Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 07-11-2004, 09:31 PM   #1
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
Default anyone use stock lugnuts on rotas??
My wheels come this comming friday but i got an email saying my lugnuts are on back order for two frikin weeks and I really need to get my car rolling because im sitting on the spare right now. Does anyone know if they will work for a couple weeks or should I order lugnuts from somewhere else ? And if so where is a good place ? Thanks ..
One more thing do I need hubcentric rings ? Wheels are rota torque.
wrxsubaruwrx is offline   Reply With Quote
Old 07-11-2004, 11:04 PM   #2
BluSuby
Member#: 12154
04 Sti
99 Outback
I wouldn't use the stock lug nuts on the rota's. They are not the correct type. The stock ones mount against a flat surface wheres as the Rota's require a tapered lug nut. They are nothing special, and your local tire shop should have them.
You do not need hubcentric rings,
Bryan
BluSuby is offline   Reply With Quote
Old 07-11-2004, 11:38 PM   #3
fastsubie
Member#: 21999
2012 Wrx
Right, do not use the stock ones. Get a set of spline drives or something to protect your new wheels.
Fess
fastsubie is offline   Reply With Quote
Old 07-12-2004, 01:39 AM   #4
nqwan
Member#: 2916
02 duburu arr exu
pretty much all rota's for subaru are hubcentric now. the only ones that required the rings were the first sets that they came out with along time ago.
nqwan is offline   Reply With Quote
Old 07-12-2004, 01:40 AM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I autocrossed a few times on stuck lugs with Subzeroes. Then again I am not worried about scratching that part of the wheels... I have McGards now though
edit, that's STOCK lugs
john
Old 07-12-2004, 08:07 AM   #6
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Ok thanks guys . I guess I will have an extra set of lugs in two weeks
Old 07-13-2004, 01:07 AM   #7
dorifto88
Member#: 17684
1989 pathfinder
rusted red
somewhat OT but...
why is it bad to use aftermarket lugs on stock wheels?
dorifto88 is offline   Reply With Quote
Old 07-13-2004, 08:39 AM   #8
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
I believe you can find fairly cheap tuner type lug nuts in parts stores. I would probably get a set of those until the lug nuts you ordered come in. Then keep the cheap ones as backups, or sell them off. Shouldn't cost you very much. Lug nuts are just too important to take a risk by using the wrong type.
TheWRX is offline   Reply With Quote
Old 07-13-2004, 08:39 AM   #9
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
Is it bad?
I am planning on using my splinedrives on my stock RS wheels this winter (have rota battle right now)
Originally posted by dorifto88
somewhat OT but...
balajc is offline   Reply With Quote
Old 07-13-2004, 09:13 AM   #10
JT Clark
Member#: 38112
2003 Impreza TS
Think of fitting square peg into a round hole. Or rather trying to screw a square nut into one cut for a round nut. Check out this too. A picture can be worth a thousand words. While it's true that you can screw the bolts on tight, they will not fit right if they are not of the correct shape.
JT Clark is offline   Reply With Quote
Old 07-13-2004, 09:28 AM   #11
balajc
Member#: 15393
oh I see...thanks for the analogy. Good thing I did not throw my rusted OEM lugs away
Old 07-13-2004, 10:06 AM   #12
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Wow--lots of misinformation. A few clarifications:
1) The stock lug nuts have a 60 conical seat just like all the "tuner" lug nuts.
2) The first problem is that the total area of the seating surface is fairly small on the stock nuts
3) The other problem is that the holes in many aftermarket wheels are tight, and you can't get a 19mm socket deep enough in there.
Here is a pic of the stock nut on the left next to a "bulge" lugnut with a larger seating surface and a smaller 17mm hex to provide more socket clearance.
Jon Bogert is offline   Reply With Quote
Old 04-12-2007, 11:06 PM   #13
ShelbyLuva
Member#: 111242
2004 WRX Wagon
WRC Blue Pearl
What is the final answer? The stock ones will work, but aftermarket work better?
ShelbyLuva is offline   Reply With Quote
Old 04-13-2007, 12:01 AM   #14
rougeben83
Member#: 115154
2005 Outback XT
White on grey
They'll work, but like Bogert said, the aftermarket ones hava a wider seat area so they'll be in contact with the rim better.
I've done all the permutations, stock lugs/aftermarket rims, aftermarket lugs/stock rims, etc. I've also autocrossed and rallycrossed said setups with no problems. Not just one kind of rim; I've gone through around 4 different sets of rims on this car too
Torque them to the right spec and you'll be fine in the meantime
rougeben83 is offline   Reply With Quote
Old 04-14-2007, 01:00 AM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
Nope, run Mcguard SplineDrives
http://www.oakos.com/Merchant2/merch...gory_Code=1100
decent pricing too, great product.
Old 04-14-2007, 03:14 AM   #16
mountjonas
Member#: 93859
2013 Appliance
6MT
i ran the stock lugs on my rotas for a few days when the tire shop forgot to put the mcgard spline drives on. everything seemed fine.
mountjonas is offline   Reply With Quote
Old 04-14-2007, 07:27 AM   #17
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
That's some good searching going on . Good job ! Don't see many search compliments on nasioc so thought I would add one . I never tried stock lugs on the rotas just went with mcguards . I have also been through threes set's of wheels since the rotas that I had back in 04 .
Old 04-26-2007, 03:14 PM   #18
DieselClown
Member#: 36135
2005 WRX
bump, but I just realized that I've been running the stock lugs on my Rotas for the winter. they're fine, but I had a set of no name lugnuts for my summer set up (SSR Comps) and can't seem to find them anymore. Will the spline drives fit the comps?
DieselClown is offline   Reply With Quote
Old 04-26-2007, 04:00 PM   #19
LyveWRX
Member#: 19057
& Red Ford & '72 CB350
Bogert and rougeben are correct. Also hubcentric rings are not essential they only make it easier to put your wheels on.
The best answer in this thread:
LyveWRX is offline   Reply With Quote
Old 04-27-2007, 11:43 AM   #20
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Thumbs up
EXCELLENT! 100% I like the bulge style and could never figure out why the factory designed lug nuts with such a small surface area? I think all the OEM wheels have steel inserts which is more durable then just the aluminum. I wonder what percentage of our members are running aluminum verses steel lugs and I am sure only a few have Ti.
nottofast is offline   Reply With Quote
Old 04-27-2007, 01:57 PM   #21
LyveWRX
Member#: 19057
" I think all the OEM wheels have steel inserts"
nope for a fact the regular 16x6.5 100pcd subaru wheels do not have steel seats, to my direct knowledge my compomotives have steel seats. IIRC someone posted a photo showing the forged BBS wheels have steel seats too.
Old 07-20-2007, 08:30 PM   #22
BlackPearlX
Member#: 118165
2006 WRX /
2004 Forester
good thread
BlackPearlX is offline   Reply With Quote
Old 07-20-2007, 09:11 PM   #23
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
the 06/07 wheels have steel seats, too.
Old 07-20-2007, 11:05 PM   #24
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
same thing happened to me when i bought my RAYS gramlights 57S rims, so I went to NAPA and they hooked me up. The ones i bought from NAPA looked like the picture above fit way better into the rims because of the large "buldge" which looked to hold the rim much better than stock lugs that barely made contact with the rim at all. i wouldnt feel safe driving with the stock lugs on these particular rims at all.
but you should be able to pick up a set of lugs at any NAPA or autostore if you had to, i didnt feel like waiting either!
PaulRex is offline   Reply With Quote
Old 07-22-2007, 11:04 PM   #25
ChrisL2
Member#: 1444
I've used the stock logs on rotas before. However, I had to use a thinwalled 19mm socket to put them on.
If you need lug nuts, go to any good tire/wheel store and they should have some that fit. I got a set of gorilla splined lug nuts from Discount Tire.
Just make sure they are the correct thread pitch.
ChrisL2 is offline   Reply With Quote
can I use stock tires on rota boost 17X7.5 meatling Tire & Wheel 4 08-11-2008 12:20 PM
Stock lugnuts on Rota BlackPearlX Newbies & FAQs 3 07-20-2007 08:38 PM
anyone use stock lugs on rotas? phantom338 Tire & Wheel 2 07-05-2006 08:06 PM
Any reason not to use stock lugnuts with BBS wheels? robtmc Brakes, Steering & Suspension 6 01-03-2003 02:43 PM
Can I use Factory Lugnuts for ROTAs? desiwrx02 Brakes, Steering & Suspension 7 09-12-2002 11:16 PM
