Welcome to the North American Subaru Impreza Owners Club Wednesday November 25, 2015
Old 02-12-2001, 12:53 PM   #1
Member#: 775
Post Octane rating for Turbo's
How is it I can't import a whole WRX engine and put it in my car without running at leat 97 octane, which we can't get in the states without ocatne boost. Yet, you all turbo your cars and run fine on 91 octane? what am I missing?
SubieRacer is offline   Reply With Quote
Old 02-12-2001, 12:54 PM   #2
Member#: 329
1995 325i
Arctic Gray
The way we measure octane is a little different from other countries, so our 94 octane we get at the pumps is close enough.
RidinLow is offline   Reply With Quote
Old 02-13-2001, 01:31 AM   #3
Member#: 775
What? How is it they measure octane differently?
We only get 91 in Colorado.
"close enough" is something I can live without.
Old 02-13-2001, 07:45 AM   #4
Member#: 2709
2006 WRX Wagon
I don't think that the measurements are different, but the components that make up the gasoline (ethanol) are different from country to country (for emmisions requirements) and lead to different ratings.
I certainly dont think an engine designed for a minimum of 97 would run too well on 94. The engine would probably knock like crazy. Thats one of the reasons why it takes so long for cars like the WRX to get introduced over stateside. The car has to be tuned to the [much] lower octane rating (91 is the minimum requirement for the WRX, correct?).
I know for a fact that you can get higher than 94 at a service station. My company markets 100 octane at a number of its outlets in the Delaware Valley. Its not very common, and at around $4.00 per gallon, you'd prolly only fill up before an auto-x ($4x10 = $$$$$$$). This is still better than the 11$ bottle of octane booster cause the 100 is still a higher rating and better blended. (I think its 2 bottles of octane booster to get over 100... dont quote me on that though.)
0.02$ USD
Mike2000GT is offline   Reply With Quote
Old 02-13-2001, 04:38 PM   #5
Member#: 20
You can run the JDM/Euro motors here without a problme...not sure about on 91 octne gas though, as that is a bit low. The rest of the world uses a different measuring system than the US (ala metric vs. U.S.). As such, 91 octane here is NOT the same as 91 octane "over there". I researchd this heavily when shopping for the motor in my car now (almost done!), and found that 94 Sunoco, which I have always used anyay, is equla to 98 RON (the JDM/Euro rating). Since my motor is from an STi 4, I will be fine..the STi4 ecu's are much better at compensation for lower octane than the V5's, from what I am told....due mainly to the V5 running a bit highr boost, and ignition timing a little higher than the previous STi's. When turning up the boost significantly (over 21 psi) I will use either booster, but probably av gas, or race gas
adam99rs is offline   Reply With Quote
Old 02-14-2001, 05:44 AM   #6
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
The issue is that in Europe and Japan they just use RON (Research Octane Number), whereas the States use the RON+MON/2 formula (MON is Motor Octane Number, and is lower than RON). Hence, our ratings are an average of the two numbers and are lower than the numbers you see overseas.
Marquis is offline   Reply With Quote
new octane rate for my country 555 Engine Management & Tuning 1 07-02-2003 02:47 PM
76 Racing gas 91-100 Octane ratings WRX-pilot STi Forum Archive 2 06-20-2003 02:54 AM
Do The Octane Ratings Lie? Absolut Off-Topic 19 04-25-2003 06:15 PM
Octane ratings.. ??? Speedwagon Legacy Forum 3 12-06-2002 09:42 AM
Cold weather octane rating? doobie Normally Aspirated Powertrain 5 11-27-2001 11:11 AM
