Old 07-10-2004, 11:51 AM   #1
surefooted
Member#: 39662
2008 OBP STi
2012 WW Evo X
Default Where to get instructions on cleaning a HKS BOV
Hi,
I bought a used HKS BOV and need to take it apart and clean it. Where can I find instruction on this? Thanks in advanced.
surefooted is offline   Reply With Quote
Old 07-11-2004, 02:23 AM   #2
Silver WRX 420
Member#: 37498
2002 PSM WRX w/
JDM STI V7 motor swap
All I had to do to take mine apart was remove the c clip that holds the BOV to the mount and then remove the cover that holds the insert(allen wrench) and you should be good to go from there...check the o ring while you are in there too
Silver WRX 420 is offline   Reply With Quote
Old 07-11-2004, 06:14 AM   #3
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
does it really get that dirty inside, and affect performance alot? i just got one the other day and was wondering how i should maintain it...
also...how did you tighten down the last bolt on the right? i didnt have any ratches that would clear the bov, so i had to use a wrench..
AK_2002_WRX is offline   Reply With Quote
Old 07-12-2004, 09:36 AM   #4
surefooted
Member#: 39662
2008 OBP STi
2012 WW Evo X
Thanks Silver WRX 420
AK_2002_WRX- to tighten it I use a 12mm wrench.
Where to get info on Konig Wheels and what offset to use with springs? Kwyjibo Brakes, Steering & Suspension 7 12-15-2002 10:50 PM
where to get stick on side markers?? jakester Interior & Exterior Modification 0 04-10-2002 10:59 PM
SVX 6-Cylindar Engine- Where to get info on it? daytonians General Forum Archive 7 09-15-2000 02:30 PM
Where to get deal on springs/shocks Rubasu General Forum Archive 0 06-12-2000 10:49 PM
