#1 |
Member#: 3618
it seems to me that i've heard people having the best luck with a 5:1 rrfpr for mild boost applications 5-8 lbs jus trying to confirm this. also wondering what fuel pumps seem to work the best for the same set up. and are exterior fuel pumps too loud or should a guy go for the in tank style. thanks for the help.
#2 |
Member#: 2188
Vehicle:2004 Impreza STI 82 BRAT with 12 in. lift |
I have a 4:1 and my SAFC enrichment rises up to about 14% at it's peak. I am sure with a 5:1 I would have it leaned out a bit so a 4:1 or 5:1 should get you to just either side of the desired fuel curve.
#3 |
Member#: 216
I have a 5:1 rising rate regulator, it's a begi type that doesn't start working until around 5 psi. So my fuel pressure is:
0 psi 40 lbs 1 psi 41 lbs 2 psi 42 lbs 3 psi 43 lbs 4 psi 44 lbs 5 psi 65 lbs 6 psi 70 lbs 7 psi 75 lbs Well you get the point. I'm using this one because I heard (a long time ago in a post from Shiv) that we don't really need any extra fueling until your running higher boost levels. It seems to work well for me. I'm also using a supra tt fuel pump, it's a venom performance rebuilt pump and it works nicely and is quiet. Pretty easy to install too. |
#4 |
Guest
Member#:
walboro fuel pumps are great.
im useing a 4.1 rrfpr,vortech |
| Thread Tools | |
| Display Modes | |
| Rotated Turbo (No turbo inlet) QUESTIONS | Stiguy34685 | Factory 2.5L Turbo Powertrain | 2 | 03-19-2009 07:20 PM |
| avcs swap or new turbo+accesories? | bradze | Subaru Conversions | 4 | 11-24-2008 10:03 PM |
| FS: WA turbo accesories and more | gmulid | Engine/Power/Exhaust | 2 | 05-22-2007 02:53 AM |
| 2.2 turbo and non turbo head questions | legacydreamz | Built Motor Discussion | 2 | 03-28-2006 06:18 PM |
| Turbo owners-question in the Newbie forum. | lucien2 | Legacy Forum | 0 | 04-05-2001 07:24 AM |
