Old 02-10-2001, 12:19 AM   #1
antonRS
Member#: 7
Question AWD .. stuck?
i was in an empty parking lot but the snow+ice surface was too high and my car was stucked (99RS 4eat). I tried rolling the car back and forth trying to push the car out... while doing this, i looked out at my front and rear wheel. The front is moving, BUT the back is - n o t -
is my RS a FF? emm.... ???
anyways, as I was rocking the car back n forth, it finally got out, however, the (ABS) light came on.
I recall that we discussed about the 90/10, and 50/50 power distribtution b/w stick & slush... but if my front tires lose traction, it *should* transfer power to the back right? Or is it because the snow+ice is so high that my car is lift up? ...
Pls help me out...
antonRS is offline   Reply With Quote
Old 02-10-2001, 12:54 AM   #2
V6
Member#: 2703
Y2K GC8
Silver forever
Post
As people mentioned before, for AT, gear one is 50/50
V6 is offline   Reply With Quote
Old 02-10-2001, 06:34 AM   #3
dandbest
Member#: 1885
Post
Anytime youre stuck, put the shifter into 2nd gear. That on the autos, bypasses 1st, so its much easier to get out. Its in the owners manual. Also, don't worry about the ABS light, it will go away. Some snow/ice must of gotten stuck by the sensor on the rotor. It has happened to me before.... Dont worry
Danny
dandbest is offline   Reply With Quote
Old 02-10-2001, 07:21 AM   #4
Gambit
Member#: 102
Post
should've gone out and dig. your car was prolly "lifted" off the ground. Anyways glad u're ok.
Gambit is offline   Reply With Quote
Old 02-10-2001, 01:25 PM   #5
Black98RS
Member#: 786
Post
Yes AWD works in reverse, too.
Trust me, I know.
Black98RS is offline   Reply With Quote
Old 02-10-2001, 02:29 PM   #6
antonRS
Member#: 7
Arrow
emm... thats what i thought too!
however, while i was stuck last nite, my friend was standing beside my car, and he said that all 4 wheels were moving when I am goin forward, but when going backward, only the front wheel is moving
even if my car is lift up by the snow - all 4 wheels loose traction, they will still spin right?
Old 02-11-2001, 12:12 AM   #7
antonRS
Member#: 7
Post
thanks guys!... how about in reverse? AWD suppose to work in "R" too right?
Old 02-13-2001, 07:53 PM   #8
Section 8
Member#: 821
Post
Hello,
Unless you have modified your car so it has three locking diffs, all four tires will not spin under low traction conditions, open diffs lead to spinning and stationary tires.. Next time it happens, have your friend check the other side of the car, the passenger tire was probably spinning. In sever conditions while spinning tires fiersly, you will have essentially 2 wheels driven with open diffs (and the stock "locking" diff). Put a locking diff in the rear (as in the newer RS's and people wo have upgraded theirs) you get a worst case of three wheel drive.
Greg
Section 8 is offline   Reply With Quote
Old 02-14-2001, 06:17 AM   #9
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Post
Just a little clarification. On an AWD car with open front and rear differentials and a "locking" center differential, the car is really two wheel drive unless traction is equal on all four tires. One front wheel and one rear wheel will have most of the torque. On the 2000 model year RS the rear differential is limited slip (viscous coupling) so this car is actually three wheel drive unless the traction is equal on all four tires. If you install a limited slip front differential on a 2000 RS then the car will be true four wheel drive requardless of the traction difference between any tires. Open differentials send power to the path of least resistance.
[This message has been edited by subarumantoo (edited February 14, 2001).]
subarumantoo is offline   Reply With Quote
Old 02-14-2001, 07:54 AM   #10
mhj
Member#: 3057
Post
I had this exact same problem on my '90 legacy (4eat). I was trying to get out of an icy parking spot in reverse, but only the fron wheels were spinning. I know this because I got out of the car and saw that the rear wheels were both dry while the fronts were wet from spinning in the ice. THis was both in forward and reverse (i tried all gears).
I checked the Tranny codes and found a 'Previous' problem with the 2 VSSs, but not 'Existing' problem. (if you know about the procedure for checking tranny codes you'll know what i mean). Do a search in the SVX forum and you'll find the method for checking this (although I don't know if it applies to Imprezas, it's easy enough to try out)
Someone posted the message
mhj is offline   Reply With Quote
Old 02-14-2001, 09:28 AM   #11
Jessie James
Member#: 2072
Post
When I got stuck in the snow last weekend, and was high centered on a snow bank, all four wheels spun in 1, 2, and R gears.
Would have been nice if I was on the ground. 0WD was what I got...
Mac
Jessie James is offline   Reply With Quote
Old 02-14-2001, 08:50 PM   #12
antonRS
Member#: 7
Wink
Thanks guys for ur explainations! Do u guys agree that the AWD system on a 5-spd is better than an auto since it's 50/50?
and also, what are the differences b/w the 4EAT on a 99RS and on a WRX? Thanks!
edit-> got the answer from the other post: 45/55
[This message has been edited by antonRS (edited February 15, 2001).]
subie shop with awd dyno for sale speed industry Mid West Subaru Owners Club Forum -- MWSOC 14 04-14-2011 12:32 PM
FS : 96 Impreza GM: AWD, Manual, Coupe. PCSkiBum_21 RMIC Private Classifieds 10 09-05-2010 05:42 PM
Who has gotten stuck so far with our Invicible AWD? reddevil North West Impreza Club Forum -- NWIC 185 12-30-2008 05:52 PM
Stuck in snow, no AWD WTF!!! jordanderson Newbies & FAQs 37 12-22-2006 07:14 AM
4EAT Stuck in AWD? arcsound Transmission (AT/MT) & Driveline 3 11-19-2003 06:43 PM
Message Board Statistics All times are GMT -4. The time now is 06:11 PM.
