Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-19-2000, 09:04 PM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Post need help with the J&S knock sensor
did any one know how to install the knock sensor?
i went to lagging.com but it wasn't help at all.
I think i'm ok with the ECU part but i couldn't find where to install the knock sensor by the engin department.
thank
ChAi is offline   Reply With Quote
Old 10-19-2000, 10:55 PM   #2
MPREZYA
SCIC
Member#: 85
Post
The only one I have seen installed was up underneath cyl #2 IIRC but it was tapped to go there. The piston that seems to go kablooey is #3 (I think it is due to the heat from the headers and a turbo going there). Hope that helps.
Rich
MPREZYA is offline   Reply With Quote
Old 10-20-2000, 07:18 AM   #3
suby2nr
Member#: 2231
Post
The drivers side motor mount bolt is a good place, threads are the same as the sensor adapter and it`s easy to get to. Replace the bolt with the adapter, tighten it good, then install the sensor and snug it down lightly.
Another way is to move the stock sensor to the bell housing and install the J&S in the stock position. This makes the J&S more sensitive than the stock sensor but involves drilling and rethreading for the J&S.
The J&S is the best mod I`ve put on my Impy. Really brings out the potential of the turbo!
ED @ ISR
96 1.8 turbo
www.autocaresubaru.com
suby2nr is offline   Reply With Quote
Old 10-20-2000, 10:34 AM   #4
TMR Impreza
Member#: 168
2011 M3 and 328i
white and black
Talking
Suby2nr.... Ya, how cool. Anyways, senior Ed is absolutly right. putting the stock knock sensor on the bell housing and locating the J&s in the stock location worked out wonderfuly. I can't live without my J&s. What a great piece.
[This message has been edited by TMR Impreza (edited October 20, 2000).]
TMR Impreza is offline   Reply With Quote
Old 10-20-2000, 11:08 AM   #5
MPREZYA
SCIC
Member#: 85
Post
Wow me, Ed and TMR all posting in the same thread talk about weird.
Ed thanks for everything yesterday.
TMR are you going on Sunday?
Rich
Old 10-20-2000, 11:19 AM   #6
TMR Impreza
Member#: 168
2011 M3 and 328i
white and black
Talking
If I can car pool with somebody yes, If not, no. I don't want to drive my car.
Old 10-20-2000, 08:09 PM   #7
MPREZYA
SCIC
Member#: 85
Post
Find a way to ISR and I got you.
Rich
Old 10-20-2000, 11:32 PM   #8
ChAi
Member#: 1277
1999 Minnam Stage 2
Post
thank a lot you guy and do you have any picture for it?
thank
CEL Fix, Need help with the rear o2 sensor subiee sTi Newbies & FAQs 4 05-03-2010 01:18 PM
Help with CEL and knock sensor tahrndt Normally Aspirated Powertrain 9 10-23-2005 08:56 PM
01 LGT Tranny into WRX. Figured out the basics, need help with the rest. elhalisf Transmission (AT/MT) & Driveline 1 03-10-2005 08:50 PM
Need help with the Crank pulley The Wraith Normally Aspirated Powertrain 1 07-12-2001 07:43 PM
Anyone try this with the stock knock sensor? 8Complex Normally Aspirated Powertrain 3 10-20-2000 06:49 AM
