weak but fixing that only leaves the driveshafts, axles, and diffs.
N/A is offline   Reply With Quote
Old 10-23-2000, 05:41 AM   #5
Jay_UK
Member#: 296
Post
In response to his actual question.. (stock internals)
It depends on what EJ20 you are referring too ?
I would say mid 300's.. tops!.. more like 330... But that wil be replaced bolt on goodies.
J.
Jay_UK is offline   Reply With Quote
Old 10-23-2000, 09:35 AM   #6
shabby
Member#: 2682
93 Eagle Talon AWD
Post
Im basically talking about the EJ20 found in the new turbo'd impreza's.
Is this the same engine found in the older turbo'd impreza's too? Or does the new impreza get a new/stronger EJ20?
How Much Hp Can The Stock 2.0 Hold?? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-25-2009 03:15 PM
How much hp can the manual trans in a 99 GT handle? adgenet Legacy Forum 8 04-20-2004 09:11 PM
How much HP can the 02 AT WRX hold? GabooN Transmission (AT/MT) & Driveline 4 04-02-2004 10:43 PM
how much hp can the stock bottom end handle WRteXmeX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-10-2002 01:51 AM
How much HP can US EJ20 internals support? Baluchitherium4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-25-2002 08:35 PM
