Old 10-19-2000, 07:54 PM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Post best setting on a Field SFC Hyper R
i seem to run way too reach on it any one know what is the best setting on a Field SFC Hyper R for stage II turbo with 8~9psi of boost?
OR what is your setting on it.
thank
ChAi is offline   Reply With Quote
Old 10-19-2000, 10:49 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
What year is your car first?
I have a MY00 NA so my settings won't be able to help you since you're turbo'd. But it would help others to help you.
Keiho is offline   Reply With Quote
Old 10-20-2000, 12:05 AM   #3
Omensan
Member#: 2726
Exclamation
Need to be FAR more specific..
For ex - you have changed fuel pump? I put on the Holley 255lph pump, and all of a sudden, fuel pressure has been bumped overall about 2 (Field SFC) points, I also have a 4:1 fuel:boost pressure riser, and that too figures in. Which intake? K&N, GReddy Airinx, stock, etc? Using anything to adjust timing? What settings on that? :-)
I'm running ~44psi WOT, 0 lbs boost, ~70psi @ 6.2 lbs boost (NICE and GENTLE.. i like my rings the way they are) and settings as follows, and ALWAYS 92-95 oct gas.
RPM - Fuel Timing
1000 - -1 +11 (800 rpm)
2000 - 0 +6 (2400 rpm)
3000 - 0
4000 - +1 +5 (4000 rpm)
5000 - +3
6000 - +4 -1 (5600 rpm)
7000 - +5 -5 (7200 rpm)
8000 - +5
Take these figures with a BIG grain of salt. This is based on a (first-flight) DOHC '98 RS with original MAF, and a Mavtech Safeguard (just in case the air is JUST dense enough to encourage a ping or two...)
This seems to provide a good, even, smooooth increase in power (despite the darn T03/04 boost curve).
Good luck, and if you blow a motor, don't blame me. If anyone has any constructive suggestions, I'm open for them too! (I know, I should replace the ECU with a custom-programmable and all, but i'm not that rich right now.)
-JCS, San Diego, CA
Omensan is offline   Reply With Quote
Old 10-20-2000, 10:18 PM   #4
ChAi
Member#: 1277
1999 Minnam Stage 2
Post
i have 99 impreza 2.5RS
i have a question for you Omensan. i have a 2.2L WRX turbo fuel pump. WRX owner assume that it can pump up to 2~4 bar(28~56 psi)of pressure. I don't think they know the pressure of the pump very well.
i don't want to install it coz i don't have a fuel pressure riser/REGULATORS , and i don't want too much pressure in the fuel line.
what should i do install it with out REGULATOR?
is it going to pump to much pressure?
Old 10-21-2000, 10:54 PM   #5
Omensan
Member#: 2726
Post
the stock RS pump is a 155lph model, max (real flow) pressure in the 70's psi, the replacement I bought is a 'size identical, harness identical' from Holley, 255lph in the 80's psi
max pressure for both pumps is well over 100psi, but the flow significantly drops past 95 or so.
the regulator on the RS is on the fuel rail, a simple system, you don't need to worry about the pump you put in. Shiv Pathak put in one from a Mazda RX-7 (VERY high flow..) and his WOT (0 lbs boost) pressure went from 42psi (stock) to 45 psi (whoopie!)
the big difference --> the stock regulator is a 1:1 pressure riser, i.e. hooked up to the intake vaccuum (boost), it gives 1 psi per one psi of boost... WAY inadequate for those of us running boosted 2.5's on the stock 320cc injectors. (so i've been told..)
i also put in a 4:1 'rising rate' regulator.. it is passive until it sees boost in the intake, then starts a 4psi per pound of boost pressure increase (by throttling the output of the stock regulator). it's a much more inexpensive solution (albiet somewhat jerryrigging...) than buying a whole pressure regulating setup to replace your stock system in it's entirety.
at 4:1, it REALLY goes rich under boost, which is good. if it's really too rich, i use the AFC to tone it down a notch or two, but it's really not necessary. runs fine, no rich-smelling exhaust, no smoke, nuthin. seems pretty well tuned as is. You can get any spring rate you want (up to 15:1 i think) for the downstream-regulator, that would be a little too rich for me ;-)
AS FOR the '99 rs, i'm told that due to small differences in the MAF and ECU, that the turbos tend to run a little leaner, and some folks even recommend an 'additional injector setup' to make up for it.. i'm not sure it's necessary with proper fuel pressure management (bearing in mind that most injectors won't function above 95psi or so).. I'd think that you would be safe with the bigger pump, and a downstream rising-rate regulator/restrictor.
FOR NOW, with the stock pump, even with an intercooler, i'd not be running more than 5.0 psi of boost... you're badly risking detonation :-) (yes, i've lost rings already...)
The pump changeout takes less than an hour with a single screwdriver, It's worth the effort for the added pressure of even a wrx pump :-)
---JCS
San Diego, CA
Old 01-19-2004, 04:36 PM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Question Oldy
Yeah, this is old as hell but I have a question about it.
Those of you that have this on an N/A Subaru, could you please tell me what your settings are?
I'm specifically talking about the 'Car Type Setting Switch(#s 1-8), and the 'Speed Switch' (#s 1-4) on the back of the unit. I plan on installing it but want to get it right the first time.
The only two switches I have set to 'ON' are #2 in the 'Car Type setting' and #4 in the 'Speed Switch' setting. Thanks!
Kevin Thomas is offline   Reply With Quote
Old 06-10-2011, 01:57 PM   #7
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
Question
jay_parot is offline   Reply With Quote
Old 06-10-2011, 02:33 PM   #8
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
this is in the incorrect forum.
Admin please move.
Rudgers73 is offline   Reply With Quote
Old 06-10-2011, 02:34 PM   #9
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
Question
Admin please move.
so where should i ask for ????
Old 06-10-2011, 03:54 PM   #10
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
rs25.com
awdorgtfo is offline   Reply With Quote
Old 06-10-2011, 04:00 PM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Or the engine management forum
Old 06-10-2011, 04:09 PM   #12
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
i did no one answer and here you guys whjere talking about it so thats why i ask .....
Old 06-10-2011, 08:49 PM   #13
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Ok, I'll allow it. But if an admin catches us we're all dead!
Old 06-11-2011, 09:25 AM   #14
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I heard that once a Moderator killed a member for calling them an Admin.
Old 06-11-2011, 09:43 AM   #15
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I remember this one time, a thread was started in 2000, and then it was bumped 3-1/2 years later, and then it was bumped 7-1/2 years later, and in the meantime it had been put in the wrong forum when NASIOC was re-organized years ago.
Old 06-11-2011, 10:16 PM   #16
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
So I Ask Again Can You Please Give Me The Wiring Diagram I Need To Know What Wire Goes To What Fron The Field Please ????
Thanks Guys
Field SFC hyper and Jumptronic air/fuel monitor jkyes Private 'For Sale' Classifieds 10 08-29-2003 05:12 PM
Need wiring info for Field SFC Hyper fuel computer dead-eye Electrical & Lighting 0 06-23-2003 07:14 PM
Field SFC Hyper-R fuel maps Mirage Normally Aspirated Powertrain 0 06-19-2003 03:45 AM
field SFC install?? please help spunky General Forum Archive 3 12-28-2000 04:08 AM
Apex'i S-AFC vs. Field SFC inzomniak Vancouver Impreza Club Forum -- VIC 5 12-11-2000 11:37 PM
