Old 10-20-2000, 12:12 AM   #1
merlin8019
Member#: 416
1993 Impreza GF8
Steel Blue
Post opinions on a 5spd tranny swap....
i can get my hands on a MY00 that is not repairable, the drivetrain and stuff is all good just it was rolled etc etc. RS motor and tranny(5speed tranny) along with all the ecu, rear diff, map sensor and all that good stuff is fine. should i switch over to a 00 map sensor? i have a MY99 auto right now. any opinions on if i should do this or not? is the diff on teh 2000's better then the 99's? any info about anyone thats done a tranny swap would be helpful. thanks
keith
www.marksauto1.com
merlin8019 is offline   Reply With Quote
Old 10-20-2000, 12:17 AM   #2
Digital_Boy
Member#: 730
Post
Lemme know what you want to do with all the leftovers!
My lowly 95L 1.8FWD needs a 2.5 RS drivetrain....
Digital_Boy is offline   Reply With Quote
Old 10-21-2000, 06:16 PM   #3
merlin8019
Member#: 416
1993 Impreza GF8
Steel Blue
Post
Old 10-21-2000, 06:36 PM   #4
Subu WEX
Member#: 1169
Post
How much would you want for the ECU?
Subu WEX is offline   Reply With Quote
Old 10-21-2000, 09:18 PM   #5
HillbillyRS
Member#: 2501
Wink
First off, I would definitely switch to the map sensor, but I don't know if it will work with the stock '99 ecu. I would definitely swap the tranny. And yes the differential is different. '98 and '99 had an open diff'. '00 has a viscous limited slip. Plus if you swap to a stick you'll have to swap the rear diff so that the front and rear gears are the same. Auto has 4:44. Stick has 4:11.
HillbillyRS is offline   Reply With Quote
Old 10-21-2000, 09:24 PM   #6
HillbillyRS
Member#: 2501
Post
Also I forgot to tell you that if you plan on running the rear diff you also need the halfshafts that go with it.
Want opinions on a possible suspension swap...Ohlins users wanted! keaniegenie Brakes, Steering & Suspension 25 02-27-2011 04:16 AM
good deal on a 5spd tranny, some questions about a possible swap into a 4eat RS xjordanx Subaru Conversions 1 12-03-2006 06:59 PM
Advice/opinions for Legacy motor/tranny swap kingpumba1 Subaru Conversions 9 02-20-2005 05:55 PM
5spd tranny swap spacemonkey Private 'Wanted' Classifieds 2 03-30-2004 03:26 AM
