Old 10-20-2000, 06:16 PM   #1
mms4ba
Member#: 1200
FREE OLMEK
Bureau (-=FOB=-)
Angry Solid lifters?
My car was in the dealer for a ticking noise on startup. They say as the car has solid lifters, and not hydraulic, the sound is NORMAL and there is no problem.
(ME)Q: Why then, have I just recently started hearing this noise upon cold startup?
(DEALER)A: It's the engine breaking in. You have some miles on it (50,000).
IS THIS BS????
Matt
mms4ba is offline   Reply With Quote
Old 10-20-2000, 06:26 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
What year and model is your Subaru?
ColinL is offline   Reply With Quote
Old 10-20-2000, 06:27 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Nevermind, saw your other post. The DOHC EJ25 is indeed solid lifter. There are no lifters in the SOHC EJ25.
Old 10-20-2000, 06:33 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Oh, and by the way there is a tolerance limit for valve lash. You could demand that they inspect it and if it's out of tolerance they will shim it back to the minimum lash. Unfortunately if they pull the valve covers and it's within tolerance you're out some bucks for their time.
Old 10-20-2000, 08:00 PM   #5
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Exclamation
Here is some news that will blow your socks off. Did you know that Subaru first offered the EJ25 in 1996? Yep. It was an optional engine only available on the Legacy Outback wagon with AWD.
Now for the kicker. The 2.5 that was offered in 1996 was quad-cam and had hydraulic lifters!!!! 1996 was the only year that the 2.5 came with hydraulic lifters. If you could find one of these motors it would be a rare find.
ARG
ARG is offline   Reply With Quote
Old 10-20-2000, 08:59 PM   #6
mms4ba
Member#: 1200
FREE OLMEK
Bureau (-=FOB=-)
Post
Thanks ColinL
I think i'll skip the tolerance inspection...the noise is only when it's cold on startup for a few minutes. It was just that I'd never heard the noise before, however slight.
Do you agree with the Subaru Rep, that this is normal? Or do you think (like I do) that he just doesn't want to touch it because it has 50K (almost out of warranty)?
Thanks
Old 10-20-2000, 09:29 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
If it's only on cold startup it is probably NOT valvetrain noise. If it were valvetrain noise, it would probably make that noise when warm and at idle.
Have them look at the belt tensioners.
Old 10-21-2000, 09:54 PM   #8
SubeTek
Member#: 1714
1999 RS-T COUPE
Post
I've also seen some 2.5's with noise when cold- the cause was piston slap. Not an uncommon problem due to the pistons having very short skirts, thus causing them to rock ever so slightly in the bore until the piston/cylinder heat up and expand.
Bret
SubeTek is offline   Reply With Quote
Old 10-22-2000, 12:16 AM   #9
Ken S
Member#: 1895
05 Leg GT Ltd. W
Post
Yep, the 98 DOHC have solid lifters that make noises when cold. They also use shims to adjust the clearance which adds to the noise as well. I wouldn't worry if it goes away after a few minutes.
As for the piston slap, that's a real problem. I had that happen in my 2.5 DOHC and had the dealer swap out the pistons with "countermeasure" pistons that are supposedly machined to tighter tolerances. The hard "tapping" that was indicative of piston slap was fixed using these different types.
Ken S is offline   Reply With Quote
Old 10-22-2000, 02:42 PM   #10
XT6Wagon
Member#: 524
04 STi
Post
Um, Avoid the 96 EJ-25, as they SUCK. They have the lowest power output of any of the 2.5L motors, require premium, and from what I have heard are just waiting to puke.
XT6Wagon is offline   Reply With Quote
hydraulic lifters or solid lifters??? keihacker Legacy Forum 0 02-11-2008 08:33 PM
Solid lifters with hydraulic underneath? reddevil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-20-2006 01:17 AM
Why do Subarus have solid lifters? Dale_K Newbies & FAQs 6 01-19-2005 04:42 AM
solid lifters question suberboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-13-2002 05:01 PM
WRX Solid Lifter Service Interval DammitBevis Normally Aspirated Powertrain 9 01-17-2001 02:37 AM
