Old 07-11-2004, 01:55 AM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Default options for ecu management?
I have a 98 2.5rs dohc and its geting headgaskets replaced so I figured id turbocharge it while its in the shop, but my concern is what do I do about my stock ecu? Can it be reflashed by anyone who watches tech tv or this something that takes lots of hardware to adjust, does anyone know of cheap ecus or piggybacks for my car that are programable what are my options...
BTW: what damage could be caused from turbochargeing my rs without runing a programed ecu?
2.5rsDOHC is offline   Reply With Quote
Old 07-11-2004, 02:05 AM   #2
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Hydra EMS or Link plus
NeaD is offline   Reply With Quote
Old 07-11-2004, 02:34 AM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Default Re: options for ecu management?
Best line evAr.
subiekid is offline   Reply With Quote
Old 07-11-2004, 12:18 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
On a 98 you can run up to 6-8 psi and use an SAFC, with good results.
I run 11 psi of the stock ecu with an safc and j&s knockguard. EGTs get a little to high when im really on it so I have to keep the right foot in check. I also have a 2.2t shortblock.
I wouldnt run much more than 8 on a stock 2.5 bottom end.
HTH
jay
Old 07-11-2004, 02:03 PM   #5
NeaD
Member#: 43371
Hydra User, Blue
I'm running 8 psi in my 98.
Old 07-11-2004, 03:49 PM   #6
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
I appreciate everyones input I belive I can make my mind up now but what does SAFC stand for
Old 07-11-2004, 06:31 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Super Air Flow Converter.
made by APEXi
Next step up from that would be a Greddy Emanage, just a bit more money but has alot more features, but requires a lap top and real tuning.. as in dyno, or wideband tuning..
Jay
Old 07-11-2004, 06:33 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
http://www.apexi-usa.com/electronics_safc.asp
looks like the havent updated their site, but thats the orig SAFC, they now have the SAFCII it has more functions and more precise tuning.
Jay
Old 07-12-2004, 03:57 PM   #9
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
This helps me out alot in my future plans to go forced induction thanks alot for the assistance and if I havent been too much trouble I have one more qustion, is there any other modifications that I should make before I run about 6-8lbs boost?
Old 07-12-2004, 05:34 PM   #10
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Should definately be thinking about a stronger clutch...maybe a promotion at work also cause trust me, it can get expensive unless your a very self controlling person unlike myself
Kyle
Andursun0013 is offline   Reply With Quote
Old 07-12-2004, 05:56 PM   #11
billyr2.5
Member#: 53663
2011 WRX WR Blue
2000 Coupe, Sedona Red
i have a safc too, and i'm turboing my rs and really the afc helps w/ an ej25 t? if it matters i have a MY00 2.5rs.
billyr2.5 is offline   Reply With Quote
Old 07-12-2004, 06:45 PM   #12
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
billy
a 2000 ecu will learn around the SAFC.
You might want to look into a gready emanage, and j&s knockguard, if you dont want to go full standalone.
Jay
Old 07-21-2004, 02:03 AM   #13
billyr2.5
Member#: 53663
2011 WRX WR Blue
jay
is there any way to stop the ecu from learning around it?
billy
Old 07-21-2004, 04:54 PM   #14
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Originally Posted by billyr2.5
jay
billy
No, there isn't, but iI believe it's only an issue with newer RSs. The 98 should be fine and is probably the best car to use an AFC with.
BUT, a better alternative is to use a Greddy E-manage, which for slightly more than an AFC, you can control timing and fuel (what the AFC does). Also, the E-manage has an advantage over the AFC since it adds fuel by directly modifying the injector duty cycle as oppose to modifying the MAF signal, which can have some slight negative side effects.
Search around for info on the E-manage.
good luck.
jonathan
ilmaestro is offline   Reply With Quote
Old 07-21-2004, 07:19 PM   #15
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Also know that it depends on your plans for the build. I was going to do a Greddy E but then was told it wouldn't pull enough fuel past 10 psi-ish. and i'm looking for 15-20's once turbo, and STi block is on. WHEN, yes i know, it sucks. But cheep. this game really isn't cheep. but look on the used private for sale classifieds.
Also, where can i get a J&S? everyone seems to have them, but no one knows where one can buy one. W T F Batman? Thanks for any help.
-Eli
squirrelmasta is offline   Reply With Quote
Old 07-21-2004, 08:45 PM   #16
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Yeah... Eli's got it right. Once you start getting into the 10+psi range you're looking at needing a standalone ECU such as the Haltech, LINK, Tec units, etc.
Eli: J&S's can be purchased directly from J&S. They also pop up on ebay pretty often. Check their website and send them an e-mail. John from J&S posts here every now and then. You could try finding him and sending him a PM.
j
Old 07-24-2004, 01:51 AM   #17
billyr2.5
Member#: 53663
2011 WRX WR Blue
sweet thanks so do u guys think i should just sell my safc and by the e mang. or try to find a 98 ecu?
Old 07-25-2004, 01:22 AM   #18
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I would spend my money on a stand alone. I have a 1998 that has been turbo for two years. I have used the SAFC and a ITC. They will work alright but the stock computer doesn't have a fuel or ignition map past 0psi. So don't plan on running more than 8psi without any problems.
http://www.microtechefi.com/
You will need the LT-8
CUNNINGHAM is offline   Reply With Quote
Old 07-25-2004, 10:12 AM   #19
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
HTH
jay
HA!!!
10-12 psi, stock bottom end and over 40k on the boost!
Still going strong! (not with me anymore, but she's still good!)
Old 07-25-2004, 10:17 PM   #20
billyr2.5
Member#: 53663
2011 WRX WR Blue
do you guys think with only 6psi a 98 ecu swap would be all right?
Old 07-26-2004, 01:21 AM   #21
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
if you have a 2000 then i dont think you can swap to a 98 ecu because the 98s are MAF and DOHC, the only interchangable years i can imagine are the 00 and the 01 since the cars are the same.
Derk1127 is offline   Reply With Quote
Old 07-27-2004, 04:41 AM   #22
billyr2.5
Member#: 53663
2011 WRX WR Blue
and the 01 ecu would learn around the safc too tho right?, i'm about to just save up and do a link or some kind of standalone
Old 07-27-2004, 11:57 AM   #23
Joncas
Member#: 5349
You can get a J&S safeguard at http://www.jandssafeguard.com/
John's a good guy - real knowledgeful. Call them up and order it right over the phone.
Joncas is offline   Reply With Quote
Old 07-27-2004, 07:37 PM   #24
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Originally Posted by hondaslayer
HA!!!
shut up n00b!
My car has been turbo for almost 30k. on 11psi, stock 98 ECU, SAFC and J&S
Jay
Whats my options for engine management USMARINE24M Engine Management & Tuning 12 02-19-2006 06:36 PM
HELP!!! Need a ecu pinout for a 96 L for e-manage install! Sideout Legacy Forum 0 12-01-2005 11:04 PM
Engine management options for SVX?? Help? Porter Engine Management & Tuning 12 04-28-2003 06:31 PM
Solo2 STX - options for Engine Management ? MNbiker Motorsports 24 05-23-2002 03:33 PM
Best aftermarket ECU/management option? 2OHOH2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-05-2002 08:34 PM
