Old 02-14-2001, 09:53 AM   #1
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Question 00 MAP and forced induction question
I recall a thread a few months ago, that I haven't been able to locate in a search about problems with the MY00 and forced induction. It seemed to relate that the MAP couldn't read the increased air volume and therefore didn't let the car get over 2 psi of boost. Does anyone remember this and if so, do they remember what the solution was? It seems like it was something simple, but I just don't remember. Thanks
Kent
Templar is offline   Reply With Quote
Old 02-14-2001, 10:07 AM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
A my00/01 needs a $0.12 4.7v zener diode on the MAP input wire and a RRFPR to run low boost. (actually this is apparently usable upto about 7psi)
Midwayman is offline   Reply With Quote
Old 02-14-2001, 10:07 AM   #3
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
you can either do a voltage clamp on the MAP so it doesn't send the signal of too much air to the ECU or you can use a bypass valve so the MAP never gets too much air
Strepto is offline   Reply With Quote
Old 02-14-2001, 03:51 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Rallispec posted the zener diode specs awhile ago. Ludespeed confirms this works like magic.
Old 02-14-2001, 05:39 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Here it is! http://www.i-club.com/ubb-files/Foru...ML/001139.html
I can't believe I missed this post.
Old 02-15-2001, 12:23 AM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
There are a couple options to get around the boost problem:
1-live with 2psi (not recommended, but free)
2-the zener diode (don't know much about this one, but I think Trey said it has voltage bleed)
3-JC Sports Torque Chip II ($250)
4-TEC II ($2000-$2500)
5-Split Sec voltage clamp (www.splitsec.com, $70)
6- FCD from J&S (Trey knows about it, $150)
7-ASR check valve ( seen at http://rave.stranger.com/Pictures/tmp/index.html , price unknown)
RRFPR is needed for all of them except #4
-Jon
After market Forced Induction GURU question??? OB2 Normally Aspirated with bolt-on Forced Induction Powertrain 5 03-23-2008 12:28 PM
forced induction is forced induction? keaniegenie Built Motor Discussion 3 03-12-2006 02:50 PM
carbs and forced induction (non-subaru specific) QfactorRS Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-30-2003 10:08 PM
California Forced Induction - C.A.R.B. questions Mizen Technical Forum Archive 15 06-29-2000 12:48 AM
questions on forced induction please help... shukes24 General Forum Archive 4 06-19-2000 05:37 PM
