Old 10-20-2000, 06:42 PM   #1
bmt
Member#: 2731
Question SOA Supercharger?
How come no one talks about this anymore?
2.5-liter SOHC 4-cylinder boxer engine with Eaton supercharger and Subaru B4 intercooler
230 horsepower @ 5,600 rpm
210 lbs.-ft. of torque @ 4,000 rpm
This is from the STX that SOA confirmed they would build in their 9/7/00 press release.
bmt is offline   Reply With Quote
Old 10-20-2000, 06:44 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Probably because SOA said it wouldn't be offered, and because we know we're getting the turbo EJ20.
RidinLow is offline   Reply With Quote
Old 10-20-2000, 06:58 PM   #3
bmt
Member#: 2731
Post
The STX wouldn't be offered or the S/C wouldn't be offered? Why is the STX still on the SOA website?
Old 10-20-2000, 07:24 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
They better offer the STX... takes me back to the BRAT days...
Brian
http://members.nbci.com/_XMCM/northu...reza/index.htm
Old 10-20-2000, 07:24 PM   #5
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
the S/C won't be offered to us. Even if it is an EJ25 it will be built differently to handle the boost. People have asked SOA if the engine would still be under warrenty if they bought the S/C kit and were told "NO"!!
Strepto is offline   Reply With Quote
Old 10-20-2000, 07:32 PM   #6
bmt
Member#: 2731
Post
Well then, if everyone is talking about engine swaps from the new WRX, what are the pros/cons of an engine swap from the STX in '02 when it comes out?
Old 10-20-2000, 10:50 PM   #7
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Maybe we should all warn SOA how bad Rimmer is. After all I care more about SOA than I ever care about Rimmer. LOL!
Imprezer is offline   Reply With Quote
Old 10-20-2000, 11:00 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The STX engine was created and tuned by a Michigan shop and not Rimmer.
Revision is offline   Reply With Quote
Old 10-21-2000, 01:10 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Even so, you forget that that engine w/SC won't fit in the Impreza... it'll hit the hood like some of the original Rimmer kits.
Old 10-21-2000, 07:45 PM   #10
bmt
Member#: 2731
Post
You are assuming, of course, that Subaru built a completely new platform/frame to base the STX off of. Knowing engineers and corporations (one aims for simplicity and the other aims for cost-saving), whatever proven technology they can pull off of the shelf and incorporate into something new, they will. Accepting this assumption, the question is, will the STX be based on the Legacy or Impreza platform? Also looking at the specs for Eaton S/Cs from their site, the M45 and the M62 both are the same height (125.0 mm, apprx. 7 inches) with the front to back distance varying from 210-371mm and 254.5-415mm respectively. That doesn't seem like too much extra to cram into an admittedly tight engine compartment. Throw in the B4 intercooler and things get tighter, but I don't think that it is impossible to do. And finally, I would gladly replace my current hood for a S/C under a new, bumby, bubbly, scabby, scarred or just plain ugly hood. Besides, with the extra power, people would be spending a lot more time looking at my pretty '99 rear (well, maybe not pretty, but at least it's not as ugly as the US WRX rear) than my Frankenstein (scars and bolts sticking out if necessary) front.
Old 10-21-2000, 08:36 PM   #11
N/A
Member#: 133
TBA TBA
TBA
Post
The STX had was supposed to be based off of the Legacy. Which makes sense. The Rimmer and CAPA kits would all fit under the hood of a Legacy because there is more clearance from the underside of the hood to the S/C pulley. Let's also not forget that a RSK B4 top mount IC won't work on the Impreza because it would sit up too high. With the EJ25 becoming the standard engine the CAPA company will likely to be building a kit for the Impreza and the Legacy. Let's hope they do build one since they've seem to figured out the fuel management and ignition on their kits.
N/A is offline   Reply With Quote
Old 10-21-2000, 09:02 PM   #12
bmt
Member#: 2731
Post
I still can't shake the gut feeling that there will be interchangeability with the STX and previous 2.5s. The whole point, at least for me, is to have SOA put that sucker (well, blower really) in my '99 and tell me if it breaks, they will be there to fix it. Now that I read what I just wrote, that seems like a tall order.
Response from SOA on Center Differential maruksai Transmission (AT/MT) & Driveline 6 06-01-2010 07:26 PM
Supercharge or not to supercharge, that is the question. ScoobySean Normally Aspirated with bolt-on Forced Induction Powertrain 14 04-09-2006 12:06 PM
('93-'01) Rimmer superchargers jgring Impreza Forum 5 06-06-2001 01:51 PM
Eaton Superchargers Any good Supercharging a RS Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-24-2001 06:57 AM
