Old 10-19-2000, 05:15 PM   #1
mikesoob7
Member#: 2500
Cool Knock Sensor
Does anyone know of another knock sensor for the 2.2 liter engine? I definitely have problems with it but I'm afraid there would be no difference if I got another from Subaru.
Mike
mikesoob7 is offline   Reply With Quote
Old 10-19-2000, 05:50 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
I hear tell you can put one in from a 2.5 engine... couldn't hurt to ask the local parts department guy.
Old 10-20-2000, 05:56 AM   #3
gumball
Member#: 1209
Post
The Subaru TSB on hesitation doesn't reccommend replacing the knock sensor, it reccommends replacing the ECU under warranty. That seems to imply its the filtering/listening circuitry that's at fault. The piezoelectric mic just picks up whatever its supposed to. It the ECU that's really over-reacting.
gumball is offline   Reply With Quote
Old 10-20-2000, 06:16 AM   #4
Scooter
Member#: 75
Post
Excellent gumball, couldn't have said it better myself.
Scooter is offline   Reply With Quote
Old 10-20-2000, 06:44 AM   #5
mikesoob7
Member#: 2500
Question
Do you know of a technical document online I can reference when I go to the dealer?
Mike
Old 10-20-2000, 03:28 PM   #6
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Smile
I also get a bad hesitation in my 98 OBS ever time I get the oil changed! They have looked at the car many times, and replaced a number of things....nothing helps. Where exactly is the knock sensor? I told them to put a little less oil in the car this time. After going for a test drive a few days later, the car had more oil than they put in. Not a good sign. However today they pressure tested the car, and everything seems fine according to them. Just to shut me up, they ordered a new pressure regulator.
Ru fan is offline   Reply With Quote
Old 10-21-2000, 05:57 PM   #7
Italiano
Member#: 2137
a 6spd Manual
Acura
Wink
I have a 97 2.2
I too had annoying hesitation for the first week after every oil change, took it to many Subaru dealerships here in CT, every service manager/mechanic i spoke to said "They had never herd of such a complaint or of the service bulliten." Basically everyone thought i was crazy, but that really didn't do much to resolve my problem,
So i got a MY00' knock sensor.....(it has been slightly changed from the MY97' knock sensor) and replaced the knock sensor.
It has behaved nicely since, just an occasional slight hesitatation usualy the day after the oil change, is all i get.
The Knock Sensor cost me $42.36 and probably the worst 1/2 hour of my life....it's a real pain in the you know what to replace, due to it's location.
Hope this gives you guys another option
-Domenic
p.s. I was way past my 36k warranty, I highly doubt i would want to pay out of my own pocket for a new ECU!
[This message has been edited by Italiano (edited October 21, 2000).]
Italiano is offline   Reply With Quote
Old 10-22-2000, 01:38 AM   #8
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Lightbulb
I'm pretty sure someone mentioned this before...a lot of you where having this problem after changing oil.
What if filling the empty oil filter is causing the knock sensor create hesitation?
The next time some with hesitation problems changes their oil, fill the filter first and see what happens.
D. Neil Crawford
Reciprocity is offline   Reply With Quote
WTB: wrx or STI knock sensor 94Tleg Private 'Wanted' Classifieds 4 06-05-2010 04:41 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
knock link or msd knock sensor? wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:21 PM
