Welcome to the North American Subaru Impreza Owners Club Friday September 19, 2014
Old 10-19-2000, 01:39 PM   #1
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post Does anyone knoe a company that reworks ihi turbos..
i am looking to get mine hybrided perhaps change the compressor wheel or something to make it push more boost more efficiently?
bill harvey is offline   Reply With Quote
Old 10-19-2000, 01:56 PM   #2
Tim Prudence
Member#: 216
Post
Bill, this is an email I got back from Majestic Turbo in Texas. They rebuilt Skidazzle's turbo with a larger compressor from an 80's Thunderbird turbo coupe:
Dear Tim,
We can do. I suggest a T3/T4 hybrid. Please
call so we can discuss options, so we can
give you an accurate cost estimate. Our
1-800-231-5566# runs 8-5, M-F, CST. Please
ask for Robert, Anita, or Kevin.
We offer one day service, no charge diagnosis,
pay gorund freight one way (in US), and accept
major credit cards. Hope to hear from you soon!
Original Message:
Date: Thu, 21 Sep 2000 12:08:59 -0700
Subject: turbo upgrade for IHI-RHB52
Hi,
I'm using an IHI-RHB52 turbo that originally came as an OEM part on a 1994
Subaru Legacy turbo (5spd, 4wd). I'm using this turbo on a 1999 Subaru
Impreza 2.5 RS. My engine is 2.5L and the Legacy I got it from was a head
restricted 2.2L.
My main concerns with this turbo are:
Excessive back pressure
Inability to build more than 6-7 psi at high rpms (from 5000 to 6250
redline)
What can you do for my turbo?
Could you please estimate prices for various performance upgrade packages?
What kind of turnaround time is expected with an upgrade?
Thank you,
________________________
Tim Prudence
Tim Prudence is offline   Reply With Quote
Old 10-19-2000, 02:00 PM   #3
Tim Prudence
Member#: 216
Post
I never called them because I'm too impulsive, and I'm trying to curb some of my car related expenditures. I will be doing this sometime though, probably sometime after the holiday season.
Old 10-19-2000, 02:14 PM   #4
bill harvey
Member#: 10
Garnet red pearl
Post
keep me updated i am running the same turbo and have the same problems with not enough boost and the impulsiveness thing also
Old 10-19-2000, 03:23 PM   #5
Tim Prudence
Member#: 216
Post
You got the turbo on already? The JC sports kit, right?
Does that kit come with an intake or exhaust replacement? If not, I'd go this route first, you'll gain much more power by eliminating restrictions and increasing boost than by just increasing boost alone.
The turbo is good for somewhere around 230 horsepower. With the larger compressor that Skidazzle is using (and many Miata guys, there's a Miata kit that uses the IHI) it's good for around 260 hp. That's probably enough to keep most of us happy, and that upgrade doesn't cost much (think it's around $500). Hope that info helps.
Old 10-19-2000, 07:16 PM   #6
bill harvey
Member#: 10
Garnet red pearl
Post
i don't have the turbo in hand yet and i already have the exhaust and the intake taken care of. i just want to make the turbo operate cooler and more efficient at 7psi or so
Old 10-19-2000, 07:45 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Tim,
It's a turbo kit, not an exhaust kit. So we do our own exhaust, but it does include the intake.
The legacy turbo runs pretty cool with an intercooler vs the smaller IHI loyale turbo, and if you want the car to last forever, you'll wanna stay with the 230 hp 7 psi kit
However, I am told it can push 8-10 psi with an electronic boost controller. Hmmm....
Larry www.ImprezaRS.com
PS: We will be adding my intercooler sprayer on 10/28/00 when I upgrade my clutch. That should help lower the intake charge temps from the small turbo at higher psi's...
[This message has been edited by ImprezaRS dot com (edited October 19, 2000).]
ImprezaRS dot com is offline   Reply With Quote
Old 10-20-2000, 05:18 AM   #8
NateP
Member#: 2414
Post
The only company I would deal with for turbochargers is Forced Performance in Texas. Rest assured when the Rex comes over, Robert will have something wild for it. http://www.forcedperformance.com
He can rework any turbo, into whatever you want, and also custom fab tons of parts.
NateP is offline   Reply With Quote
Old 10-20-2000, 10:12 AM   #9
Tim Prudence
Member#: 216
Post
Mr. dotCom,
Yes the IHI can push 8-10 psi, but that's misleading. I've run with the pressure line to the wastegate disconnected (I know, not a good idea), and have seen boost rise up slightly past 10 psi in the lower rpms (below 4000). However, even with the wastegate completely shut (as in this case) this turbo WILL NOT provide more than 7 psi at redline (and even that is only in 4th and 5th gears). An electronic boost controller will not allow you to bypass this problem.
Old 10-20-2000, 10:27 AM   #10
Dan_E
Member#: 673
1999 2.5RS-T <RIP>
2000 RS-TURBO'D
Lightbulb
Check out www.majesticturbo.com Not too much info online, but call them up...good prices!
Dan_E is offline   Reply With Quote
Old 10-20-2000, 10:34 AM   #11
Jay_UK
Member#: 296
Post
Not being awkward here...but..
When you guys talk about boost and max psi .. at what rev/flow are you talking about..
Sure a turbo might make 12/14/40 psi.. but at what flow/rev range ?
You might find you have to back the boost off the higher up the rev range you go, otherwise u will be way off the comp map (efficiency) of the turbo... and will be killing the turbo and heating the intake too much.
When looking for a turbo... look at the comp maps, etc.... do some simple calcs... work out the flow rates at certain revs and boost.... and see where it puts you on the map.
J.
Jay_UK is offline   Reply With Quote
Old 10-20-2000, 11:17 AM   #12
Thug
Choke Artist
Member#: 603
Post
Bill, did you ever check with TRE?
Thug is offline   Reply With Quote
Old 10-20-2000, 03:12 PM   #13
bill harvey
Member#: 10
Garnet red pearl
Post
no nate never checked with them still waiting for that slap you primised if i didn't check with them
Old 10-20-2000, 10:56 PM   #14
Thug
Choke Artist
Member#: 603
Post
Sure Bill, any time you want it. Wait a minute, would that be assaulting a police officer???
Old 10-21-2000, 11:11 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
Post
Well,
I am told by an experienced Subaru mechanic that I should limit my MY00 to 7 psi anyways, or I will have problems with the drivetrain, expecially above 10 psi.
I am happy with an IHI that will only do 7 psi max, and want to focus on reliability. Going from 165 hp to 230 hp is fine with me
I think it would be nice to cnsider re-working the turbo someday. How do they do a T3/T4 hybrid with an IHI though, I don't understand?
Does anyone know the person that currently owns that Trust DD exhaust on nasioc? rites General Community 4 12-12-2006 11:08 PM
Does Anyone Knows A Company That Does Retro Fittings? spliffpirate Electrical & Lighting 4 07-16-2004 11:58 AM
Does anyone know this guy that works with me. STEALTH-WRX Southern California Impreza Club Forum -- SCIC 43 09-02-2003 09:48 PM
what happend to that fake ihi turbo thread? Turbo Tin Can Factory 2.0L Turbo Powertrain 1 03-01-2003 01:23 AM
Does anyone have a tranny that will fit a 91' Loyal??? SpamMansXe Mid Atlantic Impreza Club -- MAIC 5 02-04-2003 08:18 AM
