#1 |
Member#: 1277
Vehicle:1999 Minnam Stage 2 Cobb Stage3 engine, TEC3 |
did any one know how to install the knock sensor?
i went to lagging.com but it wasn't help at all. I think i'm ok with the ECU part but i couldn't find where to install the knock sensor by the engin department. thank
#2 |
SCIC
Moderator Member#: 85
SCIC
The only one I have seen installed was up underneath cyl #2 IIRC but it was tapped to go there. The piston that seems to go kablooey is #3 (I think it is due to the heat from the headers and a turbo going there). Hope that helps.
Rich |
#3 |
Member#: 2231
SCIC
Vehicle:2002 WRX Black |
The drivers side motor mount bolt is a good place, threads are the same as the sensor adapter and it`s easy to get to. Replace the bolt with the adapter, tighten it good, then install the sensor and snug it down lightly.
Another way is to move the stock sensor to the bell housing and install the J&S in the stock position. This makes the J&S more sensitive than the stock sensor but involves drilling and rethreading for the J&S. The J&S is the best mod I`ve put on my Impy. Really brings out the potential of the turbo! ED @ ISR 96 1.8 turbo www.autocaresubaru.com |
#4 |
Member#: 168
SCIC
Vehicle:2011 M3 and STI white |
Suby2nr.... Ya, how cool.
Anyways, senior Ed is absolutly right. putting the stock knock sensor on the bell housing and locating the J&s in the stock location worked out wonderfuly. I can't live without my J&s. What a great piece.www.autocaresubaru.com [This message has been edited by TMR Impreza (edited October 20, 2000).] |
#5 |
SCIC
SCIC
Wow me, Ed and TMR all posting in the same thread talk about weird.
Ed thanks for everything yesterday. TMR are you going on Sunday? Rich |
#6 |
Member#: 168
SCIC
If I can car pool with somebody yes, If not, no. I don't want to drive my car.
#7 |
SCIC
SCIC
Find a way to ISR and I got you.
Rich |
#8 |
Member#: 1277
thank a lot you guy and do you have any picture for it?
thank |
| Thread Tools | |
| Display Modes | |
| CEL Fix, Need help with the rear o2 sensor | subiee sTi | Newbies & FAQs | 4 | 05-03-2010 12:18 PM |
| Help with CEL and knock sensor | tahrndt | Normally Aspirated Powertrain | 9 | 10-23-2005 07:56 PM |
| 01 LGT Tranny into WRX. Figured out the basics, need help with the rest. | elhalisf | Transmission (AT/MT) & Driveline | 1 | 03-10-2005 07:50 PM |
| Need help with the Crank pulley | The Wraith | Normally Aspirated Powertrain | 1 | 07-12-2001 06:43 PM |
| Anyone try this with the stock knock sensor? | 8Complex | Normally Aspirated Powertrain | 3 | 10-20-2000 05:49 AM |
