Old 07-11-2004, 11:02 AM   #1
2centz
Member#: 35377
2007 GTI
Question Air pump?
Anybody have good suggestions on an air pump for tires? I'm not sure if I should go the 12V route or go for those foot operated pumps. Also, if I went the cigarette lighter route, it's not 12V DC, right?
thanks!
2centz is offline   Reply With Quote
Old 07-11-2004, 11:21 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Default Re: Air pump?
Pretty much all of the power leads you have easy access to on a car are 12V DC...
if you are just adjusting pressure a little bit this way or that (5-10lbs) anything is fine - I use a bike pump
Old 07-11-2004, 09:52 PM   #3
2centz
Member#: 35377
2007 GTI
Hey, if a bike pump works, that's fine with me! It's definitely a cheaper solution.
Old 07-11-2004, 10:08 PM   #4
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
A decent bike pump works fine. Mine is like about 5-10 pumps per psi.
brizey is offline   Reply With Quote
Old 07-11-2004, 10:30 PM   #5
2centz
Member#: 35377
2007 GTI
What do you mean by a decent bike pump?
Old 07-12-2004, 02:40 PM   #6
kenchan
Member#: 15106
I use a 12v aircompressor ($25 at Autozone?) and a 12v
power supply (was used for my RC car battery charger back
in the days...) in my garage to pump the tires up.
It can do about 1psi in 10sec...so not too bad.
Yes, the cigarette lighter output is DC, but my air compressor
can work either polarity.
kenchan is offline   Reply With Quote
Old 07-12-2004, 03:14 PM   #7
JT Clark
Member#: 38112
2003 Impreza TS
You want one meant for volume. Otherwise it could quite literally take you days to pump up a tire. Some tiny little handpumps are like this. They're fine for adjusting a bike tire, but would be murder trying to do a car tire. Even if it's not a big car tire it's many times greater than that of any bike.
JT Clark is offline   Reply With Quote
Old 07-12-2004, 03:34 PM   #8
2centz
Member#: 35377
2007 GTI
Thanks I'll stay away from the hand pumps then <as he surreptitiously sneaks the hand pump behind his back>. Joking of course, since the hand pump I have takes a long time to get my bike tires filled up.
Old 07-12-2004, 03:42 PM   #9
JT Clark
Member#: 38112
2003 Impreza TS
Yeah, if it takes long on your bike it'll be like 10x worse on a car tire. A lot of bike pumps should be plenty strong as they are built to go up over 50+ (very conservative guess) and I think many should hit near 70-80 psi at least. Probably more. I'd look for one that has a foot bar/stand. Folding even. I can't remember what bike pump I have off the top of my head, but it's small enough to mount on the bike, but still has the foot pedal (folding) and can inflate it fairly quickly. It's still going to take quite a while to do a car tire though.
Old 07-12-2004, 05:48 PM   #10
2centz
Member#: 35377
2007 GTI
Thanks, I'll take a look for pumps at a Dick's Sporting Goods or Sports Authority.
Old 07-12-2004, 11:54 PM   #11
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
I have been using the $20 compressor from Walmart for over two years, and amazingly enough it's still working. It's not very fast if you need to add large quantities of air, but it does the job. I think they also have a cheaper model for around $10.
TheWRX is offline   Reply With Quote
Old 07-13-2004, 01:04 AM   #12
aznatama
Member#: 60316
2004 STi
decent bike floor pump - $30-60
12v cig socket pump from autozone/kragen - $25-45
the bike pump might be a lil faster though.
I use a autozone 12v pump. just set it to a preset psi, and leave it there til the desired psi is reached. then check w/ a hand tool.
aznatama is offline   Reply With Quote
Old 07-13-2004, 02:13 AM   #13
AWDfury
Member#: 29819
02 wrx wagon
sedona red pearl
yup, i got the cheaper $10 one, at least you dont have to pump by foot. better than nothing.
AWDfury is offline   Reply With Quote
Old 07-13-2004, 02:54 AM   #14
wm07
Member#: 26529
04 STi
It is a good workout using a bike pump to fill up a tire. Don't ask me how I found out, but hey, now you can use the $$ you saved from paying gym money for mods! :P
wm07 is offline   Reply With Quote
Old 07-13-2004, 08:46 AM   #15
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Wanted to mentione one more thing on the Walmart compressors: Ignore the built-in pressure display, it's way off. Use a good pressure gauge to measure your tire pressure. If you use the compressor frequently, you'll have a good feel for how long it will take to add a given number of psi. I typically measure the pressure before connecting the compressor, run the compressor for a little longer than necessary, and then bleed off the extra pressure (it's normally very close already).
Old 07-13-2004, 10:08 AM   #16
2centz
Member#: 35377
2007 GTI
Dumb question- how do you bleed off air pressure in the tire? I can do it pretty easily on bike tires since I only have to put pressure on the presta valve, but I'm not sure on car tires. Also, for the hand pressure gauge, I got a cheapie from Walmart. How accurate are they? Any better than the Walmart or Autozone pumps?
06 WRX Air Pump Removal - is it safe?? Banish Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1077 02-18-2016 07:22 AM
2006 WRX Air Pump john_tran Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 02-09-2007 10:00 AM
air pump/tire inflator urgewrx Service & Maintenance 3 09-21-2006 03:03 PM
Air pump removal bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-22-2006 04:41 PM
